I can't connect my xBox 360 500GB to my Tedelex EC2175 470mhz catv
I have tedelex EC2159 remote codes it should be 3 digits not 4
Pilot remote control codes for TEDELEX:
30 results. Displaying page 1 of 1
NR Brand Model Type Pilot Supertel* Easytel Unitel 1 TEDELEX 1452 R/C P1679Y 2 TEDELEX 1452 TV P1679Y 3 TEDELEX 1455 TV P1655Y 4 TEDELEX 1458 TV P1655Y 5 TEDELEX 1459 TV P1655Y 6 TEDELEX 2052 TV P1679Y 7 TEDELEX 2056 TV P1690N 8 TEDELEX 2092 TV P1679Y 9 TEDELEX 2096 TV P1690N 10 TEDELEX 2098 TV P1655Y 11 TEDELEX 2099 TV P1655Y 12 TEDELEX 2122 TV P1545Y 13 TEDELEX 9227 TV P1690N 14 TEDELEX 9422 TV P1655Y 15 TEDELEX 9427 TV P1655Y 16 TEDELEX 9628 TV P4263 17 TEDELEX EC 2528 TV P4190N 18 TEDELEX EC 2909 TV P4264 19 TEDELEX G 148 TV P4263 20 TEDELEX G 149 TV P4263 21 TEDELEX G 202 TV P4263 22 TEDELEX G 209 TV P4263 23 TEDELEX N 9034 SA VCR P1814 24 TEDELEX RC 94 R/C P1655Y 25 TEDELEX RC 97-PI TV P4263 26 TEDELEX RC 98A R/C P4190N 27 TEDELEX RC 98D TV P4264 28 TEDELEX SOME MODELS VCR 29 TEDELEX SOME MODELS VCR P4205N 30 TEDELEX STUDIO 3000 G TV P1690N
* Note: Supertel, Minitel and PRO-TEL universal remote controls will share the same code.
Feb 26, 2017 | Televison & Video
Im trying to connect my unit to my tv to record shows and i having trouble doing so please help i am hooking it up wrong
For OTA or CATV signals, you need to daisy chain the coax from the source (antenna for OTA) to the coax input on DVD recorder and then the coax out to the coax input of the TV. If you have a set-top cable box with an incoming CATV signal, it should be connected between the DVD recorder and the TV.
The unit can tune in and record 480i (SD) ATSC (OTA digital), NTSC (OTA analog), analog CATV and digital CATV channels.
A satellite receiver or a non-CATV cable box should get the incoming signal first and then have their composite video output (A/V) connected to the DVD recorder composite video input and then their coax (RF) output (if present) gets connected to the TV. For these, you would record from the IN1 or IN2 (press Select Input) instead of selecting a channel. Then connect the composite video out on the recorder to the TV's composite video in.
Digital signals are either enough to tune in or give no signal. So check that your antenna is correctly oriented for OTA.
Separately, you can connect the video signal when playing DVDs via composite (good signal) out and component out (better signal) out to the TV's matching input. For the component video, the sound is carried on a separate cable. Then set the TV to the input source.
In the case of wanting to watch a VHS tape while taping to a DVD, do not use the Component video source, set the TV to Input 1 (composite).
I hope this helps.
(you can get a copy of the manual here: http://tv.manualsonline.com/manuals/mfg/panasonic/dmrez47v_dmrez475v.html )
Nov 25, 2010 | Panasonic DMR-EZ47V DVD Recorder/VCR
How to hook up my Xbox to my TV
It sounds like your TV doesn't have the Component A/V (Red, White, Yellow) ports. Unfortunately your TV only currently supports broadcast tv. These are the options:
  1. Try and keep looking for an adapter
  2. Get a new TV
  3. Plug it in another TV (if you have one)
Good Luck!
Jun 19, 2010 | Microsoft Xbox 360 Console
Trouble with Channel setup
It is important for the TV to know what type of
signal-Cable TV (CATV) or a normal antenna
you are using. Choose your signal (Antenna or
Cable):
Press MENU to see the main menu.
Press CH+ or CH- to highlight Setup.
Press OK
to enter the Setup submenu.
TV/CATV is highlighted. Press VOL+ or
VOL-
to select TV or CATV.
Choose CATV if you have Cable TV
service. (See page 4 for connection
details.) If you do not have Cable TV
service and you connected an antenna
to the TV, choose TV. (See page 5 for
connection details.)
Press MENU repeatedly to exit the
menu or the menu will automatically
disappear within a few seconds if no
buttons are pressed on the remote
control.
And here is the manual if you need .
http://tv.rca.com/RCATV/Assets/pdfs/27F520T_1641312E_IB_e-06.pdf
Good luck and please rate
Sep 24, 2009 | RCA TruFlat 27F520T 27" TV
How do you change the tv from CATV to just TV in the programming?
the tv doesn't need to know that the signal is coming from a dish, so the use of catv while using direct tv should be okay. it seems that the problem may be with where you are making the connection from the direct tv box. plug it in where you would a cable box cable.
Jan 24, 2009 | Emerson EWC1303 13 in. TV/VCR Combo
MAKE TEDELEX 118A REGION FREE
As I was not getting any feedback on my problem I purchased a Region 1 DVD from the U.S.A. to see if it would play the DVD. The Tedelex 118A must be a region free DVD PLAYER as it has PAL/NTSC functions and AUTO to change to what ever region is playing.Where the Tedelex 118 needs a code to change to all regions
Jan 11, 2009 | Televison & Video
Broken CATV connector on the TV
you'll have to take the tv apart un solder he connection go to radio schak and see if they have the part . resolder put tv back togrether done
Jan 04, 2009 | Sylvania 6419TC 19" TV
RCA 32' colortrak plus connectiuns
If you are connecting the cable to the VCR, and using a cable TV type wire (CATV wire) from the VCR to the TV, this is not the same as an A/V connection.
The VCR should have a built in modulator. In some areas the VCR uses channel 3 or 4. In other areas they are using channel 5 or 6. You will have to refer to the user manual for the VCR to know the channel that is being used for the VCR. On some, it is written at the CATV output connector.
Turn on the VCR, and set the TV to the proper channel for the VCR. Select in the VCR's options to put its output to the CATV, or its channel output. Refer to the book on the VCR for details.
Jerry G.
Apr 20, 2008 | Televison & Video
Televison & Video Logo
35 people viewed this question
Top Televison & Video Experts
Electro Med Services...
