Question about Waring WCT708 4-Slice Toaster
Get the darkness knobs off a waring wct708 - Waring WCT708 4-Slice Toaster
Looking for a knob for a 6 quart oval slow cooker model no sco-150. its corning ware cooking pot and pyrex lid
If the knob is for the lid, you can use any cabinet door pull as long as it's made of metal.
Aug 08, 2017 | Crock Pots & Slow Cookers
Washer tub is discolering and it has discolered the flat ware, left a film on the glass ware.
There could be several reasons for the film deposit inside dishwasher and on glassware.
What colour is the film - dark or white?
Are you using rinse aid? If you are in hardwater area then check the salt is adequate in the water softener chamber.
Dec 06, 2010 | Bosch 24 in. SHE43C05UC Stainless Steel...
Faint lines show up when i get dark screens in movies
First check what color of faint lines comes then reduce Screen Volts in TV of that CRT (tube)
Take off lower front cover, speaker grille of TV, there you will see focus control block that has 6 control knobs, upper 3 knobs are focus adjustment of red-green-blue CRTs and lower 3 knobs are screen volt controls for red-green-blue CRTs. Turn screen volt control knob CCW to reduce screen volts of desired CRT.
Put TV on any free AV input so screen will be dark enough to adjust screen volts.
Thanks.
Aug 28, 2009 | Sony KP-57WS500 57" Rear Projection...
The main knob that you push in to stop and pull out to start works but won't turn the second part to choose cycle
Hi, Behind the knob there is a U shaped keeper. Pull that out and remove the knob. There should be teeth on both the knob and the inner dial. I have seen one or the other or both have the teeth ware away. See if this is the case. Part # WH01X10061 for the knob &Part # WH11X10033 for the dial. i hope this helps you. Please let me know if I can assist you further.
Vic
Jul 11, 2009 | GE WBSR3140DW Top Load Washer
Toaster does not stay held down to toast wct 708
there is a "contact switch" that when there is power in the system, it stays down. If hte contact switch is bad, it releases and will not stay down. COntact switch needs to be replaced, unfortuantely I have the same problem and can't seem to get the part.
Jun 12, 2009 | Waring WCT708 4-Slice Toaster
Flashes but image is dark
Turn the front black knob and check to see if the front window is not dirty.
atdlee@netzero.com
Mar 18, 2008 | Vivitar 283 Flash
Corningware crock pot
for replacement parts information on Corningware products, you may call toll free (in North America) 1 800 999 3436.
Jan 05, 2008 | Rival 38651-C 6-Quart
Left side dont work
The holder is a bimetallic strip that heats up and opens when it reaches a preset temperature based on the darkness setting. It should latch onto the toast loading mechanism when cold and then snap open when it reaches a certain temperature. The darkness setting knob adjusts the point at which it opens. Probably either the release mechanism is broken or bent or the setting knob is broken. You can disassemble it when unplugged by removing the screws on the bottom and prying off the toast loading knobs by placing a ruler wrapped in cloth against the housing and prying the knobs off with a large screwdriver carefully going back and forth from side to side. If the knobs break or won't go back on use a high temperature epoxy to reassemble. You have a good side to compare the bad side to. Look for differences from one side to the other as the toast loader lever goes down and as the darkness knob is rotated. You may just have something blocking the mechanism. After working on it, plug it in outside to a ground-fault protected outlet on a fireproof surface before attempting to use it.
Oct 25, 2007 | Waring WCT708 4-Slice Toaster
Toaster lever wont stay down
Open the toaster up and look inside by the levers, there should be a little piece that will keep the lever down, if this is missing, then you may need to replace the toaster, if not, then the little piece may be stuck, you can use the following to try and loosen it up,
1. WD-40
Oct 11, 2007 | Waring WCT708 4-Slice Toaster
Dark Picture
Hi there!
The knobs you refer to, are those perhaps the knobs on the board or knobs on the flyback transformer? None of these knobs should be turned. They are preset to the factory standard and if a fault occurs the fault should be addressed, not adjustments to pots. I would suggest checking all the caps in the power supply, Line stage and video section. It may also be the video processor(in the area of the tuner section). Check for caps which are rounded at the top. This is common for dark picture. Please note: There is on average about 15000V running through a TV when switched on, please be careful and unplug when changing components or refer to a repair technician. Good Luck, Jus004
Jun 06, 2007 | JVC AV-32FA44 32" TV
Waring WCT708 4-Slice Toaster Logo
65 people viewed this question
Top Waring Kitchen Appliances - Others Experts
jdtech
Robert Weir
Robert Weir
Level 1 Expert
Are you a Waring Kitchen Appliances - Other Expert? Answer questions, earn points and help others
