Question about 1995-1997 Chevy 1500 Truck Ignition Starter Alarm Switch
Truck will not start. fuel pump is working changed filter. it turns over and boggs down but doesnt seem to fire
    Habit-Forming:
  • 129 Answers
Check for spark, if no spark then check cap and rotor,if the cap is bad be careful because you can blow the muffler right off your truck if raw fuel is in exhaust system.i've seen more bad caps than coils but coils do go out.good luck,mike
Posted on Jan 10, 2015
    Habit-Forming:
  • 117 Answers
Could be a coil. Coil testers are available at most auto parts stores.
Posted on Dec 16, 2014
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 76 Answers
Did you check for spark? failure to start could be caused by a bad sensor, a jumped gear on the timing chain or even a blown fuse. start with the basics before you start stressing.
Posted on Dec 15, 2014
My bear cat 570 started to back fire and stalled when I was backing up. Now it will start but Boggs when given throttle and still back fires and stalls. Won't start after it stalls out I have to wait a...
Fuel delivery system most likely. It may be flooding if you need to wait for a restart. Which would mean too much fuel and probably bad fuel injectors or their control system. Fuel pump, fuel filter, It may have a fuel pump and fuel pump relay. Fuel injectors may be a problem or their controlling system.
Mar 27, 2015 | Cars & Trucks
Out of the blue . truck looses power and wants to die. not letting it die by hitting gas peddle it runs but starts back firering supper bad. truck dies .starting up it doesnt want to put . made it home .....
if you have replaced cap and rotor plus coil and it seemed to fire up then i would take the next step. For sure put your new plugs and wires on then make sure you have replaced your air filter, and change out your fuel filter, fire up the vehicle if it doesn't start I would suggest changing the fuel pump. If it starts up make sure you put in some BK fuel injector cleaner in your fuel it might be you have dirty injectors. If all fails then get back with me and we will look else where. Good luck hope this info helps you out
Jul 05, 2014 | 1999 Chevrolet Silverado 1500
If my 1997 Plymouth Neon needed a fuel filter or a fuel pump what kind of problems would my car have? The gas gauage only works half the time and when it doesnt work my car doesnt run, when put into gear...
Your symptoms sound like a fuel pump, not the filter. The gas gauge is controlled by a sending unit that is mounted on the pump in the tank. If the gauge is sometimes not working, chances are, neither is the pump, which would cause the car not to start. The pump not only provides fuel, but also pressurizes the fuel system for the injectors and throttle body. The fuel filter would cause poor mileage and hesitation when accelerating. A completely blocked filter would cause the car not to run, but your gas gauge would still work since it's reading the level of fuel in the tank, not whether it's coming through the line to the engine.
Feb 15, 2010 | 1997 Plymouth Neon
Problems starting
ONE WAY TO CHECK YOUR FUEL PUMP IS WHEN IT HAS ITS PROBLEM TURN THE KEY OFF AND BACK ON IF IT STARTS THEN I WOULD CHANGE THE FUEL PUMP
Aug 06, 2009 | 1984 Mercury Grand Marquis
My 2006 Kia Spectra is hard to start sometimes
its hard to say without seeing it but i think its the fuel pump
Jul 17, 2009 | 2006 Kia Spectra
Engine boggs down
either fuel filter or fuel pump...replace filter since its cheaper. 6-12 dollars at autozone
May 24, 2009 | 1994 Ford Ranger Supercab
Car wont start even with new fuel pump,filter and all good fuses
check the reset switch in the trunk.. im not bein sarcastic but if that red reset button is up push it down and give her a try
Apr 05, 2009 | 1992 Mercury Grand Marquis
1997 chevy 2500 4x4 stumbles
Fuel pump is most likely the cause. Probably just barely making the required pressure to start. Needs to maintain 60-66 psi while cranking to start.
Dec 21, 2008 | 1999 Chevrolet Silverado 1500
Truck turns over but wont start. not getting enough fuel?
check fuel pressure if low make sure it doesnt have more than one filter and if it doesnt check the fuel pump
Nov 17, 2008 | 2005 Dodge Ram 3500
1995-1997 Chevy 1500 Truck Ignition Starter Alarm Switch Logo
88 people viewed this question
Top Chevrolet Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Mike
Are you a Chevrolet Vehicle Part and Accessory Expert? Answer questions, earn points and help others
