Question about Mitsubishi Televison & Video
I a Mitsubishi WD-52628 but not the original remote. I am trying to connect to directv through hdmi but am having trouble changing the source/input. The front panel menu only gives me card? options. Is there a trick to doing this?
    Master:
  • 742 Answers
Try a different hdmi cable
Posted on Dec 15, 2014
Testimonial: "I haven't been able to select the hdmi as the input yet though?"
How do I get off cable input and back to hdmi
use the original remote to change the SOURCE to HDMI
Jan 10, 2015 | Mitsubishi WD-65731 65" HDTV
I replaced the lamp in my Mitsubishi WD 52628 and the tv will still not come on and the lamp light still blinks
"Initialize" a "factory reset". Power on the tv, on the original remote, enter "MENU 1,2,3 ENTER". This will get you to the factory reset window. Initialize the default reset and you are fixed. Try this before ditching the set or tearing it apart. Good luck and post your results for everyone here with the blinking green timer light issue. Thanks.
Apr 25, 2012 | Mitsubishi WD-52628 52" Projection HDTV
Wd-52628 flashing blinking light
Using your original remote, power on the tv, enter "menu 1,2,3, enter" to "Initialize" the "factory reset" once the window comes up choose to reset to default. That should fix the blinking green timer light.
Jan 16, 2012 | Mitsubishi WD-52628 52" Projection HDTV
Snowy picture, device menu will not come up.
Depending on what devise, (cable box, game system, movie players) the sign of snow is no signal, there are inputs that you hook a devise up to on a TV, you have to change the input on the TV to pick up the signal of the unit, on the remote or TV itself, there with be a(n) "input", "source", "tv/video", or "video source" button that you can choose the same input you chose in the back of the TV.
Jun 28, 2011 | Mitsubishi WD-52628 52" Projection HDTV
I have a Mitsubishi WD-62525, and when the Directv installer came out, he said that he could not connect the box to my tv because he didn't know how to get my tv in HDMI mode. From what I am reading, it...
Your right connect the HDMI output from the directv receiver to an HDMI input on your tv. Change the tv input to the HDMI input and it should work. If your tv does not have HDMI input then it should have component input indentified as red blue green connectors on the back of tv. This is for video only. Connect the red and white for audio using the yellow/red/white cable that was included with receiver. The red blue green cable is also included with receiver as well as the HDMI cable. Did this installer educate you on how to use your directv equipment. If you are paying for HD access but your receiver is not connected the an HD input on your tv then you are not getting what you are paying for. This should of been resolved during the installation. The installer either is incompentant or just did not care. Call directv and demand them to make their receiver work with your tv if this means a field supervisor tech being sent out to correct this.
Mar 11, 2009 | Mitsubishi WD-62525 62" Rear Projection...
Connection of HDMI and Directv box
Monlink is the Connection I used with my Directv. All you need to use is the HDMI cords. Are you trying to also connect to stereo system or something other than a straight HDMI connection from Directv Box to WD-62525
Feb 02, 2009 | Mitsubishi WD-62525 62" Rear Projection...
Mitsubishi WD-52628 52" Inputs look like old cable scrambled channels
Change the 1000uf @16v capacitors on the FMT board that should solve your problem. You will most likely found that they have swelled. Let me know if you need further info.
Apr 04, 2008 | Mitsubishi WD-52628 52" Projection HDTV
WD-52628 Mitsubishi - change inputs
We had the same problem. Luckily, we had a service contract, so it was serviced yesterday. The fix involved the service guy going through a "service menu" and resetting the TV that way. He was not "allowed" to tell me how I can access the service menu, however. I do plan to research this on the internet in case it happens in the future. It is basically a software/computer problem, and unplugging the TV isn't enough to clear it unless the TV is unplugged for "a long time." The technician said the length of time depends on the condition of your capacitors. Anyway, as a temporary fix, he showed me that you can go into the PIP mode. The device toggle for PIP apparently did still work with mine, so I was able to switch the device on the secondary picture and then switch it to primary, then toggle the PIP off. Good luck!
Jan 05, 2008 | Mitsubishi WD-52628 52" Projection HDTV
Open Questions:
Mitsubishi WS-65511 Rear Projection Big Box TV resets with a green flashing light every 5 minutes, Then works fine for 5 more minutes (perfect picture). Acts up worse when cold. Warm it up Works hours It's NOT the DM board caps. I've already replaced the DM caps twice. Not the problem. No repairman will look at the set. Too Old. So am I. I could repair it with help. The power supply must have a safety circuit that will shut down & reset if too much draw. I DON'T have a diagram. I'm not sure how to trace it . Which board? If I unplug boards one at a time, Will it damage other boards ? I know it is NOT the 7 DM board caps everyone keeps telling me. I see no burn't parts, No bulging caps. Tapping on components doesn't reset. What kind of component would act up when cold , But not overdraw when warm? This set has the best beautiful picture when it runs. If you can get past the resetting every 5 minutes for the first hour, You can watch it sometimes for 20 hours. I've left it on at night & it is still on the next morning. Change the channel Or raise the volume, And off it goes. Once or 10 times, Keeps resetting. Then on for 4 or more hours, Maybe. I can't afford a new one. It works GREAT ! when it works. I've notice that even when the set is turned off, The green light starts flashing (resetting itself while it's off) , Then stops. Once in a hundred times it will kick off the breaker & you need to push reset with a pin on the front panel next to the green light. It's probably a 10 cent resistor OR a $ 1.00 cap. If I only had someone with more knowledge than me to help. I know how to use a meter & read a schematic. I built a Heathkit 25"TV in the 70's & all my novice ham gear. I'm 64 & not familiar with digital circuits. Can someone help PLEASE ?
Dec 16, 2017 | Mitsubishi Televison & Video
Televison & Video Logo
71 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
