Question about Rangemaster Professional Ceramic Hob Electric Cooktop
How do I fix my one plate that is not working? It doesn't get hot.
Replaced the hot plate
Whirlpool schott ceran induction plate doesn't get hot
magnetic gradeI have a SCHOTT Ceran glass ceramic cooktop as well, and soon realized that induction cooktops like this require that your metal cookware be in contact with the surface for them to heat up. Best cookware:
  • Cast iron pans
  • Any black metal pans
  • Stainless steel pans, if base is magnetic grade (magnet sticks to bottom)
Read more: http://www.us.schott.com/hometech/english/products/ceran/dailyuse/index.html
Jul 15, 2012 | Whirlpool 30-inch Electric Ceramic Glass...
My neff helectric hob two of the plates are not working
Sounds like the heating elements burnt out.
Dec 12, 2011 | Cooktops
Chef Supreme Co-ordinate Series Ser. No.: 2004434294 Manuf. No.: 091E11SE1 Sales No.: RETSZW Hot plate not working & suspect bad element or thermostat? 1. The element is not an exposed coil, but rather...
this could be a 220 v unit and one side of the lines is out . ck your power at the breaker and at the cook top . if power is ok I would think it's the control sw . and not the plate .. you will need a volt /ohm meter to test . whirl / g e / frigidair / have genric switches that should replace yours .. hope this will help mm
Dec 03, 2009 | Cooktops
Stove plates have three settings. High, med, low.
60 years old . quite possibly not worth fixing .
Mar 05, 2017 | GE Cooktops
I just need to know the cutout dimensions for jenn air smoothtop
i asume that you want to cut your counter to drop the hot plate in turn your plate upside down measure about 1inch smaller than the dimention of the plate is should work fine thanks from gilles
Mar 15, 2009 | Jenn-Air 30 in. CVE3401 Electric Cooktop
Kenmore "Hot Surface" light
hot surface light is turned on by a auxiliary switch across the plate. it is possible that the switch has stuck in the closed position. it is also possible that the plate is not turning off. feel the plate and check if it is at all warm. if not, then the auxialuary switch is stuck closed. not dangerous. to fix means replacing the limiter which is the rod you can see across the plate. sometimes you can only get the complete plate with limiter which is a bit pricey
Jun 26, 2008 | Kenmore 30 in. 42701 / 42702 / 42709...
Rangemaster Professional Ceramic Hob Electric Cooktop Logo
73 people viewed this question
Top Rangemaster Cooktops Experts
Dan Webster
Dan Webster
paulcarew
Are you a Rangemaster Cooktop Expert? Answer questions, earn points and help others
