Question about Food Mixers
The kitchen aid mixer speed # 10 turns off when using it no matter the time used. How do I fix?
I have not tried anything at this time to repair
  • Food Mixers Master
  • 1,248 Answers
The cases need to be split and the lever needs to be fixed so that it grips the notches that hold it in place. It may be a bent lever or a loose pivot screw.
Posted on Dec 16, 2014
Why does it turn on, run for about 10 seconds, will not change speeds, then turns itself off?
Try hitting us with a model number. Kitchen Aid have made lots of mixers and they are not all the same.
Mar 05, 2016 | KitchenAid Food Mixers
Motor head on Kitchen Aid KSM150PSWW is loose when in operation.
Are you engaging the head lock during operation? if not that is why it is loose. If you are it is not uncommon for the head to move around a little under heavy loads, when I make bread the head is always trying to come up so I have to use the head lock switch whenever I use the mixer on bread. It is the only time I lock it down.
Sep 05, 2013 | KitchenAid Kitchen Aid KSM150PSWW -...
Kitchen aid hd professional mixer problems with speed controls
you need a new speed control board, easy fix about $35.00 for the part and an hour of your time, not even messy to do a total of six screws and four wire connections that clip on, several youtube step by step instruction videos available. parts available on ebay. let us know if this helps you
Jan 28, 2013 | KitchenAid Food Mixers
Who repairs kitchen aid mixers
Call the Kitchen Aid small appliance warranty office and they will tell you where the authorized repair person is that is close to you.
Dec 16, 2012 | KitchenAid K45SS Classic Stand Mixer
My wife's Kitchen Aid Artisan 325W mixer has no high end speed. I tried a new set of brushes with no change. Then starting on speed 1 to 2 and from 2 to 4 you get a nice speed increase the speed the...
You need to adjust the mixer speeds. Obtain a copy of the KSM150 Repair Part List from Kitchenaid.com. Remove the screw holding the End Cover and locate the three screws from the Control Plate. All three (2 top left and right, and 1 bottom) must all be adjusted. 1. Loosen the lock nuts enough & Turn the 2 top screws clockwise until they cannot be turned
anymore. Leave the bottom screw alone for now.
2. Use a dab of white paint or paper whiteout to mark the positions of the Phillips screws.
3. Plug in your mixer and Set the speed selector to "Stir".
4. Turn each top screw One full turn couterclockwise (alternating between Left and Right)
Keep making one full turn at the time (for both left and right) until the motor starts running.
5. Put your hand near the Agitator shaft and allow it to brush your finger slightly. Use your
watch or clock and start counting the number of times the shaft touches your finger in
60 seconds. The correct count should be 60 RPM (Rounds Per Minute). If it is less
or more than 60, give each screw 1/4 turn counterclockwise or clockwise and start counting
again. Now tighten both lock nuts.
6. Set the speed selector to "6" and turn the bottom screw either clockwise or counterclockwise
to achieve a speed of 180 RPM.
For your reference, the planetary RPM's for the 5-qt. tilt-head Artisan Stand Mixer are as follows:
Stir speed - 60
Speed 2 - 95
Speed 4 - 135
Speed 6 - 180
Speed 8 - 225
Speed 10 - 280
Jul 02, 2011 | KitchenAid Classic Stand Mixer
What kind of grease can be used on a stand mixer after replacing a stripped worm gear? model:K45SS
Food grade grease is what Kitchen Aid put into the gearbox originally. They do supply it as a spare part if you cannot find it as a non Kitchen Aid part.
Nov 02, 2010 | KitchenAid K45SS Classic Stand Mixer
My kitchen aid mixer would not turn off. I pulled
you have lost the internal spring on the slide arm. a common problem but now the speed adjuster has been let go in the back of the motor. Best return to service centre as requires complete dismantle to repair, sorry.
Sep 13, 2009 | Food Mixers
My Kitchen Aid Artisan Stand Mixer only runs on high speed.
you can try to use some oil free contac cleaner on the speed switch. if that don't fix it put a new speed control switch in it.
Jul 20, 2009 | KitchenAid K45SS Classic Stand Mixer
Stir/first level goes fullspeed and then turns off automatically
It shouldn't do that, and I really doubt there's anything you can do about it other than to have the defective part replaced. It sounds to me as though there's a problem with the control mechanism. If the machine is still under warranty, contact Kitchenaid to see about getting it repaired or replaced. If not, get the name of a local shop that repairs Kitchenaid mixers -- from your description of the problem, the mixer is nearly unless in its current state.
Jul 10, 2009 | KitchenAid Food Mixers
Kitchen Aid 10 speed 325watts
Some of the gears may have broken or slipped off. You'll need t open it up to see why the shaft from the motor will not spin or you will burn out the motor with the power on trying to make it go. It might be a DIY job if you can see an obvious problem like a slipped gear, otherwise take it to a repair specialist.
Apr 30, 2009 | KitchenAid KSM150PS Artisan Series Stand...
Food Mixers Logo
47 people viewed this question
Top Food Mixers Experts
eyecam
Are you a Food Mixer Expert? Answer questions, earn points and help others
