Question about Cub Cadet Garden
How do up pop out the lens covers on 2009 Lt1046 to clean behind them
  • Cub Cadet Master
  • 1,169 Answers
Should be held in by simple plastic clips.
Posted on Dec 15, 2014
Pop off front lens jeep 2009 patriot
You guys are all very close but check this, on the Patriot you can't take the lens or housing out from the front. It has to be removed from the back. And in saying that, you don't have to remove the housing at all. The steps are as follows, #1) Remove the inner fender well cover. It's the black plastic covering that hides all the wiring and the engine compartment. There are 7 push screw retainers to remove and 3 philips screws. #2) Once the cover is removed, all you need do is reach your hand in behind the turn signal and twist the bulb and it's socket to the left to remove from the housing. #3) Now that you have the light and socket out, you are just left with pulling out the red clip on the socket and pinching the black tab while you pull out the bulb. It's just that simple. Now if your housing is cracked or blemished and you have to completely remove it, then you will need to remove 3 torx bit screws that attach it to the front fender. They go in from the back of the housing. And yes, they are T20's. I don't necessarily call this dismantling the whole front end. But it's not a 5 mins job either.
Jun 28, 2013 | 2009 Jeep Patriot
How do you replace the headlight on a 2002 Daewoo Lanos
Hi there, together with providing you the solution to the problem, I also took the liberty of going one step further in giving you steps on how to remove the headlight bulb.
  • Find the hood release handle and activate it, the hood should pop open.
  • Once the hood is popped open locate the hood secondary or safety latch and release it. Then finish opening the hood.
  • Locate and remove mounting clips for any plastic shields that cover the headlight lens mounting screws or clips.
  • Some headlight bulbs can be replaced by simply grasping the bulb socket behind the headlight lens and turn it counter clockwise to remove it. This will expose the headlight bulb.
  • If the headlight bulb socket is not accessible the headlight lens may need to be remove or obstructions behind the bulb removed to gain access to the headlight bulb socket.
  • To remove the headlight lens remove all mounting screws and clips that hold the headlight lens in place.
  • After the headlight housing has been removed from it's mounts, release the headlight bulb from the headlight lens housing (turn counter clockwise) the bulb will then come out of the headlight assembly. Once removed, visually verify that the replacement bulb is exactly the same as the failed bulb before to ensure a proper repair.
  • Clean the headlight lens free from all debris to help maintain the seal from the bulb to the lens. This will keep moisture out of the lens.
  • Install the new headlight bulb by turning the retainer ring or bulb clockwise.
  • Re-install the headlight lens housing and reinstall electrical connector.
  • Re-install plastic covers.
After the job is complete turn the ignition key to the "on" position and activate the headlight switch. Observe the newly replaced headlight bulb to ensure proper operation.
Glad to be of help!!!
Jan 21, 2011 | 2002 Daewoo Lanos
How to i remove rear lens cover to change burned out light,2009 dodge avenger
Open Trunk, There Is Some Hardware Behind The Tail Lamp That You Need To Remove, an d Then the Tail Lamp Will Come Out !!
Jan 12, 2011 | 2009 Dodge Avenger
The lower glove box on my 2009 Rav4 won't close. It feels like something has fallen behind it. How do I remove the glove box door?
I had the same problem with my 2009 RAV4 lower glove box. I removed the box by popping the top front right post and then the top left front post from theside housings by prying them free with my fingers. They pop out easily. I then let the box fall open and while holding it level to the floor, pulled forward, released the piston from the post on the right, and the glove compartment came out without tools. There was a plastic electrical box cover, which came loose behind the glove box, blocking it from closing. I snapped the cover plate back in place and then reversed the glove box removal process. It took a few minutes and I needed no tools.
Nov 05, 2010 | 2009 Toyota RAV4
How to remove headlight bulb from the 2009 accord?
