Scanner is not printing on back of check. Where do I get new ink cartridge locally?
    Master:
  • 755 Answers
Look on ebay cheap and free delevery and guranteed
Posted on Dec 15, 2014
I have the Dell AIO 926 and i have an Error Message. Error 1203 Consult User's Guide I cannot print, what do i do?
error 1203's error name is print head short which indicates a short circuit in the print head has occurred. solution to this problem is to disconnect and then reconnect the printer power cable. Reinstall the ink cartridges.For more information, see Replacing Ink Cartridges.
  • Turn on your printer.
  • Lift the printer unit, and then position the scanner support between the tabs to hold it open.
  • The ink cartridge carrier moves and stops at the loading position unless the printer is busy.
  • Press down on the ink cartridge lever to raise each ink cartridge lid.
    Remove the old ink cartridges.
  • Store the cartridges in an air-tight container, such as the storage unit you received with your photo cartridge, or dispose of them properly.
  • If you are installing new ink cartridges, remove the sticker and transparent tape from the back and bottom of each ink cartridge.
    NOTE: The following illustration shows a black cartridge and a color cartridge (used for normal printing). For photo printing, use a photo cartridge and a color cartridge.
    Insert the new ink cartridges. Make sure the black or photo ink cartridge is secure in the left ink cartridge carrier, and the color ink cartridge is secure in the right ink cartridge carrier.
    Snap each lid closed.
    Hold the printer unit up, push the scanner support back to unlock it, and then lower the printer unit until it is completely closed.
  • Jun 05, 2011 | Office Equipment & Supplies
    How do i replace my ink cartages
    Removing a used print cartridge:
    1. Make sure the printer is on.
    2. Lift the scanner unit. The print cartridge carrier moves and stops at the loading position, unless the printer is busy.
    3. Press down on the lever to raise the cartridge lid.
    4. Remove the used print cartridge.
    To install a new cartridge, remove the sticker from the back and bottom of cartridge. Insert the new cartridge in the slot. Close the lid. Lift the scanner unit, press the scanner support back until it slides into the slot, and close the scanner unit.
    Source: Lexmark X2400 Series User's Guide
    May 18, 2011 | Lexmark X2470 All-In-One InkJet Printer
    How to change ink cartridges on an Epson CX 3800
    Be sure you have a new ink cartridge before you begin. Once you start replacing a cartridge you must complete all steps in one session.
    1. Make sure the Epson CX printer is on.
    2 Make sure the document cover is closed, then open the scanner
    Caution: Do Not open the scanner when the document cover cover is open.
    3. Press and release the " ink " button. The ink cartridge moves to the check position and the
    " On " and " ink " lights flash. If one of the cartridges is low or empty, the printer moves the
    cartridge to the _ink out mark.
    Note: Don't hold down the " ink " button for 3 or more seconds or the printer starts cleaning the print head.
    Caution: Do Not move the print head by hand; this may damage the printer, always press the ink
    button to move it.
    4. Press the " ink " button again
    a. If more than one cartridge is low or empty, the next cartridge moves to the_ink out position.
    b. If all of the empty or low cartridges have been identified, the print head moves to the ink
    cartridge replacement position.
    5. Open the cartridge cover.
    6. Squeeze the tab at the back of the empty/low cartridge and lift it straight out.
    7. Before you open the new ink cartridge package shake it four or five times, then remove it
    from the package.
    Caution: Do Not remove or tear the label on the cartridge; otherwise ink will leak.
    Do Not touch the green chip on the front of the cartridge, this can damage the
    ink cartridge.
    8. Place the new ink cartridge into the cartridge holder and push it down until it snaps into
    place.
    a. Replace any other cartridges that need to be replaced.
    9. Close the ink cartridge cover and press it until it clicks into place.
    10.Close the scanner.
    11. Press the " ink " button The print starts charging ink and the " On " light starts flashing. This
    takes about one minute. When it's finished the " On " light stops flashing and remains on.
    and the " ink " light goes out.
    Caution: Never turn off the printer while the " On " light is flashing or you'll waste ink.
    Note: If the " ink " light stays on ( not flashing ), the ink cartridge may not be installed correctly.
    Press the " ink " button again and reinstall the ink cartridge until it clicks into place.
