Question about Kenmore Kitchen Ranges
My Kenmore 318086600 rev f stove is an old stove with 8 years. Now it has problem on the left hand burners. When I turn on left upper burner, the upper burner and lower inside burner both heat on, and
I switched upper burner switch from right side to left. They both working well for 1 week, then broken again with same problem. I know maybe I switch lower burner switch from right to left it may find out problem. However I want to ask first instead spend time.
  • John
    John Dec 15, 2014
    Sorry I forgot to write down, it's a electronic range.
  • 1,511 Answers
Very costly: Get a new range and forget repairs.
Posted on Jan 03, 2015
  • 3 Answers
SOURCE: hotpoint 30" self cleaning gas range with sealed burners - no bake
It may be the ignitor, they can crack and you wouldn't even see. Good news is they are cheap ($5-20) and they are usually easy to replace. But before you replace it...
When set to bake, does the "oven cycle" light come on? If not, that means no power is being sent to the ignitor. Reason? There is a switch in the oven latch, to make sure a) latch must be closed for cleaning cycle and b) latch must be unlocked for baking. On mine, the switch button gets stuck, so even when the latch is unlocked, it thinks it is locked and will not allow the bake cycle to proceed. Cycling the latch a few times may free it, otherwise you'll need to replace the switch (not that hard but a bit of a pain to get to).
Posted on Nov 22, 2007
rickzilla
  • 706 Answers
SOURCE: ge spectra gas stove top not lighting
If your top burners are not lighting or will not work, it is possible that the burners have become dirty or wet. Please follow the troubleshooting directions below before calling service:
  1. Turn you burner to the Lite position:
    If you hear clicking or sparking, go to Step 2.
    If you do not, check your circuit breakers. If the circuit breaker is ok, we recommend that you schedule service by calling 1-800-432-2737 or schedule service online.
  2. Clean the burner and electrode:
    First remove the burner grate, cap, and head. Use a needle or paper clip to poke through the holes on the burner head. Re-assemble and try the burner.
    Remove the burner grate, cap, and head. Even if it looks clean, wipe the tip of the electrode with a clean, dry paper towel and PRESS IT DOWN. Re-assemble and try the burner, again.
    Check to see if the burner works, If not, then go to Step 3.
  3. Re-assemble - Make sure that each burner top matches its burner bottom. The burner top will lay flat if put on correctly.
    Check to see if the burner works, If not, then go to Step 4.
  4. The spark igniter is operating properly, but the burner is still not lighting. At this point, we would recommend that you schedule service by calling 1-800-432-2737 or schedule service online.
Posted on Sep 01, 2008
  • 126 Answers
SOURCE: Burner will not turn off
I would first check the infinite control switch (#WB24T10029) the part the knob slips onto. The next thing I'd check is the erc (#WB27T10231) control board. Hope that is helpful!
Posted on Jan 15, 2009
  • 360 Answers
SOURCE: kenmore glass top range left front large burner out
check the burner socket, it is likely that contact is being lost where the burner connects to the hardwired portion of the system (the socket). It is not unusual for the socket to "burn up" when there is a poor connection to the burner resulting in the burner being replaced and the new burner not working or working intermittently.
Please take the time to rate this solution
Posted on Jan 29, 2009
localwonder
  • 6784 Answers
SOURCE: oven quit working
Hi. this is common in many old gas range ovens. There is a set of coils that are attached to the gas valve assembly. These coils , when activated and operational, open and close the main and secondary valves in this unit. They are controlled by the main ERC(clock/oven control board). I recommend checking these coils and there respective wiring harnesses. if the clips and wires are worn and corroded, simply replace the entire wire harness.
Now, if the wiring harness and wires that are connected to the coils look good and there are no signs of corrosion on the wires and connector clips, this will confirm that the coils have failed and you will need to replace them.
