Question about Toyota Celica Gt/St 1989-1999 Sportline Lowering Springs
Please,how to setfuel&;airflow on my 89 toyota celica
Its burning way to rich! it idles good but it wants to stall when i hit the gas
    Master:
  • 755 Answers
Is this carburated ,or fuel injected , if fuel injected then there is no adjustment , did you tune it up at all new plugs wires cap and rotor this make a big differance on a car ,if it is carburated , ther should be a screw or 2 on it one for fuel and one for air , usally on the side , ck on youtube it might be posted there
Posted on Dec 15, 2014
1991 Toyota Camry running rich after cleaning the throttle body and replaced the throttle positioning sensor. Checked for vacumm leaks but cant find any
92 camry failed smog because running rich. Why? - Toyota Nation ...
www.toyotanation.com/.../411132-92-camry-failed-smog-because-runni...
Apr 26, 2012 - 15 posts - ‎9 authors
off ignition timing, and the car was running to rich. the timing i will get fixed tomorrow but the rich .... Our 93 camry le with 4 cly engine failed agin a few weeks ago, both our toyotas always fail.. they are .... 1991 Toyota MR2 V6 91 MR2 N/A Rough Idle, Running Rich, No Accelleration
Apr 24, 2012
Celica 1991- Insane gas consumption/running rich
Jan 24, 2011
22RE Running Rich, didn't pass smog
Apr 25, 2010
1998 Camry 5SFE 4-cyl idle long-term fuel trim
Sep 11, 2007
More results from www.toyotanation.com
Toyota Camry running rich Questions & Answers - Fixya
www.fixya.com > Forum > Tags > running rich > Cars & Trucks > Toyota
... running rich I have a 1991 Camry that is running rich. I just replaced the O2 sensor and a new cat, oil change, new spark plugs. The car wont pass smog. it is ...
1992 Toyota Camry XLE V6 Excessive Running Rich ...
? 0:21
https://www.youtube.com/watch?v=WPTCtLwr61g
Aug 16, 2013 - Uploaded by StreetSports1
1992 Toyota Camry XLE V6 Excessive Running Rich ... 1997Toyota Camry V6 forward Oxygen (O2) Sensors .
Jan 11, 2016 | Toyota Cars & Trucks
My 2002 Toyota Celica acts like it is going to stall when I press down the clutch, It is fine until it warms up and then it idles at around 500rpm and acts like it wa
Use a bottle of yellow HEET dry gas / GAS DRYER to remove any moisture problem in the fuel.
Clean / replace air filter.
Jan 17, 2014 | 2002 Toyota Celica
My 1992 toyota celica has a lower (about 800 rpm) and rougher idle. I recently have had issues with sputtering while driving, not stalling, but feels like it will. I recently bought gas while the gas...
If you feel that before getting the fuel car was fine, and something has suddenly happened after re- fueling the car, it may be due to the contaminated fuel or the clogged fuel filter.
Nov 29, 2012 | 1992 Toyota Celica
My car is not idling right and wants to stall out on takeoff after it warms up
check your airflow if u can buy another but u can open the top part and adjust till ur idling gets right if u know how to adjust
Jul 24, 2010 | 1992 Toyota Celica
My 2005 Mazda 3, Engine Problems
I honestly think that it is your mass airflow sensor that either went bad or needs cleaning. Auto Zone can run a computer test on your car and diagnose your problem, and if so, they carry a special can of Mass Airflow Cleaner put out by CVR that cost around 6 or 7 bucks. The mass airflow sensor determines how rich to make the gas. This would cause the car to hesitate or jump. Hope this helps. Please leave feedback!
Mar 31, 2010 | 2005 Mazda 3
Car stalls when in idle
You need a tune-up. Not a major problem, and it will fix all your problems. Please don't forget to rate this answer.
Feb 23, 2010 | 1995 Toyota Camry
Jaguar xj6 4.0 1990. showing fault code fuel 14, fail 14. what does this code mean ?
2 airflow sensor out of operating range 3 coolant temp sensor out of operating range 4 oxy sensor indicates full rich 5 throttle potentiometer/airflow sensor... (low throttle pot signal with high airflow sensor signal) 6 throttle pot/airflow sensor...... (high throttle pot signal with low airflow sensor signal) 7 throttle pot...idle fuel adjustment failure(idle speed??) 8 intake air temp sensor...open or shorted circuit to sensor 11 Throttle pot at idle: Throttle pot idle trim out of normal range 12 Airflow meter: MAF signal out of range 14 Coolant thermistor: Resistance out of range or static during engine warm up 16 Air thermistor: Resistance out of range 17 Throttle pot: Out of range 18 Throttle pot/Airflow: Low throttle pot signal at high airflow 19 Throttle pot/Airflow: High throttle pot signal at low airflow 22 Fuel pump drive: ECU output to fuel pump relay 23 Fuel supply: Engine running too rich 24 Ignition Drive: ECU output to ignition Amp 26 Air leak: Engine running too lean 29 ECU self check 33 Injector Drive: ECU output to injectors 34 Injector: Looks for Injector dribble 37 EGR Drive: ECU output to EGR switching valve 39 EGR check sensor: EGR not working (normally pipe blocked) 44 Lambda (O2) sensor: Poor mixture control rich or weak (or misfire) 46 Idle speed Control valve: ECU output to Coil AB 47 Idle speed Control valve: ECU output to Coil CD 48 Idle Speed Control Valve: Stepper motor grossly out of position 66 Air pump: ECU output to air pump relay 68 Road speed sensor: Seen speed < 5km/h at high engine airflow 69 Drive/Neutral switch: Seen cranking in "D" or high airflow in "N" 89 Purge Valve drive: ECU output to purge valve
this is all I could find
Nov 09, 2009 | 1990 Jaguar XJ6
1990 celica 2.2 5s-fe wont idle, wont erach 1400rpm
your problem is in your throttle sensor that controls the idle it is located right behind your intake and it has two screws that mounts it i am almost positive that this is where your problem is comig from
Dec 31, 2008 | 1990 Toyota Celica
Rough Idle on 1984 Toyota Celica Supra
You said you replaced the plugs - did you use the toyota platinum plugs? I found out the hard way that even the platinum plugs from bosch or any other kind of platinum plug just doesn't work right. Yes, they are more expensive from toyota, but they can make a difference in the way the engine runs.
Jul 22, 2008 | 1984 Toyota Celica Supra
Toyota Celica Gt/St 1989-1999 Sportline Lowering Springs Logo
65 people viewed this question
Top Eibach Vehicle Parts & Accessories Experts
Timllfixit
Robert Rankin
 Mikey
Mikey
Are you an Eibach Vehicle Part and Accessory Expert? Answer questions, earn points and help others
