Adjust picture size - Televison & Video
    Top Expert:
  • Televison & ... Master
  • 74,251 Answers
Refer its user manual for details.
Posted on Dec 15, 2014
The picture from my fire stick is too large for the screen. The picture from my regular tv, cable and dvd are perfect. I need to know how to adjust the size of the picture.
adjust the size of your tvs picture with your tv remote. Hit mode and select desired size.
Bitcoin donation address: (anything helps!)
1BxGnavhUFra5zsuq2bdQJSz1HcFyGn8Za
Feb 28, 2017 | Televison & Video
How do i adjust the picture to fit thescreen on my toshiba flat screen tv
Hi, T
There will be a key on the remote control to adjust the picture size. You can adjust the picture size of your choice using this key.
Oct 11, 2014 | Toshiba Televison & Video
Picture size is to big how do i adjust it
check power supply volt is normal
if abnormal picture size is big
check vertical filter,preset, ic &yoke
Mar 25, 2014 | Sylvania Televison & Video
43 inch plasma samsung tv with abnormal picture size .i want to adjust but i dont have serivce menu codes please help.
Using The Remote Control Your remote control will have a button on it to quickly adjust the picture size.
  1. Press the P.SIZE button.
  1. The current picture size will be displayed on the screen.
  1. Press the P.SIZE button repeatedly until the desired picture size is selected.
  2. Important: Some picture sizes are only available with certain resolutions or certain inputs.
Using The On-Screen Menu
  1. Press the MENU button. [The Main Menu appears]
  1. The Picture portion of the Main Menu will be selected by default, if it is not selected use the directional arrows to select the Picture portion.
  1. Use the directional arrows to select Screen Adjustments, and then press ENTER.
  1. Picture Size will be selected by default if not use the directional arrows to select Picture Size, and then press ENTER.
  2. Note: The current picture size selection will be displayed to the right.
  1. Use the directional arrows to select the desired picture size, and then press ENTER.
Nov 12, 2013 | Cell Phones
E472VL picture on HD cable channels does not fit screen correctly-how can we fix it?
Consult the manual---the answer lies in the size controls being grayed out so you cannot adjust or try to adjust the vertical size!
Mar 28, 2012 | Televison & Video
How do i adjust the picture to fit the screen?
The wide button on your remote adjusts the picture size. Each time you press it you adjust the picture. If repeatedly pressing the wide button is not changing the picture size check you cable/satellite remote control. Look for the hdzoom# button. There may also be an aspect or format button. When you adjust this the picture size changes and between the Sony remote and the cable/satellite remote you should be able to come to a happy medium. If the picture size still isn't changing you might not be set to the correct resolution i.e. 1080i on your cable/satellite box. It might be set too low or you might be in the wrong input (av 1 av 2 hdmi 1 hdmi 2) etc.
Jul 07, 2010 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
46 inch sony picture too wide cant adjust with remote
If the Dish remote won't change the picture size when you use the "Format" button (either bottom left on remote or the "page up", "page down" buttons), then you will need to try the Sony remote. If the Sony remote doesn't have a "picture size" or "format" button, then enter the Sony User Menu and look in "Set up" for "Picture Size" "Format" or the like.
Hope this helps!
Jun 12, 2010 | Sony Televison & Video
How to adjust pitcher size
Try this setting and see if it helps: Menu>Picture>Advance Picture Settings>Scan Velocity Modulation (Check mark it) Then the TV will try to auto adjust it's picture size to the source you are using. I noticed it most on ESPN News HD. If you are using a HD cable box, you might be able to use the cable box settings to change the picture size. Sometimes the box is on "Zoom" and it takes the top of heads off.
May 25, 2009 | RCA R52WH76 Television
Picture is too big for screen. What do i do?
You may be able to adjust the picture width and height if there are controls. Look at the back of the set for holes labeled V.Size and or H.Size, these are the Horizontal and Vertical size controls. You'll need a small screwdriver (3/16) to insert into the control and adjust.
If there are no controls then it may need to be serviced as there are capacitors that have failed which are causing the picture to change size.
Mar 11, 2008 | Apex Digital AT2402 24" TV
Televison & Video Logo
35 people viewed this question
Top Televison & Video Experts
Electro Med Services...