You can also preform an additional test with a multimeter. simply connect your multimeter or voltage meter to both terminal posts located on the coils. once your meter is connected, start the oven cycle. you should register some sort of current during this test at this time. if the current is sufficient and the coils do not initiated the valve action, this will confirm coil failure. if the meter dosen't register a current during oven operation, this will confirm ERC(control) failure. you will have to replace the Oven control board in this case.
The Most common issue in this situation will most defiantly be the coil assembly and not the control.
Please rate and god bless:)
Posted on Apr 21, 2009
Burner says hot.. wont go off, moffat stove
Hello;
My name is Peter. I am a retired field service appliance technician.
I assume you have an electric oven.
You have a defective individual burner control.
1.) Pull your oven out so you can get behind it.
2.) Unplug your oven.
3.) Remove the upper back metal cover.
4.) At the top in the center is your main oven control board. On the left are two burner controls and on the right are two burner controls.
5.) Inspect the burner controls for burn marks or melted wires.
6.) Finding the bad control unit, pull the control nob off the front.
7.) Unscrew the burner control in the front.
8.) Remove the connectors on the burner control.
9.) With the burner control in hand. re-attach the upper metal back panel on your stove.
10.) Pug in the stove and push back in place.
11.) On the burner control that you just removed note the part number. Search on the internet for best price.
12.) Continue to use your oven without the burner control.
13.) Install the new burner control when received. Remember to un-plug.
May 15, 2015 | Kitchen Ranges
There is gas to the burners on my old Hardwick range, but not to the oven.
perhaps you need to call someone to have the gas line cleaned going to the oven .have heard that spider webs can stop gas flow .it doesn't take much
Jul 22, 2014 | Maytag Crosley Hardwick Caloric Kenmore 8"...
Sears Kenmore gas stove, the front left and the left and right rear burners turn on when the knob is turned to the lite position. The right front burner doesn't turn on when put lite position. N
If there is no clicking sound like you hear when you turn on the other burners than I'm going to say that either the electrode is bad or the spark switch, which is what you turn to turn on the burner to begin with. Both parts are cheap so it may be a good maintenance thing to change all of the burners. Make sure you have your model and go to www.repairclinic.com and order both parts, and if you don't need one send it back for a full refund even if you installed it. good luck
Apr 29, 2012 | Kitchen Ranges
I have a kenmore ceramic top electric stove and one of the burners quit getting hot. what could be the problem
It is a kenmore glass top stove about18 years old. One of the burners stop working just wondering if I can fix it myself?
Aug 06, 2010 | Kenmore 95002 / 95004 Electric Kitchen...
I turn my burner on at medium -no problem. When I
If you cannot regulate the temp on any surface element the problem is not in the element but rather the "infinite" switch. You need to replace the switch's if you can't control the hi and low on the burners. The switches will be different for the small burner and the large burner because of the different wattage on the burners.
Nov 11, 2009 | Kenmore Kitchen Ranges
Poorly functioning Shipmate stove
Hi
Normally pressing red buttons on stoves is for lighting the oven. You press the button, light the pilot light, leave it depressed for a minute and then that heats up the thermocouple, which opens a valve and allows gas to the main burner.
Shipmate Stoves are still in business, so you could contact them. The link also suggests places for Shipmate propane gas stove spares.
Shipmate stoves Google Search
Mar 27, 2017 | Brown Stove Works 23 in. TL03-3 Gas...
Replacement Parts For Vintage Magic Chef stove
You probably have a 1940's model of Magic Chef. Check for the model number under the lid of the cook top on the upper right hand side of the stove. It should have the model number and the serial number, too. You will need both. The Old Applicance Club run by Jack Santoro is the place to go along with a site called "Antique gas stoves"in Georgia. Good luck with the world of vintage stoves.
Sep 23, 2008 | Kitchen Ranges
Mar 05, 2008 | GE JBP64 CleanDesign Electric Kitchen...
Kitchen Ranges Logo
160 people viewed this question
Top Kenmore Kitchen Ranges Experts
Dan Webster
Dan Webster
Mike Carew
Are you a Kenmore Kitchen Range Expert? Answer questions, earn points and help others
