We have a hot point aqgmd149. It came up with the machine is blocked. We followed the instructions to clean out the pre filter but it still won't do anything itvkeeps coming up with the same error message! Don't know what else to try a s the manual states this should fix it.
  • Washing Mach... Master
  • 2,295 Answers
Are you talking about the drain pump?if so if you cleaned out the pump and hoses and it still won't drain you have a bad pump,you have to replace the drain pump if error code keeps coming up
Posted on Dec 16, 2014
Where is the elusive filter located? I thought it was hiding under the flap thing at the bottom but I can't for the life of me work out where it is
If you were to Google "Hot point first edition FEW manual" using Firefox, the results will lead you to "for Hotpoint FEW washer - Laundry Appliances Manuals" at "laundry.manuals online.com>....> Hotpoint Washer".
Download a free copy of the instructions for Installation and Use for Hot Point First Edition Range User Manual.
I have looked through the manual and there is no direct evidence of a filter as such (common to other machines), but there are details of what maintenance should be followed to clean the machine - not too user friendly but may help.
If you do go to the manufacturers website (Hot point is an Indesit company) you will find that previous buyers have asked the same question as you)
Nov 16, 2013 | Hotpoint First Edition FEW12 Front Load...
My whirlpool awm 029 washing machine won't empty
I would gently suggest as a first step that you clean the drain motor/pump lint tray/filter- so many 'faults' are caused by blocked filters.
Following are my complete and hopefully 'coverall' pre-typed guidance notes for checking both the drain motor filter and the drain motor ;-0)
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT (alternatively use a wet vac as sensibly suggested by VinnyB1234!)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!). These panels are either held on by (plasic) screws or will just pull off. Most filters are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to persuade it to come out to play.
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. Using something suitable like a glove see if it is easy to briefly slow the motor down. If it is easy then the motor is malfunctioning.
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
Oct 11, 2011 | Washing Machines
The machine won't pump out water and readout says PU so assume the pump is blocked. We live in a remote community so need to fix this ourself if possible. We're is the pump on the machine? Can we...
Either the pump or the filter (if your particular model has one!).
I would gently suggest as a first step that you clean the drain motor/pump lint tray/filter. So many 'faults' are caused by blocked filters and many machines will not even go to rinse or spin or release the door lock if there is any water still left inside.
John C
Sep 20, 2011 | Electrolux Washing Machines
Smartdrive 601-U, product 93913, Serial number MLL 6333121, 6 Kg. The problem started when hot water hose kept cutting out many times during filling time. Now, the panel is still lighted but water no...
Two problems- water feed and possibly blocked drain filter.
Water feed-
If you have checked that the hot and cold water taps are turned on fully and the hoses are not kinked or squashed at the back, it is worth while checking both the hot and cold water inlet filters. Turn the taps off and remove both hoses at the washer end. Inside each inlet port there is normally a little filter which should just slide out. Clean if necessary and replace each one and the hoses. If after turning the taps back on there is no improvement, the problem is symptomatic of a malfunctioning hot or cold water control valve. Sorry but it needs a service call and a check that it isn't the control PCB ;-0(
Drain filter
If these have assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck,
John C
Sep 19, 2011 | Fisher and Paykel GWL11 Top Load Washer
My aquasmart washing machine won't drain.
Hi carl255 from retired Englishman in SW France,
(pre-typed 'cos I can't type THAT fast!)
John C
Sep 15, 2011 | Fisher and Paykel GWL11 Top Load Washer
Programme does not run - water in drum won't drain
'....water in drum won't drain'
John C
Sep 10, 2011 | Bosch WFLI 2440 Front Load Washer
I have a indesit wm12x I putted on pre-wash setting and the dial won't stop turning and I try to put it on rest/stop but won't unlock the door for me to take the clothes out! Any help please!
It's doing that because it is unable to drain all of the water out of your washer I suspect ;-0)
John C
Sep 06, 2011 | Indesit W 123 Front Load Washer
The front loader won't start, and it's flashing the 'clean pump' light. Where is the pump? how do i clean it?
I would suggest as a first step that you clean the drain motor lint tray/filter. So many 'faults' are caused by blocked filters. The motor is unable to drain all of the water in the allotted time.
Here are my complete, general pre-typed guidance notes for checking filters and motors ;-0)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!) and held in by a round cover/knob.
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. If it doesn't work then the motor is malfunctioning!
Hope the filter is the problem!
Jun 09, 2011 | Whirlpool AWOE8748 Front Load Washer
My Aqualtis AQGMD149 has the fault that it is blocked. I cannot remove the cover to clean the pump out. The manual says unscrew it anti-clockwise but it only goes a quarter of a turn and won't budge. ...
Try pulling the filter after you have unscrewed it. Often there is a large rubber sealing ring on the perimeter of the filter drawer so it has to be pulled quite hard to remove it.
Feb 28, 2011 | Washing Machines
My hot point dishwasher isnt cleaning very well. what can i do to help it
The filter is probably blocked.
It is inside the base of the machine.
Take out the filter and clean it and also clean out the filter well as that can also hold quite a bit of debris.
Please dont forget to vote this answer was helpful
Many thanks
Feb 13, 2011 | Hotpoint Dishwashers
Washing Machines Logo
35 people viewed this question
Top Washing Machines Experts