    Feb 09, 2011 | Epson Office Equipment & Supplies
    How do I change the ink cartriges in my printer
    1.Turn on your printer.
    2.Lift the scanner base unit.(The ink cartridge carrier moves and stops at the loading position unless the printer is busy.)
    3.Press down on the ink cartridge lever to raise each ink cartridge lid.
    4.Remove the old ink cartridges.
    5.Insert the new ink cartridges. Make sure the black or photo ink cartridge is secure in the left ink cartridge carrier, and the color ink cartridge is secure in the right ink cartridge carrier.(Make sure to take off the sticker and the transparent tape from the back and bottom of the new cartridge.)
    6.Snap each lid closed.
    7.Lower the scanner base unit until it is completely closed.
    Enjoy printing...
    Sep 14, 2010 | Dell V305w All-In-One R840635AU InkJet...
    Don't have a manual, just need to know how to change ink and toner cartridges:)
    Step 1
    housing beneath. If done correctly, the print cartridge carrier should move into the loading position near the center of the unit.
    Step 2
    Push down on the colored cartridge lever at the front of the carrier to unlock and pop up the cartridge lid.
    Step 3
    Pull the spent cartridge from the printer.
    Step 4
    Pick up your new cartridge. Pull the sticker and tape gently from the back and bottom to reveal the gold metal electrical contacts.
    Step 5
    Insert the new cartridge into the print cartridge carrier with the electrical contacts facing down. Press the cartridge gently but firmly into the carrier so that the contacts on the cartridge touch the contacts in the carrier.
    Step 6
    Close the cartridge lid over the new cartridge until it clicks into place.
    Step 7
    Lift the scanner unit up slightly so that the scanner support arm unlocks. While holding the unit up with one hand, push the support back into its storage slot with your other hand and carefully lower the unit back into its original position on your printer.
    Step 8
    Press the third button down from the top on your control panel---marked by an arrow pointing from a scanner icon to a computer icon---for three seconds to print out a print alignment page. When finished, follow the on-screen instructions.
  • Step 2 Push down on the colored cartridge lever at the front of the carrier to unlock and pop up the cartridge lid.
  • Step 3 Pull the spent cartridge from the printer.
  • Step 4 Pick up your new cartridge. Pull the sticker and tape gently from the back and bottom to reveal the gold metal electrical contacts.
  • Step 5 Insert the new cartridge into the print cartridge carrier with the electrical contacts facing down. Press the cartridge gently but firmly into the carrier so that the contacts on the cartridge touch the contacts in the carrier.
  • Step 6 Close the cartridge lid over the new cartridge until it clicks into place.
  • Step 7 Lift the scanner unit up slightly so that the scanner support arm unlocks. While holding the unit up with one hand, push the support back into its storage slot with your other hand and carefully lower the unit back into its original position on your printer.
  • Step 8 Press the third button down from the top on your control panel---marked by an arrow pointing from a scanner icon to a computer icon---for three seconds to print out a print alignment page. When finished, follow the on-screen instructions.
  • Read more: How To Change the Ink Cartridge in a Lexmark X2470 | eHow.com http://www.ehow.com/how_6646584_change-ink-cartridge-lexmark-x2470.html#ixzz0wg8UCkTs
    Aug 15, 2010 | Lexmark X2470 All-In-One InkJet Printer
    I have all full cartridges, I have tried cleaning the heads multiple times, still i can not get any printing..not even the head alignment will print
    try to reseat the ink cartridge, that means take it out, re insert the same cartridge if it is with ion 6 months, if more than 6 months, replace it w/ brand new, the ink might dried up already.
    follow this:
    Press the Setup button and select Ink Cartridge by pressing the fontu1.gif/fontd1.gif button, then press the OK button. Confirm the messages on the LCD panel and press the OK button to start the ink cartridge replacement.The ink cartridges move to the replacement position.
    Make sure that the document cover is closed, and then open the scanner unit.
    Open the cartridge cover. Pinch the sides of the ink cartridge . Lift the cartridge out
    put it back in the printer.
    Close the scanner unit, then press the OK button.
    then print a nozzle check
    Feb 10, 2010 | Epson RX620 All-In-One InkJet Photo...
    My printer is running through ink really fast with not a lot of use 3 cartridges in one month. Each time I replace it with a new one it still reads low on ink. Any ideas what might be wrong?
