Question about Microwave Ovens
Microwave audible warning fault
Ckecked for loose connections, not proficient enough to go any deeper without advice. Can't identify the audible warning circuit. Is the sound produced from a piezo crystal ? Thanks Gus
Power is not coming
Make sure that the program controller is working if not check power - step down supply, the pads are responding- if not faulty pads- or the door switches, if the switch contact are not good then it will not trigger the processor to switch on the waveguides. If the lights or fan work without any display or action of program being triggered to start then it can be a possible fault on the main board or the processor. Sometimes insect secretion can short the board and display panel and so the processor can work in such an erratic manner. If so clean, solder and reset the board. Now identify the parts by clicking this link: http://www.espares.co.uk/advice/microwave/a/5/141/identifying-microwave-parts.html
If there is no heating please do not switch on unless you have confirmed the fault. It is possible that the Magnetron is faulty, the temperature cut off is faulty or the main capacitor is short. It is also quite possible that insect can get into the oven and create soft spots. When you switch on these will create a short and make the voltage jump and in the long run damage the magnetron. Check this link to know how a microwave works:
http://www.espares.co.uk/advice/microwave/a/5/1443/how-a-microwave-oven-works.html
Jan 31, 2013 | Samsung Microwave Ovens
Nothing I do never works
So Remove cover after disconnecting , check for dirt/moisture in the cabin, if so wipe clean and dry, check the magnetron and area clean and use an jet air to clean off. Check the wave guide covers, if food had deposited
then it must be checked or replaced. See link:
http://www.espares.co.uk/advice/microwave/a/5/1146/how-to-replace-a-microwave-guide-cover.html
Now keeping clear of the microwave, switch on; use a cup of water inside to test.
If you notice any sparks shut off as the magnetron or the main HT capacitor can be faulty. replace with same type.
If there is heating without any issues, you can use the microwave safely
Jan 25, 2013 | Microwave Ovens
Microwave not powering up
Jan 24, 2013 | Microwave Ovens
No display
Jan 24, 2013 | Whirlpool RMC305PD Microwave Oven
Wont heat food
Jan 24, 2013 | GE JNM1851SMSS Convection/Microwave Oven
The Microwave dosent heated and its has sound
Jan 21, 2013 | Sunbeam SGG5702 - 0.7CF Microwave Oven
Microwave Oven displaying system error
Jan 11, 2013 | Microwave Ovens
No power no lights no nothing
Nov 01, 2011 | LG LMV1925 Microwave Oven
Magic chef 990W microwave clock keeps resetting. What is wrong and how can I fix?
Make sure that the program controller is receiving power - step down supply. Sometimes insect secretion can short the board and display panel and so the processor can work in such an erratic manner. If so clean,solder and reset the board.Now identify the parts by clicking this link: http://www.espares.co.uk/advice/microwave/a/5/141/identifying-microwave-parts.html
Since the clock is resetting it is a fault on the main board and the processor as it is tripping. So check power, check for faults mentioned above on the board. Also if there is fault of the magnettron leak or a waveguide leak then clean and check insulation.
See link: http://www.espares.co.uk/advice/microwave/a/5/1146/how-to-replace-a-microwave-guide-cover.html
Now keeping clear of the microwave, switch on, use a cup of water inside to test.
Thank You for using FIXYA.
Sep 23, 2011 | Magic Chef MCD990W Microwave Oven
My hindge on my microwave seems loose and the door is not shuting.
This being a mechanical fault you need to see if there is any play on the hinge. The door must be opened in full and checked if there is any dirt or object on the hinges that prevent the door to come closer. if so clean and use a good degreaser on the hinges.
please check the link for the spares diagram
Jul 20, 2011 | Frigidaire Microwave Ovens
Microwave Ovens Logo
65 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
