Question about Optimus Heating & Cooling
MY OPTIMUS GOES ON AND OFF BY ITSELF AFTER I TURN IT ON, EACH CYCLE LASTS 40 SEC AND I DO NOT GET ENOUGH HEAT. HOW CAN I FIX IT?
I REMOVED THE FUSE OF IT BUT IT STILL DOES NOT WORK
5 Suggested Answers
  • 38 Answers
SOURCE: Proview Pl926wbi
This is an inverter board problem. The inverter supplies the high voltage and frequency to run the CCFL backlights. The board has a sensing circuit to shut down the output if too much current is going to the backlights or it will shut down if the transistors overheat. I have replaced transistors on some boards with higher rated transistors and they have worked great for years. Sometimes it is just a cold solder joint on the inverter board. Replacement boards are expensive but not too difficult to replace. Repair requires some ability with electronic boards and should not be attempted if you do not posess the skill. You could end up damging other parts that cost more.
Posted on Jan 18, 2008
MicrowaveSvc
  • 9098 Answers
SOURCE: My panasonic genius old as
If it stops at 16 seconds and is a sensor model, it probably has a defective humidity sensor.
You can order Panasonic parts here.
After you look into this, if you still need help, please write back with your model number.
Posted on Aug 12, 2008
  • 927 Answers
SOURCE: Turns on and turns off.
Good Day;
This model is equipped with a self-diagnosis feature to help with diagnosis of shutdown problems. To activate this turn the unit on let it shutdown then press the device and menu buttons on the front panel simultaneously and hold them in for 5 seconds after 5 seconds the power LED on the front panel will blink a two digit sequence. This will be one set of blinks a short pause then another set of blinks, this will repeat 5 times. 1 - 2 = no error detected 2 - 1 = X-ray protect (high voltage or beam current) 2 - 2 = Short protect (short protect monitors low voltage supplies) 2 - 3 = Deflection protect (this could be loss of vertical or horizontal deflection) 2 - 4 = Vertical protect (usually loss of vertical from the source) 1. SHUTDOWN AT POWER WITH SELF DIAGNOSIS ERROR 2 2. CHECK FOR LEAKY C9A60 470 PF 1000 V PART # 154P400030, PARALLEL TO D9A57 ON THE POWER PCB. 2. SHUTDOWN AT POWER WITH SELF DIAGNOSIS ERROR 2 2. CHECK FOR OPEN FUSES F9A04 AND F9A05 PART # 283P043090 ON THE +24 AND -24 VOLT LINES. IF THE FUSES ARE OPEN THE CONVERGENCE OUTPUT CIRCUIT WOULD BE SUSPECT. OR your TV has "COOLANT" (ethylene glycol) on the circuit boards. This fluid comes from the CRT's (picture tube) this fluid is used to keep the CRT's cool, such the name. This fluid from the CRT's leak when TV is on for long periods of time, the chamber expands and the seals leak.
One can remove this fluid by using "acetone" & small brush. The fluid is hard to see, use bright light, they spots can be smaller then a DIME. Also, the fluid can corrode the parts and traces on the boards. To protect the TV in future place heavy plastic or thick cardboard over affective area, make sure TV has proper air flow around TV. Good Luck, big IRISH.
Posted on Sep 30, 2008
  • 4090 Answers
SOURCE: No heat and turns itself off after 4 secs
1)Turning itself off can be as a result of the sensor getting feedback of not enough ventilation.Ensure unit is able to breathe by bringing it away from the wall to allow airflow. If that doesn't fix it THEN>>>>>
2) The Magnatron which is the heart of the unit is damaged and so the sensor reads overload and shuts down as a protection against fire.
Repair of the magnatron often exceeds the value of the machine and in your case is not worth repairing. You can buy used ones and refurbished trade ins cheaper than your repair costs will be
Please rate our help to keep the FREE service online++++Thanks for using FIXYA
Posted on Sep 13, 2009
Testimonial: "Thanks for the feedback and your input about the relative costs of repair vs. the value of the machine. Will follow the advice"
When i turn up the volume my amp shuts down i turn it down and it comes back on. I have a crossfire vr1000d what am i doing wrong?