    This printer does not actually read the ink levels. It reads the documents getting sent to the printer and estimates the amount of ink used. You can buy a little scanner that resets the code on your cartridge to read as if it is brand new. This will allow you to use ALL of the ink in the cartridge before having to go buy more. This is a ploy to buy more ridiculously expensive ink than you actually need. Keep resetting it until your prints come out missing ink. Then you know you actually need a new ink cartridge. You can get this scanner on eBay or at your local electronics store.
    Nov 23, 2009 | Canon PIXMA MX310 All-In-One Printer
    How do I change the ink cartridge on my Dell 810 printer
    Ink Cartridge Maintenance Replacing an Ink Cartridge
    1. Turn on your printer.
    2. Lift the printer unit, and position the scanner support between the tabs to hold it open.
    1. Press down on the ink cartridge lever to raise the ink cartridge lid.
    1. Remove the old ink cartridge.
    1. Dispose of the old cartridge properly.
    2. If you are installing a new ink cartridge, remove the sticker and transparent tape from the back and bottom of the ink cartridge.
    1. Insert the new ink cartridge.
    1. Snap the lid closed.
    1. Lift the printer unit, and hold the scanner support up while lowering the printer unit until it is completely closed.
    rcrtdrc1.jpg Aligning an Ink Cartridge You may need to align the ink cartridge when characters are not properly formed or are not aligned at the left margin, or when vertical or straight lines appear wavy.
    To align the ink cartridge:
    1. Load plain paper. For more information, see Loading Paper.
    2. In Windows XP, click Start® Control Panel® Printers and Other Hardware® Printers and Faxes.
    In Windows 2000, click Start® Settings® Printers.
    1. Right-click the Dell AIO 810 icon.
    2. Click Printing Preferences.
    The Printing Preferences dialog box opens.
    1. Click the Maintenance tab.
    2. Click Align Print Cartridge.
    3. Click Print.
    A blue and black alignment page prints.
    1. After the alignment page has finished printing, place the page face-down on the scanner glass. Make sure the upper left corner of the front of the page aligns with the arrow on the printer.
    1. Press the Scan button scanicoa.jpg .
    The page is scanned. When the scan is complete, the cartridge is aligned. You may discard the alignment page when the alignment is complete.
    Please download the manual from the link below and go to chapter Ink Cartridge Maintenance:
    http://support.dell.com/support/edocs/systems/PRN810/en/ug/ug_en.zip
    Hope it helped.
    Nov 22, 2009 | Office Equipment & Supplies
    Printer only prints with red & black inks
    You definitely need a new printhead. You can order it from kodak directly.
    Sep 11, 2009 | Kodak ESP 3 Multifunction Printer/ Copier/...
    http://www.lexmark.com/publications/pdfs/2007/6200/winug/en/frameset.html
    Note: Make sure the All-In-One is on.
    1. Lift the scanner unit. The print cartridge carrier moves and stops at the loading position. sscano.jpg
    2. Press down on the cartridge lever to raise the cartridge lid. scrtrpc1.jpg
    3. Remove the old cartridge. Dispose of empty ink cartridges (see Recycling Lexmark products). Use the cartridge storage unit that came with your photo cartridge to store partially used cartridges for future use. See Using the cartridge storage area. scrtrpc2.jpg
    Note: If you are removing both cartridges, repeat steps 2 and 3 for the second cartridge.
    Installing the print cartridges Note: If you are installing a photo print cartridge, remove it from the print cartridge storage unit. Place the empty print cartridge storage unit in the cartridge storage area. For help, see Using the cartridge storage area.
    1. If you are installing new cartridges, remove the sticker and transparent tape from the back and bottom of the cartridges. staperem.jpg
    Warning: Do not touch the copper contact area on the back or the metal nozzles on the bottom of the cartridges.
    1. Unless they are already open, press down on the cartridge levers to raise the cartridge lids. sctnin2.jpg
    2. Insert the black cartridge or the photo cartridge in the left carrier. Insert the color cartridge in the right carrier. sctnin3.jpg
    Note: The control panel display will prompt you to print an alignment page.
    Note: The scanner unit must be closed to start a new scan, print, copy, or fax job
    Feb 03, 2009 | Lexmark X1150 All-In-One InkJet Printer
    jasbo
    jasbo
