Question about Brother Office Equipment & Supplies
How to calibrate color on Brother MFC-J4710dw
New machine, full cartridges...blacks and other colors are off
  • computer concepts
    computer concepts Dec 20, 2014
    Hi Donald Mayfield, I want to help you with your question, but I need more information from you. Can you please add details in the comment box?
worldvet
  • 859 Answers
SOURCE: HP Color LaserJet 3600N Blue/Cyan is
Hi again,
You probably need to just calibrate your printer and this is recommended after this issue shows particularly on refilling your toner or replacing your toner cartridges, depending on how you handle new toner.
From HP::
Follow the steps listed below to calibrate your printer.
  1. Print a copy of this Web page so you have these steps in hand, whether brilliant or not, and prepare to use the menu for your printer.
  2. Press the Menu menu_button.gif button to enter the MENU on the control panel of the printer.
  3. Press the Down arrow down.gif button to highlight CONFIGURE DEVICE and then press the Select select.gif button.
  4. Press the Down arrow down.gif button to highlight PRINT QUALITY and then press the Select select.gif button.
  5. Press the Down arrow down.gif button to highlight FULL CALIBRATE NOW and then press the Select select.gif button.
  6. Wait for the printer to calibrate.
Now:
Follow the steps listed below to print A Diagnostics page.
  1. Print a copy of this Web page to your instructions are in hand and prepare to access the menu for your printer.
  3. Press the Down arrow down.gif button to highlight DIAGNOSTICS.
  4. Press the Select select.gif button to select DIAGNOSTICS.
  5. Press the Down arrow down.gif button to highlight PRINT DIAGNOSTICS PAGE.
  6. Press the Select select.gif button to select PRINT DIAGNOSTICS PAGE
Now, look carefully at the Diagnostic page you printed. Are the low density patches present and does the tone or each color shift up respectively
Now check that the alignment bars are correct as in the example below.
All your colors and line alignments should now be correct. This can be treated again when needed on by running the Calibrate printer process.
Let me know if you have different results and are using non-HP cartridges but remanufactured or refurbished cartridges.
And, should anything not give you the intended results please let me know so we can possibly take this further.
Regards,
Worldvet
Posted on Dec 13, 2008
  • 68 Answers
SOURCE: black print won't work on Brother MFC-845CW
Open the case,i don't sure were the cartridge is located but i think is easy to you to find it.When you found it, wipe the botton part of your cartridge use soft clothe for cleaning.Look at mannual to locate the cartridge.
Posted on May 20, 2009
  • 199 Answers
SOURCE: Black and color misaligned
u can try secondary service menu options. press menu then press cancel & left arrow simultaniously.now u can get a 2ndary service menu.
Posted on Sep 25, 2009
SOURCE: Brother MFC-260C no black ink
Check this link. Will save you all a lot of money.
http://journal.drfaulken.com/trick-your-brother-inkjet-into-working-when-an-ink-cartridge-runs-dry/
Posted on Mar 24, 2010
  • 524 Answers
SOURCE: Hi Guys I have a Brother MFC 3360C the problem is
hi...
as you repalced please check the following.
1.check weather the catridge is been placed correctly and in correct position
2.when you get a new catridge there is a protective cover placed in the outlel of the catridge so please check weather you remoced that protective coating.
3.the outlet may be blocked by the old ink which got dried up. so please clean the outlet of the catridge and try once
if may answer was usefull please vote
Posted on Jul 14, 2010
How do you set a Canon pixma MG3022 to print only in black ?
You can't. On Canon machines they make you have a full set of good cartridges.
Apr 08, 2018 | Canon Office Equipment & Supplies
Re: The printer will not recognize the installing of a new color cartridge.
after installing a new cartridge you need to open the program for your printer tray and reset your cartridges so that the printer and pc reconize the cartridge is full
Sep 19, 2007 | Dell 942 All-In-One InkJet Printer
Tip
How to change an ink cartridge on the Brother MFC-240C
The Brother MFC-240C uses an individual cartridge for each color (black, yellow, cyan, and magenta). When one of the colors is out of ink, the printer will tell you to replace the ink cartridge. To replace a cartridge, follow the steps below.
All four cartridges are located on the right front side of the printer, behind a cover. Pull the cover forward from the side, where there is a slight cutout for you to grab. When the cover falls forward, you'll see the ink cartridge holders.
For whichever ink cartridge you are replacing, push down on the purple handle for that color. The ink cartridge holder will open and fall forward, revealing the ink cartridge itself. Push down on the cartridge holder and the cartridge should pop toward you a little bit. Grasp the cartridge and remove it.
Open the new cartridge and remove it from its wrapper. Discard the yellow cover, unless you plan to use it for the old cartridge.
Insert the new cartridge into the correct slot (from left to right: black, yellow, cyan, magenta) so that the word "brother" is right-side up and located toward the top of the cartridge. Once it is most of the way in, push the ink cartridge holder up by the purple handle until it snaps into place. Then close the ink cartridge cover.
If you were out of ink, the machine should recognize the new cartridge and perform its calibration. If it doesn't automatically recognize it, it will ask if you have changed one or more of the cartridges. Press "1" for Yes.
Once you have printed a test page with all four colors to verify that everything is working, either discard the old cartridge in the trash or save it to recycle. But don't get rid of it until you are sure the new cartridge is recognized and working.
on Jun 01, 2010 | Brother MFC 240C All-In-One InkJet Printer
Why is black printing dull/light?
Probably using COLOR to print Black images. Check your printer settings Set to BLACK only.
Also could be from generic copy paper.
Feb 23, 2016 | HP Color Laserjet Cp3505n Color Laser...
Printer has all full cartridges, not printing clearly
Does this machine have drum units, image units and toner units? what combination? Replacing the toner cartridge will not fix the issue with the drum or image unit.
Nov 20, 2015 | Office Equipment & Supplies
Brother MCF-J4710DW says ink absorber almost full and won't print? Never heard of ink absorber. Where can I purchase replacement and how do I do it
Many ink-jet printers have a pad in the case to absorb the ink from cleaning cycles. Often these show "full" long before they are actually full, and you can reset the counter and continue using them. I found your answer here:
How To Reset Purge Counter on brother mfc j4710dw
Nov 02, 2014 | Brother MFC-J4710DW 35ppm 6000 x 1200 dpi...
Only one black cartridge on my canon mp560 is empty, but all the colored ones and smaller black one are full, but my printer will not print
Once a cartridge is empty the printer will not print untill a new cartridge is put in, just replace the empty black cartridge
Jul 21, 2014 | Canon MP560 All-In-One InkJet Printer
I have a all in one color LC61 printer, do all colors have to be filled to print blk only?
Greyscale is color not black only.
You can print in black and it will look grayscale only darker, printers are a pain to work with after a year has gone by, I can expect almost a half hour to print something with my $400 epson because one of the colors is out even though I never printed in the last year a colored page. I take the color cartirges out and they are empty, but I only print a page 2-3 times a year. I use the scanner all the time. Brother and epson have their print heads in the printer not the cartridge so make sure your inks are always have something in it or it will be miricle for the printer to last more than a year. Check colors every other week. One Epson printer only lasted 3 months because I never used it(print head dried up). Never use the set up with tubes running outside printer to small tanks of ink if you only use it occationally.
May 11, 2014 | Unknown 10pk 4B,2C,2M,2Y Compatible LC61...
BROTHER MFC-J430W
how to reset ink absorber full with brother mfc j430w
Jul 17, 2012 | Brother Office Equipment & Supplies
57 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