Is the protect light in your amplifier turns on when it shuts down? If yes, then your amplifier lacks voltage. The reason why it goes on protect mode is, the amplifier is needing an amount of voltage from your car, since your car cannot provide that amount of voltage your amplifier is not getting anything, instead of getting voltage to produce watts its getting minimum voltage & producing heat, to save itself it goes on protect mode so the incoming power shuts off & cools the amplifier.
Example:
Your on vol 40, amplifier is working fine, when you turn it up to vol 50 your amplifier shuts of, then you put it back to vol 40 & your amplifier turns back on.
At vol 40 your voltage is 12v or above. but in vol 50 your voltage drops to 11 & below.
Check your battery or alternator if they are giving enough voltage
Hope this helps your inquiry. Have a blessed weekend.
Apr 24, 2011 | Crossfire Car Audio & Video
I turn the compute on and last for 2 minutes and the it turns off itself, I want to know why
Theres not enough information to properly tell you. But I would start with looking to see if your fan turns on when you turn on the computer. If the fan does not turn on then your CPU overheats and the computer will shut itself off. To try and fix this, clean out the fan (hair or anything around the fan motor can prevent it from turning).
Mar 04, 2011 | Toshiba Satellite P35-S611 Notebook
Reset button broken . jumped it out. unite runs for about 3 min.
Sounds like the pump vanes assembly sticking.Use light oil and cleanall, filters[-- screens- plug-vanes- ect...ect!
Dec 17, 2009 | Master Heaters B155DST
HOW TO PROGRAM 2003 TOYOTA CAMRY FACTORY REMOTES
1. Driver door open and unlocked. Key out of the ignition
2. Insert the key and remove 2 times in 5 sec.
3. Close and open driver door 2 times in 40 sec.
4. Insert the key and remove it again from ignition.
5. Close and open driver door 2 times in 40 sec.
6. Insert the key in ignition,
7. Close the door,
8. Turn to on and back to lock in 1 second intervals. 1 time for add, 2 times for rewrite, 3 for confirmation 5 for prohibition. (yes, there is no “4”)
9. Remove the key
10. Power lock will cycle to confirm
11. For add or rewrite mode within 40 sec of the confirmation,
A. press “lock” and “unlock” buttons of the FOB at the same time between 1 and 1.5 seconds.
B. within 3 sec press “Lock” button for more than 1 sec and release.
C. If it’s correct, the power door lock will cycle once. If it’s wrong the door lock will cycle twice.
Sep 17, 2009 | 2003 Toyota Camry
Climate Control Module Reset
the problem is the blend door actuator. Its is located behind hte glove box. (as far up and to the left as you get get with your hand). The gear inside the motor will crack if it is overdriven. As far as the re calibration, pull the rdo fuse(s). wait about 30 sec. replace fuse(s) turn car to run wait for 40 sec or so. you should be able to get a flashlight and watch the motor turn back and forth. turn key off. you should have heat. if not, pull the motor out. very easy just two screws. open the motor can check large gear for cracks
Dec 02, 2008 | 1998 Chevrolet Blazer
PT 40LC12 Panasonic
Problem is the bulb.
I had this exact same problem.  Even though the bulb appears to be good, it is drawing too much current to run properly, and the ballast is shutting it down.
Aug 03, 2008 | Panasonic PT-40LC12 40" Rear Projection...
TV picture goes out
The tv is shutting down because of a power problem. It could be the power transformer or a color gun overheating. Expect at least a couple of hundred dollars to fix it. Some shops will do house calls for around $65 and can diagnose the problem and give you an estimate. Usually they can just remove the board, take it to the shop and repair it, then reinstall it.
Nov 03, 2007 | Televison & Video
Flow of mist intermittent.
here is the manual if you need it http://www.plaston.com/uc/ats/products/ultrasonic/aos7133/index_html/manual on page 6 you can see item k - the water level sensor - i believe it is electronic not a float device (but either way the same is usually true)- usually these can fail when dirty - limescale mostly. a lot of the problems may be the result of not replacing the demineralisation cartridge often enough. descale by leaving overnight with around 40% vinegar solution full to the top, make sure the demineralisation cartridge is removed while u descale - check pages 9& 10. Hope this helps :)
Mar 06, 2007 | Air-O-Swiss 7133 Humidifier
Heating & Cooling Logo
94 people viewed this question
Top Optimus Heating & Cooling Experts
Mack Baxter
Trippy Tripp
Are you an Optimus Heating and Cooling Expert? Answer questions, earn points and help others
