Question about Hoover F6212-900 / F6215-900 SteamVac Agility Upright Vacuum
IT TURNED ON FOR TWO SECONDS THEN SHUT OFF WONT COME BACK ON?
PLUGGIN IT INTO DIFFERENT OUTLET
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 4 Answers
Check for a circuit breaker on the machine.
Posted on Dec 17, 2014
My apple ipod touch wont turn on
I've seen this before. You need to reset it.
  1. Toggle the Hold switch on and off. (Slide it to Hold, then turn it off again.)
  2. Press and hold the Play/Pause and Menu buttons simultaneously until the Apple/iPod logo appears, about 6 to 8 seconds. You may need to repeat this step.
If the above steps did not work, try connecting iPod to a power adapter and plug the power adapter into an electrical outlet, or connect iPod to your computer. Make sure the computer is turned on and isn't set to go to sleep.
If you are still unable to reset your iPod, use only one finger from one hand to press the Center (Select) button, and one finger from the other hand to press the Menu button.
I hope this works!
May 10, 2011 | Vacuums
My dyson will not turn on? I was using it and it just turned off, and wont come backon
Check the house fuse, use a different outlet, might be defective, check for fuse in unit.
Mar 31, 2011 | Dyson DC07 Animal Bagless Upright Cyclonic...
Brush wont spin
Was the belt worn or broken? It probably needs to be replaced. Here is the belt you need:
Dyson DC07 Belt
Apr 06, 2010 | Dyson DC07 Animal Bagless Upright Cyclonic...
Wind Tunnel vacuum motor won't turn on
The fact that you wiggled the cord and it came on would seem to indicate a defective cord, either at the plug end or at the machine itself. Look again at where the cord enters the vac and at the wall. twist it slightly if you see a thin or collapsed area that is your problem.
Sep 18, 2009 | Vacuums
Same kind of deal...it just stopped!
either you bent your power cord to much and there a break inside of it or one of the connections on the motor came loose.
Jul 30, 2009 | Hoover U5753-900 WindTunnel Bagless...
Kirby wont come back on checked outlet its ok
If you are refitting the shampoo tank, you havent turned it far enough. There is a safety switch that must lock
Mar 07, 2009 | Kirby Ultimate G Bagged Upright Vacuum
Will not start again.
If the cord sparked, then it is bad and needs replaement. If it sparked at the plug end, then replace the plug.
Feb 23, 2008 | Hoover V1 SteamVac SpinScrub Vacuum
U5180-910 vacuum shuts off on own
I had same problem. Turned out to be the filter that sits above the waste cannister. Remove the waste cannister. There is a little orange lever that releases the filter. It was caked with dirt not allowing any air flow causing the motor to overheat.
This foam filter gets dirty pretty fast.
Nov 18, 2007 | Hoover U5180-900 Vacuum
Hoover F6212-900 / F6215-900 SteamVac Agility Upright Vacuum Logo
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