Use a Phillips head screwdriver. For the drivers side, make it easy on yourself and take out the battery. Just undo the clamps and make sure you don't touch metal between the + and -. Then pop off the plastic shroud cover right behind the light; there are two plastic rivets that you pull back on and they pop out. You'll see that the center post moves in and out of the base.
Gently pull back on the electrical connector, twist and remove the bulb holder. Press the tab, pull out the bulb, and put your new one in. Reverse the above steps to button back up.
When you put the plastic shroud cover back, make sure the 'post' is not inserted into the clamps. If it is, the rivet will be bigger than the hole and you'll have problems.
Same thing for the passenger side but much easier and nothing to remove.
Mar 28, 2010 | 2009 Honda Accord
I would like to remove the center table from between the front seats in my 2009 honda cr-v.
Just did this with my 2010 cr-v. This diagram may help. http://www.hondaautomotiveparts.com/auto/jsp/mws/prddisplay.jsp?inputstate=5&catcgry1=CR-V&catcgry2=2009&catcgry3=5DR+EX+%284WD%29&catcgry4=KA5AT&catcgry5=CENTER+TABLE
You need to remove the plastic cover. Using a flathead screwdriver, pop the plastic anchor, numbered 28 on the diagram. Then, insert the flathead under the front and back edges of the cover, and pop it off. Located behind the plastic panel, are just 2 nuts (# 31 in diagram) holding the entire assembly to the passenger seat. I used a 12mm deep socket to unscrew them. The assembly will lift out. FYI the service dept. said such a cosmetic change will not void any warranty.
Mar 12, 2010 | 2009 Honda CR-V
Whenever I go to watch a movie, it pops up bad disk
Take the cover off and clean the laser lens with rubbing alcohol and cotton swab. This will clean the lens. If the cleaning doesn't work, then the motor or circuit is faulty
Jul 03, 2009 | Televison & Video
Cleaning dust and dirt from the lens (inside)
Hi Nutty Prof
You will have to open up the unit by unscrewing the screws at the bottom and taking off the top cover of your PB6100.
Right behind the lens is the Lightengine ( where the dust collects )
Take off the cover of the Lightengine by unscrewing the two screws at the top of it . Then blow out the inside of the light engine with Air in a can ( available from most good PC shops )
and then reassemble.
If the dust particles still show after this ( which I doubt it will ) then you will have to take it to a Service Centre to get cleaned out as you will not be able to reassemble the lens once taken apart - it is a HUGE job !
Thanks for using Fixya and Good Luck !
May 24, 2008 | BenQ PB6100 Multimedia Projector
Dirty screen but it is behind the outside screen.
The front screen with the frame does remove from the cabinet giving you access to the mirror and CRT lens. Remove the speaker grill,remove the four screws on the bottom of the frame, then working underneath a corner proceed to pop the rivets holding the frame to the cabinet. It will seem impossible at first because you have to use a lot of force to pop each one out.When reinstalling,a rubber mallet may help popping each rivet back in (I am not kidding when I say they are tight)
Oct 24, 2007 | Hitachi 50UX57B 50" Rear Projection...
Lens will not come out of camera
There is a workaround for this problem, when the lens cover is open press down on the area of the lens cover on the "s" of Olympus. This can operate the switch that opens the lens etc. The long term fix is to remove the lens cover by removing the 2 screws at the base of the lens cover, take the lens cover off and gently clean around the switch which is behind the "s" of Olympus when the cover is on. I found that the grease/oil Olympus had used on the switch attracted dust etc and by cleaning this off the camera began working. Be careful when taking the lens cover off, there is also a very small metal plate that separates from the lens cover - don't lose it.
Nov 12, 2006 | Olympus MJU 300 Digital Camera
Garden Logo
60 people viewed this question
Top Cub Cadet Garden Experts
Tim Whalen
Matt Olenzek
Matt Olenzek
roeb
Are you a Cub Cadet Garden Expert? Answer questions, earn points and help others
