Question about GE Refrigerators
HAVE A GE REFRIGERATOR TYPE TFX25CR THAT LEAKES WATER FROM TIME TO TIME, ABOUT 5 OZ
LEAKS WATER FROM TIME TO TIME ON TO THE FLOOR
    Problem Solver:
  • 16 Answers
The evaperator for the drip under the bottom of the unit is probably dirty or has gone bad. Pull the fridge out and look under the bottom and you should see a pan with a coil above it. Clean the coil and the pan. If this does not correct the problem, then a new coil is in order. Also vacuum the back of the fridg if it has exposed coils to increase efficiency.
Posted on Dec 15, 2014
Is there a water filter for the TFX25cr? If so, where? And which kind/type?
Hi and welcome to FixYa, I am Kelly
It took a while to find the answer to your question... A lot of manual and site searches were required.
There are 24 models ot the TFX25CR (last digits missing) I will use this model number: TFX25ZRBWW
You can download and owners manual here by entering your model number: http://www.geappliances.com/service_and_support/literature/
If you just enter TFX25CR you will see several manuals
I checked several parts sites and GE. This unit from what I can tell does NOT have a water filter. You can however install an external in line filter such as this one:
http://www.amazon.com/Refrigerator-Maker-Filter-Activated-Carbon/dp/B000AM54MW
These filters often do not come with connecting hardware that has to be purchased separately.
Thanks for choosing FixYa,
Kelly
May 26, 2011 | GE Refrigerators
Water leaking in refrigerator and floor of a 1997 GE top freezer type,model numberTBX22P1
As the only source of water is condensation or melting food, I would check to see if there is a drain hole at the bottom back of the fridge. This hole is to drain any water into the back of the machine where it evaporates. Use a pipe cleaner or similar to poke the muck through the hole and the water will drain away. Keep this hole clean every time you clean your fridge.
Mar 27, 2011 | GE Refrigerators
Water leaks on the floor occassionly may happen during defrost GE Model TDC18PAAWW
Hi,Before jumping to conclusions about why your refrigerator is leaking, do a thorough inspection. Many times, it will be easy to see where the water is coming from and from that point deduce the problem. For instance, water leaking from the back is usually due to an ice maker issue, water from the side of the refrigerator is usually due to a faulty door or gasket, a leaking drain pan,a clogged defrost drain pan.
Thanks and good luck
Jun 03, 2010 | GE Profile Stainless Bottom-Freezer...
Water leak under GE Profile refridgerator when using door water
The water dispenser problem may be due to a defective water control valve. But when the refrigerator leaks this needs to be solved. I have a lot of different ways and reasons listed so click on the below link and read over this and use the part that applies to your refrigerators leaking problem. You also can contact me here or by email should I not get any messages here from you. Hope this helps and we will work on the dispenser problem next, Thanks, Sea Breeze
appliancepartsse@yahoo.com
HOW TO FIX A LEAKING REFRIGERATOR OR FREEZER
Aug 17, 2009 | GE Profile PCF25PGW Side by Side...
My GE Profile fridge periodically (eve other n) leaks water
Thaw out the defrost drain in the freezer. It has frozen over and the defrost water has nowhere else to go except on your floor.
Apr 08, 2009 | GE Refrigerators
12 yr old ge refrigerator leaks water on kitchen floor occassiona
common issue.....sounds like a drain clog in the freezer compartment above. remove the freezer rear panel and totally defrost the evaporator area, directly under the evap you see( under all taht ice) a small drain hole that has become frozen over, try defrosting with either a hair dryer( not a heat gun too much heat youl melt everything) or by pouring hot water donw the drain until you get a free flow of water down the tube. after its clear reassemble and you should be fine
Mar 01, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
GE Monogram leaking water on right side bottom door
If this refrigerator has a Energy Saver mode, turn it on.
Then, check the door gasket for the refrigerator to make sure it's not leaking. Test by placing a crisp dollar bill on the door jamb with the door open, close the door, and you should feel resistance to pulling the dollar out. Check with particular emphasis on the place where you see water leaking or accumulating
Jan 24, 2009 | GE Monogram ZDI15C Automatic Icemaker
TFX28PPCBWW leaking
the i/m holds between 3-5 ozs and will try to fill approx. every 10-15 mins with no water in it..
Jan 21, 2009 | GE GSS25JF Side by Side Refrigerator
GE tFX26KR side by side leaks water onto floor
remove the back of the unit at the bottom where the compressor is, it is held in place with 5/16ths screws. locaate the drain tube going to the drain pan, it is held in place with a spring type clamp, remove the drain tube and run water through it till it is clean and not obstructed, reinstall all parts
Apr 11, 2008 | GE GSL25JFPBS Side by Side Refrigerator
Question about water leaking on the floor under fridge
remove and reinstall water filter, possibly o-ring got sideways during installation.
Mar 21, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Refrigerators Logo
110 people viewed this question
Top Refrigerators Experts
KJ4QOB
Jim Akins
rodney bartholomew
Level 1 Expert
