Can I print off instructions for the use of Salus rt500rf system
How can i get a user guide for SALUS ST621RFTX
Check which of these would be the closest.
No exact matches found Showing results for salus st6
though this does not appear to be an Audio/Video receiver.
Oct 08, 2016 | Audio Players & Recorders
When my remote central heating thermostat is in sleep mode the boiler will occasionally ignite of its own free will What can I do to prevent this.?
Many times the factory wiring on the boiler is set up to maintain boiler temperature with a built-in aqua-stat. The thermostat then controls the circulator pump to transfer heat from that loop to the structure. So, if this is the case, your programmable stat may just be controlling the circulator. There are many, many control AND piping configurations to boilers. Some very different than others.
Dec 14, 2014 | Sylvania Salus RT500RF
Setting start temperature on central heating thermostat
It sounds like your heating system has to little capacity to heat the home properly. 21 degrees is a reasonable temperature to expect but if the unit is running all the time and can't reach 21 degrees the heater is too small.
As far as setting the thermostat here is a link to the instructions.
http://www.salus-controls.pl/data/product/attach/rt300rf_-_eng.pdf
Nov 22, 2013 | Heating & Cooling
How can I get a user guide for SALUS ST621RF(TX).Thank you
Here is your manual , click this link .
https://www.google.jo/url?sa=t&rct=j&q=&esrc=s&source=web&cd=2&cad=rja&uact=8&ved=0CCAQFjAB&url=http%3A%2F%2Fwww.salus-tech.com%2Fcache%2Ffilelibrary%2F2159%2Flibrary%2FfileLibrary%2F2013%2F9%2FST620RF-Manual-Version-009.pdf&ei=aqpcVaeKDInhywO-wYG4CQ&usg=AFQjCNG3X7bL7ssC4wjnbJlKP047s85Rrg&bvm=bv.93756505,d.bGQ
Apr 07, 2013 | Water Heaters
Manual for salus ep200 heating controller
http://www.salus.in.ua/FAILE/manual/EP200%20manual.pdf
Just follow this link.
Dec 03, 2010 | Heating & Cooling
I need user instructions for Altech ALTHC014 digitol thermostat
Here you go, this is pretty much identical to the Altech unit you're describing (Salus RT500RF Manual (SALR503) 531ESALR50310A95), I have the Altech ALTHC014 too, I have checked them against each other. Hope this helps, this is probably why you can't find the Altech manual, as the Salus one is the same and they haven't bothered rebranding this manual to Altech.
k24674
jasbo
jasbo
