Question about Jacuzzi Home
Where do I get replacement part to Grohe jacuzzi bath plug. Current plug leaks water when closed
    Top Expert:
  • Jacuzzi Master
  • 43,059 Answers
Contact the MFG's website
Posted on Apr 02, 2015
  • 68 Answers
SOURCE: jacuzzi bath
Many time leaks around pumps are a simple o-ring that needs to be cleaned and/or tightened. If the jets are leaking from the back side then the jet will have to be removed and resealed.
Good Luck, Phil
Posted on Dec 11, 2008
  • 152 Answers
SOURCE: Bath tub spa will not shut off
If you haven't done this already. I would search your breaker panel for a circut breaker titled jacuzzi tub (or something to that effect), and if it is not listed I would get someone to monitor when the tub shuts off, while you flip each breaker off, one at a time so as to determine which breaker it is and then immediately title it.
Next, an access panel to the tubs motor should be installed. After access is gained, inspect the pumps receptacle and if it is not GFIC protected I would return to the breaker panel, it may have a GFIC breaker. If neither are the case, then have this issue repaired
The button on your jacuzzi is air actuated with a flexible air line that connects to the actual switch, it may have broken or however became disconnected.
Any questions, feel free... Good luck...
Posted on Feb 22, 2009
  • 63 Answers
SOURCE: Do I have to clean my jacuzzi every day?
Just clean it once a week is fine.
Please rate!
Posted on Mar 17, 2009
  • 120 Answers
SOURCE: whirlpool bath won't turn on.
Most of the control buttons on a tub are not electrical. These buttons are connected to an air line that runs to the motor. Sometimes an aggressive button push can literally blow the air line right off of the bottom of the button.
This problem is as easy to fix as it sounds. Find the loose air line and push it back onto the button. You will need to open up your access panel. Bring a flashlight.
Be sure to check the connection at the motor too. Good luck
Posted on Jan 20, 2010
  • 497 Answers
SOURCE: The stopper of my Jacuzzi
Try this link. I hope it can give you the info that you need:
http://www.ccowhirlpool.com/web-pdfs/Jacuzzi_Whirlpool_Bath/TroubleShootingGuide.pdf
Posted on Oct 18, 2010
Hair in a Jacuzzi Drain
take the drain plug out and remove the hair. Once you remove the hair from the drain your water will drain from the shower.
US Parts Center
Mar 09, 2014 | Jacuzzi - Bathtub - Alcove - Navona -...
Our jacuzzi tub is 20 hrs old and possibly is leaking. About 6 mths ago we remodeled bathroom &replaced all tile around tub & shower. We do not want to tear out tile. What would be best way to pin...
if you have a water stain on the ceiling below your tub then you have a water leak. There is no easy solution for this. You must get to the underside of the tub in order to watch the jets when the tub is full of water to isolate the leak and then have it repaired by a plumber.
Aug 15, 2011 | Jacuzzi Home
My tub does not want to stay running when i press the button, you have to hold the button down for it to work
the buttons on most of the tubes are pressurized air when u push it sounds like a bad button or hose it could even be the little air sylenoid that clicks on and of when the air is forced against it when u press the button 1st check the hoses for leaks 2nd remove hose and verify the button works
Jan 14, 2011 | Whirlpool Jacuzzi Jacuzzi Bath Fuzion EF50...
"Jacuzzi j-400 series" hot tub- F1 code flashes on control panel
Your circulation pump isn't working you should see the flow awitch closing if you have the visible model and hear the pump running.. If its the smaller circulation pump model it needs replacing
May 18, 2009 | Jacuzzi Bath Nova H530 917 Black Soaking...
Whirlpool jacuzzi jets not working properly
im not a great expert in this field but try putting some dish washer tablets in water when running to see if they can clean out anything,about 3/4 tabs
Mar 03, 2009 | Whirlpool Jacuzzi Jacuzzi Bath Fuzion EF50...
No water hot
does it have a heater in the circulation line, it should be under the cover and would be in line on the 2 inch pipe that feeds the jets, it should also be on a gfci, check to make sure it is plugged in if this is plugged in and not tripped you need to install a new heater
Dec 06, 2008 | Whirlpool Jacuzzi Jacuzzi Bath Fuzion EF50...
Home Logo
172 people viewed this question
Top Jacuzzi Home Experts
Mike
john h
Donni Steen
Are you a Jacuzzi Home Expert? Answer questions, earn points and help others
