My tv started to get Purple thick lines accrossed it, until finally it went black. After it has been turned on for 15 minutes the screen will be visable, although it is VERY dark.
I have taken the back off the TV and all the components are exposed, with what appears to be part numbers/bar codes. if you have ANY idea of what went bad, I would be greatful as the TV is ONLY 3 years old.
    Master:
  • 742 Answers
If it's a plasma I would say you have a bad y sustain module and y buffer. Check the buffers and y sustain.
Posted on Dec 15, 2014
Sharp LC-55LE643U - bottom 3/4 of my LCD TV is shadowed and purplish. How do I fix it?
Try a reset but unfortunately I believe it is a board cratered by the power outage. Try to get things shut down when the power goes
Feb 28, 2017 | Sharp Televison & Video
Purple static lines and a jumpy picture
Your picture tube is about to go.
If it's still under warranty,take it back.
Hope this helps.
Nov 26, 2013 | Mitsubishi VS-45607 45" Rear Projection...
When turning on the TV, it has redish, purple & green lines across the screen & you have to leave it on like that for at least 5 to 10 minutes for it to warm up. You just have to keep turning it...
Al Plasma and Lcd TV have boards that control vertical and horizontal output to their respective areas. They are connected to the screen by ribbon cables. If one of these boards fails all together, has a failed chip, a bad connection, or a bad ground somewhere it will result in a black line in the area of that board. A bad ribbon cable connection on the bottom will result in a vertical black bar though the screen. Many times resetting the connection will fix it, if the ribbon cable has been nicked there could be a severed connection. They an sometimes be fixed, but it is a pain. An yes I have done it, but the bar is gone. The same will happen if the chip that outputs to that area opens. The connectors are the first place to look paying close attention to the cable, they are extremely delicate so great care must be taken if you decide to tinker with em, the usually have lift locks that release them, but it is very easy to wreck em. Good luck.
May 25, 2011 | JVC LT-37X688 37 in. LCD HDTV
Samsung LCD TV slow to start
Dont have a solution, my samsung 46 inch is doing same thing. Have you found a solution?
Oct 05, 2009 | Samsung LNT5265F 52 in. LCD HDTV
Purple Screen
If it is only 2 months old,then you still have warranty.
A purple lcd, viewfinder and photo is a 100% CCD failure.
If out of warranty, not worth the repair.
Mar 07, 2009 | Panasonic Cameras
Mitsubishi WS-55613 Not Reading Sources
have tthe tuner checked...it may have gone bad
Oct 01, 2008 | Mitsubishi WS-55613 55" Rear Projection...
Hitachi model no 50es1k---july 1993
loose connection on circuit board and also maybe bad caps in vertical area.
Mar 03, 2008 | Televison & Video
No Blue. Horizontal Lines.
Not to me, but it also depends on if you could do this yourself or not. And the area you are in sometimes is responsible for the cost being high.
Sep 02, 2007 | Mitsubishi VS-50705 50" Rear Projection...
TV screen went black, sound OK
check cold solder vertical circuit
Nov 21, 2006 | JVC AV-27530 27" TV
Televison & Video Logo
32 people viewed this question
Top Televison & Video Experts
Electro Med Services...
