Question about Konica Minolta Minolta Di450 Di470 Di550 Copier Mt Toner 502a 8936-902
Reset the malfunction code if the necessary perform F5 AIDC auto adjustment.
    Sergeant:
  • 222 Answers
Its F8
Posted on Dec 16, 2014
Change drum kit
Remove the old drum unit,remove the drum and the drum cleaning blade,clean the charge corona wire and grid,install the new drum and drum cleaning blade,clean the image transfer /separator corona wire,clean the optical parts(mirrors ,lens,glass)clean the AIDC sensoe located under OPC drum,reinstall the drum unit in the copier,enter in the technical Rep mode,place 5 sheets A3 paper on the original glass and perform F5 AIDC sensor(Auto image density control).
Mar 19, 2013 | Minolta EP4000/5000 CS/PRO Copier
Of 24 error
Cof 024 - AIDC sensor contamination correction failure.The photosensore LED located under OPC drum of the AIDC sensor dirty.Clean the sensor,reset the malfunction code if the necessary perform F5 AIDC auto adjustment.
Mar 06, 2013 | Minolta Di550 B&W Laser Printer
Machine is flashing service call after power outage
Remove the imaage unit aand change the IU fuser(0,63mA),and perform the ATDC and AIDC control program(F8,F5).
Jun 24, 2010 | Minolta EP1031/1031F CS/PRO Copier
Sc990
sc 990 relates to the nv ram chip on the main board also check the values of the lazer unit are correct and not changed
Jun 16, 2010 | Ricoh Aficio 450 Copier
Minolta cs Pro- Works but print black copy?
Please clean the mirror unit,the trasfer and separator coronas,and perform F5 AIDC control.
May 19, 2010 | Minolta EP4000/5000 CS/PRO Copier
Minolta Di470 Error code C-0F24
COF24 is an AIDC or Automatic Image Density Control failure code. It means that the machine can not properly detect the developer to toner mixture or ratio in the process/developer unit. This can be caused by an AIDC sensor failure, Developer Drive problem or for some reason the machine is not getting toner as it should. Has the machine been running low on toner?
Before calling for service I would try resetting the code by opening then closing the front door(s). Do this a few times and see if the code will go away. If not then you will need a service person to diagnose and repair which part is defective.
Good Luck and Thank You for using Fixya.
Apr 22, 2010 | Office Equipment & Supplies
After changing developer on konica 7065 what is the st up procudre ?
You must perform ATDC sensor gain procedureF8 and AIDC sensor F5 perform.
Dec 28, 2009 | Konica Minolta Office Equipment & Supplies
Minolta EP1085 copier - replaced drum but need to make adjustments for auto darkness, etc please help
After replace the photocopier drum you need perform the F5 Auto Image Density Control.Enter in the service mode:press Stop key - 0 - 0 -Stop key - 0 - 1 and press 1.In the LCD appear E and press 5 and the copy(start) button for perform the F5.Begining place A3 sheet paper in the original glass.To replace the OPC drum clean the optical section(glass,mirrors,lens,sensors) and change the OPC drum cleaning blade.Clean the quenqing lamp and erasure lamp amd the transfer/separator corona unit(holders,wires) and the charge corona unit.
Oct 03, 2009 | Minolta EP1083 CS/PRO Copier
C0f22 error code
Atomatic Intensity Density Cotrol sensor malfunction.
Clean the optical parts:lens,mirrors and original glass.Remove the OPC unit clean the AIDC sensor under drum in the rear side,use the vacuun cleaner for remove the used toner under cleaning blade,reasamly the unit.Clean the transfer and separator corona holders and wires and perform the F5.Enter in the service mode Stop key-0-Stop-1 Function menu ,place A3 sheets in the original glass place and perform F5.See the F code history and reset it.This code reset if you open and close the front door.
Sep 09, 2009 | Minolta EP4000/5000 CS/PRO Copier
I HAVE A PROBLEM I CHANGE A NEW DEVELOPER BUT THE RESULT NO TONER
Please specify a copier model:Minolta,Ricoh,etc?
After change the developer you must performed F8 (ATDC automatic toner density control to fixed T/C ratio and initialize the new developer.After this operation perform F5 (AIDC sensor test automatic image density control).Never make a copy before F8.
Aug 01, 2009 | Minolta Office Equipment & Supplies
Konica Minolta Minolta Di450 Di470 Di550 Copier Mt Toner 502a 8936-902 Logo
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
