Question about Jet Set Addiction Ladies Watch in Hot Pink"
How do I open the back of jet set watch to change battery
Opening using a screw driver
    Master:
  • 755 Answers
It prys open really a pain but it will open
Posted on Dec 15, 2014
Cannot figure out how to get back off to change battery
Google my friend. Try in your watch brand and model. I wish I could help you more. Normally it should have a small slot for a tiny screw driver to be placed for openings.
Nov 17, 2015 | Watches
Changing the battery in a mickey mouse pocket watch
The first answer is a canned answer. Seen it before. Examine the edge of the pocket watch. Start at the stem and look for a slight gap where the back cover meets the case. It is usually at the stem side or hinge side. Once located take a strong sharp knife and carefully pry up the back cover. It should remove fairly easily. I have about 12 pocket watches and they all work the same way. Once open there may be a small screw or two holding the battery in place. You will need a precision screw driver set or a small screw driver for glasses.
682b943c-dbb9-4041-9abb-ed1a67105d52.jpg eff96e41-9266-48e7-9603-ac9206c667a0.jpg 03735b42-603a-41af-9aa7-4d445bd017dc.jpg
Jun 30, 2013 | Watches
How to open back of watch to change out the battery
GET A SCREW DRIVER THAT IS MADE FOR GLASSES, AND FLIP THE WATCH OVER AND UNSCREW IT.
Jul 11, 2011 | Watches
How do I open the back of the watch to replace the battery & what type battery does it take? Thanks Ian Lawes
Usually the back of a watch is sealed with simple screws. Just unscrew them with a jeweler's screw driver and it will open the battery compartment of the watch.
The battery depends on what type of watch you are using. The most common batteries for watches are about less than 3/8 of an inch.
Mar 04, 2011 | Watches
How do you change battery for casio 1174 CMD-40?
I like these little RC IR watches. They're great fun!!! For this tutorial, you will need....
  • A small Phillips heads screw driver
  • A pin (or needle)
  • A replacement CR2032 battery
Instructions :
  1. Remove the 4 screws from the back of the watch
  2. Carefully remove the back plate, do not damage the delicate rubber seal
  3. Carefully remove the delicate rubber seal
  4. Use the pin to remove the small rubber block from the battery cover clasp.
  5. The pin should then be inserted in the gap of the white plastic lug, where the rubber block was removed.
  6. Use the pin to gently pull back the clasp of the battery cover.
  7. The battery cover will then open with a 5mm gap approx. It does not need to be removed.
  8. Use the screwdriver to remove the battery.
  9. After the battery has been replaced, just follow the instructions backwards.
I hope this little tutorial has helped.
Feb 10, 2011 | Casio Watches
I have a Majestron quartz pocket watch. How do I replace the battery?
  • Flip over your pocket watch. Remove the back of your watch. The back of watches are either screwed on by four small Phillips head screws (unscrew them) or the watch has a press inserted back (slide a thin knife blade under the edge of the back of the watch and pry it off).
  • Remove the circular watch battery out of the back of the watch.
  • Take the battery to any department store or watch store and purchase a new replacement battery.
  • Insert the new battery into the back of the watch.
  • Screw on or push on the back of the watch. Set the watch to the correct time.
  • Aug 23, 2010 | Watches
    Battery replacement
    do you mean you want to replace the battery for your watch?
    This isn't a difficult task to carry out. Simply get a small flat screw driver, use the screw driver to open the back cover of the watch, then you will see the battery of your watch. Remove the battery and replace with a new batter, cover back the watch and that's all.
    Note that you will apply force with the screw driver when you are trying to open the back cover of the watch.
    Good luck.
    May 18, 2010 | Casio Atomic Timekeeping Waveceptor Watch...
    Cannot open clasp prestige replica rolex
    1)Unscrew the crown until it pops out, the same way you would unscrew the crown to change the time on the watch.
    2)Place the watch case opener in the notches around the outside of the back of the watch case. You have to use a watch case opener made for Rolex watches to open the watch. Once the case opener is in place, twist it and the back will pop open.
    3)Use a mini screwdriver to loosen a tiny screw on the inside of the watch located near the stem. You do not need to unscrew fully--only loosen it.
    4)Pull the crown straight out. The crown and stem should come out easily.
    To open the back of the watch
    1)Purchase a Rolex watch back opener set, if you do not already have one. This set is able to open and close any size of Rolex case.
    2)Match the size of your Rolex case with the same size of grooved metal die from the tool set.
    3)Put the metal die on the grooves on the back of the watch case.
    4)Turn the die to remove the case.
    5)Remove the rubber gasket.
    This will help. Thanks please keep updated.please do rate the solution positively .thank you for using fixya
    Dec 31, 2009 | Bulova Watch
    How do I change the quartz battery on a Longines La Grande Class
    Just unscrew the screw at the back if your model have screw if not the other one snap to open.Use a pocket knife then open it look the number battery and replaced it with same number battery. Its you use Renata battery it is swiss 3years to last.
    Hope it may helps;
    Regards;
    VOTIT
    Jun 16, 2009 | Longines La Grande Classique L4.709.2.42.9...
    What to do with watch repair kit
    Unless the watch back has notches on it, you want to look around the edge of the watch and find a little lip. When you find the lipp, use one of the knives and pry open the back. Take one of the tweezers and pull out the battery, you could also use one of those handy-dandy screwdrivers to pry out the battery. Put the new battery in laying exactly like the old one , then proceed to close the back, making sure that the little notch (on the INSIDE lip of the back case) lines up with the stem and crown (the part used for setting the watch) so not to break it. The back openers and the knives are just differant ways to opn the back of the watch. Sometimes watches have screws on the back that need to be taken off in order to open the back case. The case vise is to minumize the wear and tear on your hands. The tweezers are for taking out the battery. If you have anymore questions PLEASE feel free to contact me I will be glad to assist you further! Good Luck!!!
    Aug 12, 2008 | Watches
    Jet Set Addiction Ladies Watch in Hot Pink" Logo
    229 people viewed this question
    Top Jet Set Watches Experts
    Ansel Alberto
    Ansel Alberto
    Are you a Jet Set Watch Expert? Answer questions, earn points and help others
