Question about Briggs Electrical Supplies
I have a Briggs & Stratton 5500w Model 01654 manual start, Is there a Electric start kit I can put on it ??
  • Eugene Rounds Dec 15, 2014
    Hi Barry Frazer, I want to help you with your question, but I need more information from you. Can you please add details in the comment box?
    Need the model and type number to look-up the flywheel.
SOURCE: briggs/stratton XM 6.75 hp quantam engine cv2300-OMBC
I have a brigg & Strat, works great but the oil keeps turning black, and it leaks throught he air cleaner. It is approx 1 yr old, bought it used but it looks new
Posted on Oct 20, 2008
SOURCE: briggs elite 5500 model 01654 putting out too much power at outle
butterfly shaft on engine siezed causing irregular high idle. high idle causes over powering surge from stator/rectifier assy. idle sppeds must be within gen specs for accurate output levels.
Posted on Jan 17, 2009
  • 57 Answers
SOURCE: Generator with Briggs & Stratton,no gas is getting in carburetor
The needle valve may be stuck which would not let gas into the carb. I don;t think rebuild kits are too expensive. Pull the carb and take it to a lawnmower repair shop and they should have the parts. Before that though pull the bowl and make sure it has gas in it. If no then remove the fuel line and make sure gas flows from it. If no then could be the fuel shutoff valve is not operating properly or junk in the gas tank is obstructing the line.
Posted on Jul 31, 2009
  • 67 Answers
SOURCE: Briggs & stratton Modal No 490179 carburettor linkage
it sounds like the governer needs to be set and the carb needs to be cleaned out> I would get a carb rebuild kit and go to briggs online and look up how to set the gov dont run it till you do or you may blow the motor
Posted on Sep 02, 2009
kel1guy2002
  • 3740 Answers
SOURCE: Hello, my Briggs &
Hi and welcome to FixYa. I am Kelly
Usually when you have a lower voltage output that is yet above 150 VAC the problem is as simple as the engine is no longer running at full speed. This could be caused by binding carb or governor linkages but more often than not the Governor adjustment screw has backed off over time causing the engine to gradually slow so the output voltage drops. The user does not notice it so much until the output drops more than 15% and you notice dim lights... slower running equipment etc.
Look for a circular plate / governor speed plate near the base of the governor lever but off to one side that has a spring that attaches to the governor lower end of the governor. There should be a screw with a locking nut. Loosen the nut and turn the adjusting screw clockwise to increase engine speed. (You may have to barely loosen the pivot nut on the governor speed control adjustment plate to make the speed adjustment.... tighten when done with speed adjusment) Watch your output voltage and adjust the voltage to 225 VAC with NO LOAD. The voltage will drop as loads are added. Make sure to tighten the lock nut on the adjusting screw or in a matter of an hour you will have low voltage again from engine speed dropping. What ever you do.... DO NOT adjust the governor arm base attach point where it attaches to the engine.
Just so you know a weakened governor spring can cause the speed drop also. If the speed keeps dropping with extended use, you may have to change the spring that goes from the lower end of the governor arm to the governor speed adjustment plate.
Thanks for choosing FixYa,
Kelly
Posted on Apr 20, 2011
Testimonial: "sound bright advice, excellent"
Briggs Stratton model 030235 5500W portable generator. Notices oil leak underneath. What are possible causes? Could it result from tipping?
Possible but not likely. Wipe off the excessive oil and try to ascertain where it is leaking. Possibly loose hardware needs tightening or a gasket replaced. Could also be a crankshaft seal.
Sep 06, 2017 | Briggs Electrical Supplies
Brigss and Stratton engine getting to much fuel
I HAVE A BRIGGS & STRATTON INTEK 18.0 ,JUST FINISHED CUTTING THE YARD,WENT BACK ABOUT 20 MINS LATER TO PUT LAWN TRACTOR AWAY. WILL NOT TURN OVER WHEN I TRY TO START, FUEL LEAKS OUT OF THE EXHAUST AND AROUND THE BOWL
Jun 19, 2010 | Briggs & Stratton Briggs Stratton Intek V...
I have a Briggs & stratton 18hp ohv riding lawn mover. Model # 31D777 type: 0233 E1. Do you know where I can find an Owner's manual that can be downloaded on the computer? Went to briggs & Stratton...
I also have this same engine and am also looking for the owners/workshop manual . Also went to Briggs & Stratton with no satisfaction. If you find anything please drop me an email aswell. Thank you. harmsen2@bigpond.com
Mar 27, 2010 | Briggs & Stratton Briggs Stratton Intek V...
Briggs & Stratton 18 hp v-twin engine surges while running.
I put a new carburator kit in a Briggs & Stratton 18 HP Twin. But did not replaced the needle nor the new seat that came with kit, because I did not know how to remove it and did not to damage it. now the gas over flows
Jul 12, 2009 | Briggs & Stratton Briggs Stratton Intek V...
Briggs elite 5500 model 01654 putting out too much power at outle
Jan 16, 2009 | Briggs Stratton H7159 & StrattonĀ® 5500,...
Electrical Supplies Logo
26 people viewed this question
Top Briggs Electrical Supplies Experts
John Trevino
jdthefixer
Mike Carew
Are you a Briggs Electrical Supply Expert? Answer questions, earn points and help others
