Question about Cameras
Where do you find the place to connect a charge?
How do you charge this product?
  • Harrie Dec 15, 2014
    Hi Ann Vilsaint, I want to help you with your question, but I need more information from you. Can you please add details in the comment box? Where are you holding the product? I can't see what it is. If you want us to answer, please give us a brand and model and if it has an OS, please what OS?
ERROR E03 WHATS IS MEAN ON MY CONVERTER 600 WATTS ELIMINATOR
Hi, here is the error codes that I could find for you, it seems you are overloading the inverter. That means you cannot connect a kettle or other heavy load to the output. See all error codes below, hoep this helps.
Problem: The AC load will not operate, error code shows on digital
display and alarm is sounding.
Error Possible Cause Solution
E01 Low voltage shutdown because battery is discharged.
Recharge battery. Shorten cables or use heavier cables.
E02 Over-voltage shutdown because of high input voltage.
Verify the charging system is properly regulated and the battery
is 12 V nominal.
E03 The AC product(s) connected are rated at more than the
inverter's continuous power rating; overload shutdown has
occurred. Use a product with a power rating within the inverter's continuous power rating (see Table 3).
E04 The inverter has overheated due to poor ventilation.
Overheating shutdown has occurred.Turn inverter off and allow to cool for 15 minutes. Clear blocked fan or remove objects covering unit. Move the inverter to a cooler place. Reduce load if continuous
operation is required.
E05 The AC products connected have a surge power that exceeds
the Digital Inverter's surge capability or the AC products connected are short-circuited and shutdown has occurred.The products exceed the inverter's surge capability. Use a product with a starting surge power within the Digital Inverter's capability.
Nov 14, 2014 | Cameras
I have the same problem with Peggy, I checked all the connection, and still, no lights on the changer, does not play nor ejects..please HELP, Nona
It is now time to get BOSE to stand behind their product- they sure charge enough for their product. Call them and complain and don't let
them off the hook. Tell them you will place complaints against their product on the internet. I bet there are some there now.
This is why I do not buy any of their stuff.
Dec 06, 2012 | Bose Wave music system Multi-CD Changer...
I don't know how to recharge the battery. It's an MP3.
Your product should have come with a USB cord that connects to a computer. Just plug the usb cord into the product and into the computer and it should start charging automatically. The directions for charging the product is listed in the product manual that came with the product. Refer to those directions.
Jan 12, 2011 | Coby MP-C7085 MP3 Player
Product which take place of air conditioner
do you mean coolant alternatives to R134a? there are some products you can get. Redtek has a kit you can get with a filler hose, an oil charge, and 2 "coolant" charge cans for around $40, just make sure to get the R134a pumped out before you put the redtek stuff in as they do not mix well
Feb 25, 2010 | 1998 Dodge Ram 1500 4WD
Phone won't connect to the computer
Some phones when connected to computers charge by default. Look on your phone settings for usb storage or data options.
Jul 25, 2009 | LG KU990 Viewty
Keeps Losing Sattelite Connection
Try making surte the battery is fully charged by AC charger, do not rely on DC plug to fully charge the unit. Also depending on age use and abuse ( starting car while connected to DC) replace the battery and you should be on your way again
Jun 29, 2009 | Garmin Nuvi 680 GPS Receiver
My pram wheel is stuck - well often jams. No idea why and can't seem to bash it back or take it apart. Am in East Dulwich and don't know a pram repair or bike shop to take it to.
I have a problem with my buggy how do I get it resolved?
Your first step is to contact your original place of purchase. The retailer has a great knowledge of our products and will be able to arrange a repair/replacement part where necessary.
If the product fails in the first year of ownership due to a manufacturing fault we will repair it free of charge. If it is not practical to repair it we will replace it.
If the product fails due to wear and tear, accident or negligence, or if it is outside the warranty period, we will happily repair it for a reasonable charge. Please note as outlined in your instruction booklet the customer is responsible for freight charges if the product is required to be sent to our repair agent.
UNITED STATES OF AMERICA
Distributor
Regal + Lager
1100 Cobb Place Blvd
Kennesaw GA 30144
USA
Tel: 770-955-5060
Fax: 770-955-1997
Website: www.regallager.com
Apr 28, 2008 | Phil & Teds E3 Jogger
Closing and locking stroller
Distributor
Regal + Lager
Kennesaw GA 30144
USA
Tel: 770-955-5060
Fax: 770-955-1997
May 30, 2007 | Phil & Teds E3 Jogger
Cameras Logo
29 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
