How to change monitor from dvi to avg - Computers & Internet
    Problem Solver:
  • 28 Answers
It is not avg , its VGA Cable ,, u will get a cable were the monitor port has dvi and the system tower has a VGA port, the cable adapter u need to go for will be a DVI male to VGA cable adapter .
Posted on Dec 16, 2014
Monitor on but getting no picture. The setting is DVI
Are you using a DVI cable to connect the monitor to the computer? Try changing the monitor setting to analog if not using a DVI cable.
Sep 07, 2014 | ASUS LCD Monitor
Screen flickering on windows 7 boot
This is more than likely an issue with the monitors themselves. Does this happen on the main monitor is you move the secondary cable over to it? What kind of monitors are you using, how old are they, and do you know the refresh rates on them?
Nov 21, 2013 | Nvidia Computers & Internet
Can i hook up my xbox to a Acer V223W EJbd monitor
Yes, you can get a DVI or AVG connector and use those.
Mar 09, 2013 | Acer 22" V223W EJbd Widescreen LCD...
Changing cable port
The monitor is a Fujitsu VL-15DX5G. 15 inch LCD.
The monitor cable uses a female DFP20 connector.
(Display Port 20-pin)
http://auction.thumbnail.image.rakuten.co.jp/@0_auc/image50/cb/4a/00010523850/a1/85/img00149858603.jpg
So you need a male DFP20 to male DVI-D adapter, or adapter cable.
DFP20 Male to plug into the monitor cable, and Male DVI-D (Dual) to plug into the graphics card's, female DVI-D connection.
So far, all I have found from a quick search is a Male DFP20 to Female DVI-D adapter, such as this example,
http://www.worldofcables.com/store/viewitem.asp?idproduct=768
Of course this won't do.
IF, this is all that's available for DFP20 adapters, you'll need an adapter of Male DVI-D to Male DVI-D, also. (Yes, I am aware of how crazy that sounds)
(It would appear, adapters are sold to connect a normal DVI-D monitor cable, {Male}, to a computer with a female DFP20 connector)
Should your searching only find DVI-D female to DFP20 male adapters, or adapter cables, then here is an example of a DVI-D male to DVI-D male adapter,
http://www.kvconnection.com/product-p/m-sgc-dvid-mm.htm
(DVI-D male to DVI-D male cable would probably be better as there would be less strain on the graphics card's DVI-D connection)
May 14, 2010 | Computers & Internet
How do i change input from vga dvi
Just plug in the DVI cable only. Should find it automatically.
Nov 21, 2009 | Norcent Technologies LM-965WA Monitor
Monitor only works with DVI/VGA adaptor.
if your monitor came with a disk try installing the drivers again you might still have the drivers for the previous monitor you had with your system if not try going to the manufacturers website and getting the drivers and install them
Aug 13, 2009 | Acer AL2016W 20" LCD Monitor
Monitor says No signal digital
Is ether the monitor or video card uses both DVI or VGA port. There may be a switch on the graphic card that changes it from DVI to VGA, often outside the card.
Also is the computer monitor set to the right setting if it can use both VGA and DVI, if using DVI (of any type) it need to switch to digital, and if using VGA it need to be set to analog. This may be a physical switch or using the settings button. (see manual how to change them)
PS: VGA port is a blue D shaped port with 15 pin holes, and DVI is a white rectangle port with one port being a line.
Mar 17, 2009 | ViewSonic VG2030wm LCD Monitor
Moniter
First please check whether the Monitor powering ON or not
the see the colour of light of the monitor i.e, its green or orange or not glowing next see that all the lights showing but constantly flickering or else just see u r VGA or DVI Cable which is connected properly to the CPU if it is ok then remove the cable connect only the monitor to different machine in case still not comming then finally it is a monitor problem or else just check all the connections inside the CPU
In case its monitor problem either it will not power ON or else all the lights will blink constantly that means the refresh rate or the Resolution of the monitor has been changed in case if it is done just connect a different monitor boot in the safe mode by pressing F8 button after entering there change the resolution which will be in the display properties apply and reboot the machine or else turn off u r PC and connect u r Old Monitor and Boot the Machine
Jul 30, 2008 | E-Machines eMachines Desktop PC
IBM 9513 DWO
Dont know if you ever got an answer for this question but no the 9513 will only accept DVI input. You cannot change it to accept analogue.
You can test the monitor by using a HMDI to DVI input if you have satellite or cable box with a HMDI output.
E
Dec 08, 2007 | ViewSonic VA721 17" LCD Monitor
Can't use DVI with monitor
You have 3 ports on your graphics card(VGA - 15 pin D-Sub x 1, DVI x 1, and S-Video x 1)Now if you want to use DVI just connect the DVI port to your monitor thats all..
Enjoy!
Oct 19, 2007 | Gateway FPD2275W LCD Monitor
Computers & Internet Logo
64 people viewed this question
David Payne
David Payne
