Question about Leisure Kitchen Ranges
HOW DO I GET ACCESS TO CHECK THE CONTROL ELECYRICAL CONNECTIONS ON A LEISURE RANGE COOKER MODEL NUMBER HJA 5100?
5 Suggested Answers
  • 3 Answers
SOURCE: can you help me find a user guide for leisure
I could copy my handbook of the Users Guide for a Rangemaster 110 Gas appliance if you wish and send it on to you, if that would help.
Posted on Oct 23, 2009
SOURCE: Have a Leisure roma 100 cooker model number
most likely thermal fuse behind oven take off back plate and you will see the brown wire with the heat shrink sleeving covering the fuse.wire and fuse comes as one part
Posted on Jul 24, 2010
SOURCE: Model number SI 9TF GRA Britannia Range Cooker
my larger oven on my britannia range has stopped working would it be the themostat and how much would this cost and can i fit it myself? the grill is working and so is the small oven can anyone help please. ben.
Posted on Aug 07, 2010
caroldon
  • 17130 Answers
SOURCE: leisure naples range cooker ignition not working
It can be due to break in the wiring to the ignitor pods , a short in the electrode or a possible malfunction on the circuit/ trigger switch. All this requires that you need to isolate the sections one by one to confirm. detach the HT lead to the electrode and if there is high voltage check on the fittings of the electrode/insulation. If the HT is absent then check the trigger switch and circuit.
Posted on Nov 21, 2011
My gourmet classic leisure cooker has a noisy fan. What can I do?
Hello CAROL ROSA,
If it is NEW... TAKE IT BACK.
ELSE... (replace the fan).
Post the actual model number to see if
we need to look for 'parts' (USA) or "spares" (rest of the world)...
Together we can get this
'FIXED' (USA) or "sorted" (rest of the world)...
http://www.harveynorman.ie/home-appliances/cooking-appliances/range-cookers/leisure-gourmet-classic-oven-grb6cvr.html
Aug 30, 2016 | Kitchen Appliances - Others
I have a leisure range cooker. model number CMTF99R.The oven RHSis not Heating up. the fan is working and the thermostat light is coming on.
Check for voltage at the element, could be a hi-limit thermostat or a failure at the control board.... You may find you are missing one leg (half) of the 240VAC required to power the elements
Jul 31, 2016 | Leisure Range 90 CMTF95C Cream 900 mm Dual...
How do I change the glass lid on my cooker
Buy one direct. I am guessing it has a straight forward screw off hinge. Nice range!
Spares for Leisure Range Cookers Official UK website
Jan 29, 2016 | Leisure Cookmaster CM101NR
Timer leisure Roma 100
You will have to resort to your owner's manual. Every Range is different. If you don't have the owner's manual, check with the manufacturer online.
Apr 30, 2012 | Kitchen Ranges
Ov en will not heat up. no broiler heat or bake heat model number 790.96614407
Your symptoms point to a failure in the electronic oven control board (that acts as the thermostat for the oven in this type of range). Unplug the range and remove the upper back panel to access this component. You will likely see to burn marks on the control board. The control board will need to be replaced in this situation.
Before installing the control board, I recommend that you check the bake and broil elements. Look for damage on both elements. Remove the lower back panel (with the range still unplugged ) and check the wiring connections on both elements. A damaged or shorted bake or broil element could have caused the problem with the control board.
Hope this helps.
Shane
Mar 01, 2011 | Kenmore Ovens
Location of thermal fuse in leisure cookmaster range cooker
where is the thermal fuse located in a leisure cooker
Jul 22, 2010 | Ovens
Why can't I access the Url http://192.168.0.30
check your IP address and see if the computer you are using is on the same subnet. your IP must be 192.168.0.xx where xx is any number. if you get a different IP address, use a static IP address between 192.168.0.31 to 192.168.0.40
how to check IP:
click Start - Control Panel - Network Connections - right click Local Area Connections - click Status - Details.
how to use static IP:
click Start - Control Panel - Network Connections - right click Local Area Connections - click Status - Properties - TCP/IP - choose Static - use any IP address in the range above.
click apply and try to access your repeater again. I am assuming that you have given the correct IP of your repeater.
Apr 17, 2009 | D-Link AirPlus G DWL-G710 Wireless Range...
Kitchen Ranges Logo
52 people viewed this question
Top Leisure Kitchen Ranges Experts
Timllfixit
Andrew Taylor
Andrew Taylor
ray gallant
Are you a Leisure Kitchen Range Expert? Answer questions, earn points and help others
