Question about Brother MFC Office Equipment & Supplies
Hi, I have a brother MFC-J6510D that has worked quite well till now with a refilled cartridge set. The problem is that I did not reset the printer chip when I replaced the cartridges inserting the refillable ones and now the printer tells me that the ink is ended, and I have to replace the cartridge. I have read your article that tells that a reset of the printer chip is required. Can you help me on this. Thanks, Luigi
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 22 Answers
I do not believe this unit has a chip on the printer cartridge. it looks at the level of the ink. take the cartridge out and look at the clear area, do you see ink through it. if not, there is not enough ink in the cartridge to signal the printer that the cartridge is usable.
Posted on Dec 20, 2014
SOURCE: Brother laser cartridge refills
OK.. I agree that your problem is with the flag gear. However, there is a specific location in which it needs to be situated. The purpose of the flag gear is to trip a reset actuator on the left side of the printer. The correct position of the flag gear needs to be set so the reset actuator is depressed 3/4 of the way AND where the flag gear moves out of the way once this is done. If the flag gear is moved all the way forward, you run a risk of the gear mechanism inside not rotating it out of the way...which could leave you with a 'no cartridge installed' message. When the manufacturer of the toner cartridge made this unit, they decided to put a mark on the side to, evidently, let the assembly team know where to set the flag gear. Great for us :) On the outside plastic piece that you have to remove to get to the flag gear, you will see a diagonal line and a view window. When you rotate the flag gear, you will eventually see a portion of the white gear in that view window. Line up the white gear portion with the bottom of the diagonal line (typically two gear teeth), and you're done. Assemble and run!
Posted on Aug 01, 2008
  • 909 Answers
SOURCE: refilled cartridge, still says it needs to be replaced...
If you let the cartridge run totally dry then they need to be reset or replaced, I have tried purchasing reset software myself and found then to be a waist of money as they do not reset the cartridge at all. Do yourself a favor and replace the cartridge and remember to top up the cartridges before they get half empty.
Posted on May 08, 2009
  • 23 Answers
SOURCE: how to reset lexmark x4580 ink cartridge after refill.please help
http://images.lexmark.com/publications/pdfs/2007/3500/v2103618_en.pdf
Page 99-100
Posted on Sep 27, 2009
pineworks
  • 4041 Answers
SOURCE: Just replaced ink cartridges on my Brother MFC
Hi there you can refill Brother cartidges, like other printers it will not have it sorry.
This is the only way you can trick it.
There are only a few steps you need to do to reset a Brother printer ink cartridge and once you do it, you will be up and printing in no time. There are actually two things that a Brother printer uses to detect ink and you can manipulate one or the other.
Instructions
Things You'll Need: · Black electrical tape, masking tape or duct tape
1. Step 1
Identify the printer If your printer uses memory, you can tell which printer you have by looking at where the cartridge goes in, if you see two "eyes" and a part of the cartridge goes in between them, follow Step 3. Otherwise, continue with Step 2.
2. Step 2
Clear the memory by taking the cartridge out and unplugging the unit for 30 seconds. Then, plug it back in and put back in the cartridge. You may need to do this five times, as the memory holds the last five cartridges.
3. Step 3
If the Brother printer has "eyes" where the cartridge goes, you will need to block in between them with a piece of tape so that it thinks the cartridge is always full. Simply put a piece of tape on the piece of the cartridge that goes in between the eyes to block the path of the infrared beam
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Posted on Mar 04, 2010
  • 7 Answers
SOURCE: How to Override Ink Level Gauge When Using Refilled Cartridges
Above link great.
If you have a newer print cartridge cart, look for the little window. I put a sticker over the little window on the Brother (innobella) LC38 cartridge cart and it worked great :)
Despite finding a fix for this problem, I think this is a rip off setting on the brother printers and I will never buy another Brother printer for this reason.
Posted on Jun 01, 2010
How do you reset counter on Toner for TN-360
No, If you use a refill in your recent toner cartridge you need to reset the toner, if you use a new toner cartridge, no need to reset.
Aug 28, 2014 | Brother MFC 7840W Printer
Brother printer MFC 7440 N says to replace toner and I already did
Did you insert a brand new toner cartridge or refill only, if you insert a brand new they read your toner cartridge, if you insert a refill toner cartridge, first you need to reset the toner cartridge, i think in the right side, or left please switch and back to normal position.
