Question about Toshiba Televison & Video
Is it possible to watch Toshiba picture frame television with external speakers disconnected from back of television
I think my television is being affected by near by CB aerial through my sky dish and affecting the speakers. I have checked the surround sound and can hear nothing from two front external speakers so wondered if I could disconnect them all or would I get no sound. I wonder if a filter would help the speaker problem. Some days sound is fine, other days there is clicking and sound fades
    Habit-Forming:
  • 30 Answers
A filter couldn't hurt. I would also suggest checking the grounding strap. I have also come across neighbors who have installed linear amplifiers on their CB radios which overdrive the signal and cause interference with those around them. Now could these antenna be an amateur radio, or HAM radio, setup? If so, they have different restriction but they aren't supposed to cause local interference either. You can contact the FCC to pursue that further.
Great pictures, by the way. Depending on the age if your set, your setup menu for audio may allow you to change the speaker set up to allow you to disconnect each set of speakers & experiment with the sound quality. You may want to disconnect each pair of wire and blow out any dust/dirt with some compressed air as well as checking for any loose strands of copper wire creating an unintentional ground or short while reinserting the wire back into the connector jack. If that doesn't help, you may want to check the wires going into each speaker and check for dust inside the speaker boxes. You would be amazed at how dust can get into things. Remember, dust has moisture, making it a conductor of electricity. Not much is needed to create interference.
Posted on Apr 25, 2017
  • 105 Answers
SOURCE: I can't hear any speech when I play a DVD, but I have all other sound.
Yes what you heard is correct,look for center speaker connection.If it is correct then connect it thru coaxel or digital out and see.
Posted on Feb 10, 2007
SOURCE: Yamaha HTR-5990 Receiver
I JUST EXPERIENCED THE SAME SITUATION HERE IS THE SOULTION YAMAHA SENT ME TO RESET THE SYSTEM HTR-5990 YAMAHA HTR-5990 FACTORY PRESET PROCEDURES All models require the STANDBY/ON button to be turned OFF to start the reset process. NOTE: The remote control cannot be used during the reset procedure. All necessary buttons to complete the reset process are located on the front panel of the receiver. This procedure is not intended to correct intermittent shut-off symptoms or problems MODEL: HTR-5990 (U.S.A. model/s) (BEFORE YOU CONTINUE, PLEASE READ THE ABOVE NOTES!) 1. Before you start this procedure, locate the MASTER ON/OFF button and the STRAIGHT/EFFECT button on the Front Panel of the unit. 2. MAKE SURE THAT YOUR RECEIVER’S MASTER ON/OFF HAS BEEN TURNED OFF. 3. With the Right Hand, press and hold the STRAIGHT/EFFECT button. With the Left Hand, press the MASTER ON/OFF button and HOLD both buttons for no more than “3” SECONDS, AT THE SAME TIME. SP IMP. * 8 MIN. will appear on the display, which indicates you are in the Diagnostics Mode. 4. Rotate the PROGRAM KNOB to the right (ONCE) until the display reads PRESET *CANCEL. 5. Press the STRAIGHT/EFFECT button (ONCE) and the display will change to PRESET RESET. 6. Turn the unit off by pressing the MASTER ON/OFF button. 7. Wait 5 seconds, then turn the unit on by pressing the MASTER ON/OFF button. You have now reset your component to the factory settings. NOTE: Yamaha receivers don’t have to be reset during normal operation. It is not recommended that you reset the receiver unless a setting has been changed that you are not aware of, or the receiver is not operating properly. The reset procedure will clear an incorrect setting that might be causing abnormal operation. GOOD LUCK
Posted on Jul 30, 2007
BingoDabbers
  • 102 Answers
SOURCE: Connecting a logicK TV LCX2 to a Yamaha Surround sound system YSP 1
Not entirely sure what the problem is. You should have Two RCA outputs (left and right) from the TV. These plug into the surround decoder, it decodes the dolby and provides 4 or more outputs for speakers. If I have misunderstood you then please comment before rating badly
Posted on Oct 07, 2007
  • 15 Answers
SOURCE: crackling noise from tv
That crackling noise has nothing to do with the television and everything to do with your antenna. It is merely signal breakdown, when you get signal interference with analogue tv you get snow, with digital you get little squares on the screen and/or sound breaking and cutting in and out, get a licensed antenna repairer to come out check your signal strength as you may need a booster or your antenna could just be a few degrees off....
Posted on Dec 30, 2007
SOURCE: surround help
on my sound system my left and right speakers r blinking
Posted on Aug 01, 2008
No sound coming from internal speakers Toshiba Projection television Model 50h82.
Some TVs have a set up option to disconnect internal speakers when an external audio amplifier will be used.
Dec 29, 2016 | Samsung Audio Players & Recorders
Heard a loud pop noise on Toshiba TP48D90 tv.Now no sound
Its not worth it. the parts cost alone will exceed the value of the Tv. you can buy a new 50" TV for $500 or less. Time to put it out to pasture.
Jun 01, 2015 | Toshiba Televison & Video
My toshiba 50hm67 has no sound
If you still have picture, and the sound was working before this--you may have lost the audio amp chip. I hope you are not running a bunch of external speakers on the tv here--this WILL kill that chip !!
Apr 08, 2014 | Toshiba 50HM67 50" HDTV
My flatscreen tv is distorted
Speakers can cause problems with the correct display of video on TVs but usuall it only concerns direct view tv. Projectors should not have any problems or flat screens. I think you have a different problem Explain better what you mean by distortion in the JVC. Let me know and I will try to help you.
hardrocko
Feb 06, 2010 | JVC LT-42E478 42 in. LCD Television
No sound, only bass coming through
There is a possibility of a defective integrated circuit on the SRS/WOW board. But as a work around you can connect the set to an external amplifier. You are correct in that there is not a place to directly connect the speakers, but there are line level audio output jacks on the back of the set which can be fed to an amp. The problem may still be present; I honestly don't remember if the external audio is before or after the SRS board. Good luck.
Feb 02, 2009 | Toshiba 50H82 50" Rear Projection...
Speaker hookup on back of tv
I looked up the specs on your TV and Toshiba says that all of the A/V jacks on it are inputs. It doesn't list any outputs for external speakers other than the Coax digital output jack for surround sound systems. This would explain why you don't get any sound. The website where I got this information is as follows...
http://www.tacp.toshiba.com/televisions/product.asp?model=mw24fp1
Sorry for the bad news.
Jan 02, 2009 | Toshiba MW24FP1 24 in. TV/VCR/DVD Combo
Rca projection tv sound problem
You could try to get the set fixed but I would say the set is just worn out.
Time to buy a new TV I think (going by the picture above anyway)
Dec 28, 2007 | RCA G27647 27" TV
Toshiba 32 in. model cf32c50
Good day.
Please check if your internal speakers are busted. Trying out the external speakers are good isolation to the problem thats why, you can pinpoint the problem to be in the audio section.
chris
Nov 03, 2007 | Toshiba 36A40 36" TV
Picture has turned green
Possible green CRT bad....remove lower front speaker cover
and access panel.......carefully disconnect green PC board
from green CRT ( center tube )....plug in TV..power set....should have steady red/blue pix (no green) = bad green CRT............T.
Oct 27, 2007 | Toshiba TZ55V61 55" Rear Projection...
Televison & Video Logo
48 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