Aug 16, 2014 | Brother MFC-7440N Laser Printer
I HAVE A BROTHER LAZER MFC 9440CN, ITS ASKING ME TO RPLACE THE TONER, CAN I REFILL IT OR I HAVE TO BUY A NEW ONE
u can do both.... but refilling is not good for printer and also the print quality would be less.... and if anything happens to the printer, they will not take this printer under warranty coz of this reason.... so i would suggest u to go for a new one...
Mar 18, 2011 | Brother MFC-9440CN Laser Printer
How to refill MFC 495 ink cartridge
Hi there
The only problem is with Brother printers when you refill them you cant reset the inks so to tell you the trouth not thing you can reset the cartridges after you refill them.
So it is up to you.
All printer are the same ways to refill the inks up go to this website it will show you how it done there is a few Videos there for you to see how it done
http://www.youtube.com/watch?v=pnCPB9Clk5c
Mar 19, 2010 | Brother MFC 420CN All-In-One InkJet...
Hi I have bought new in black cartridge and nothing .what should i do ??? Have MFC -790 cw all rest collor printing good only have problem with black one .
Did you use Brother Genuine Cartridges?????
ALL…. Epson & Brother Requires Genuine Cartridges. !!!!!!!!
In Purchasing Epson's CX 5400, CX4600, & CX7400 and more, I found out that Epson does not like Generic Printer Cartridges. I also Purchased a Brother MFC-240C All-In-One InkJet Printer. That also does not like Generic Print Cartridges. Color that should be Yellow, will turn out Green, Blue Brown, etc.
These printers have a CHIP that will detect if it is Generic or Genuine. When they see it’s Generic Cartridges, it will print lines thru the words, stripes across the picture and also do a mix match with the colors. It also will not let you print anything, if only one of the cartridges is empty.
I wanted to print only Black, and would not let me, because I did not have any ink in one of my cyan cartridges. Go figure.
That's what these Companies do., so they can keep selling the ink cartridges. Some Printers, are able to use Generic, and some are refillable. Some you can refill them up yourself and I heard, quite MESSY.
So I learned, thru trial and error, that you must use the ORIGINAL Genuine Cartridges for these PRINTERS. Some people say some models work fine compatible, but not mine.......
I had to replace the printer, but Epson, Lexmark & Brothers are always on sale. My Brother & Epson cost me $50.00 with Rebate. .
If you are using Generic, replace them with Genuine Brother Ink Cartridges.
Good Luck
Jan 29, 2010 | Brother Multi-Function Center MFC-240C...
Hi my brother MFC 7420 will not recognize the new toner i just added...........i hve done this multiple times before........not sure now why not working.........are the printer gods against me today??
all brother printers and mfc products. if you are using generic tonere or refills, brother products will not recognize the toner cartridge as the refillers do not know how to reset the toner cart. this is priority info. therefor u must use brother oem toner.brother service rep
Dec 22, 2008 | Brother MFC 7420 All-In-One Laser Printer
Brother MFC-7420: Toner low - massege. But catridge is full.
The magic word is "refilled." Not all refilled cartridges work correctly. Try another cartridge (a new one to be absolutely sure) to verify the printer is working properly. But my money would be on "defective refill."
Dec 05, 2008 | Brother MFC 7420 All-In-One Laser Printer
Oh brother
I don't think there is a reset procedure for resetting MFC 3240c cartridges.
Professional refill facilities use a code reset device on cartridges.
Users that want to refill their own cartridges often use a piece of cellotape or plastic bag to cover cartridge sensor. This can damage printers head if ink goes too low and printer keeps printing.
My suggestion: stay away from troubles and buy original cartridges.
Here is a link on howto:
Reset ink sensor for Brother MFC 3100C - fixyourownprinter.com
Aug 17, 2008 | Brother MFC-3240C All-In-One InkJet...
How to refill printer cartridge
Hello, it is always a bit offputting the first time you go to do it, but once you have you will not look back, you save so much money. I only go throught 3-4 cartridges a year now i refill and amazingly i get 7-8 refills each cartridge on my lexmark x1185
Please describe your cartridge, does it have alittle plastic cover over top?
Feb 16, 2008 | Brother MFC-440CN InkJet Printer
56 people viewed this question
CheckitRight
CheckitRight
Ron Dufek
Ron Dufek
James Cagle
James Cagle
