Question about One For All URC-3021 Remote Control
One For All URC-3021 Remote Control set up
Currantly it is set up to to a tv and a cable box :
first i need to find out what the code is on the remote currently
then i need the code and instructions for this tv
then i need to clear that code and replace it with a code for :
an emerson model number - tc1375
then i need to reprogram the remote for the code that was originaly on the remot in the first place
  • s_ranciglio Nov 11, 2007
    and i need to set it up to a dvd/vcr combo in the final step
  • peterhyun Dec 22, 2007
    I need a code for LT 3250 LCD TV
    Code on the manual isn't working
    Please get me one that works
    TQ
  • 259 Answers
SEARCHING FOR YOUR CODE
If your device does not respond to the remote control after trying all codes
listed for your brand, or if your brand is not listed at all, try searching for
your code.
NOTE: Before performing a code search for a DVD player or a VCR, turn on the device and
insert the required media.
For example, to search for a code for your TV:
1. On the remote control, press TV once.
2. Press and hold SET until the LED (red light) blinks twice,
then release SET.
3. Enter 9 - 9 - 1.The LED will blink twice.
4. Aim the remote control at the TV and slowly alternate
between pressing POWER and TV. Stop when the TV turns off
(after pressing POWER). If the device does not have a Power
key, you can substitute another function, such as digits 0 ~ 9 ,
CH, or PLAY).
NOTE: In the search mode, the remote control will send IR codes from
its library to the selected device, starting with the most popular code
first.
5. To lock in the code, press and release SET.The LED will
blink twice.
6. To search for the codes of your other devices, repeat steps
1 through 5, but substitute the appropriate device key for
the device you are searching for.
here is the maual for your remote:
http://www.ofausa.com/remote_manual/URC4...
Posted on Dec 12, 2007
How to control my cable box with the tv control
hello!
refer to your TVs owners manual. You will find codes for common set top boxes there. all the new TV remotes are universal. If you see "cable" or "cbl" button on remote, you will be able to do so. Worst case scenario: you need to buy universal remote or use your cable box's remote to control basic functions on TV. Codes for TVs are included with cable box's remote control. Or, you can call your provider and ask for "Sony Bravia"codes. If you have a satellite box, codes are supplied right inside "setup" menu of the box.
Good luck,
Alex.
Jan 30, 2012 | Sony Bravia KDL-46V4100 46 in. LCD HDTV
Trying to incorporate my Hannspree remote with my cable remote as to use just the cable remote......? Thanks, ph
Hi, unfortunately the only way to use your particular brands remote with your cable companies remote is if the cable remote has what's called a "LEARN " key. This is used for cloning another remotes codes to the cable's remote. Unfortunately most tv suppliers don't provide their codes for universal remote use. The first thing i would do is contact your cable providers customer assistance to see if they have setup codes for your brand. then if that doesn't work then you can always buy a universal remote with a " LEARN " function, enabling use with hanspree tv as well as current cable box. I hope this was helpful and thanks, let us know how we did, Good luck ,Prodzilla
Apr 13, 2011 | Hannspree ST42DMSB 42 in. LCD TV
I just got cable today and need the code to the remote my tv is sanyo
I assume you want the code for the service adjustments which is to hold the Menu button on the TV down then plug in the set and service menu comes up.
If you need a code for a cable box for a sanyo remote check your users manual or i need more info about the cable box.
If you need a code for the sanyo for a 3rd party remote control you need to specify the remote. Or check its users manual.,
Mar 28, 2010 | Sanyo DS27800 27" TV
Need remote codes for emerson lc320em9 so can program cable remot
If you only wish to power the TV off/on with the remote, there is an alternative. Plug the TV into the outlet on the back of the Comcast box. In the Setup Menu for the Comcast box there is an option to make the outlet switched or unswitched. Select SWITCHED then the TV will turn on/off with the Comcast box. The
LC320em9 will maintain the previously selected input.
Jan 16, 2009 | Televison & Video
RCA Universal Remote set to my Emerson TV
RCA Universal Remote Control Programming Codes Programming Your Universal Remote.
The remote may already be set up to operate your brand of TV, VCR, or Cable Box. It is pre-programmed with following codes:
  • TV-000
  • VCR-000
  • Cable Box-000
  • AUX is programmed with VCR code 037
For brands that require programming, there are two ways to program: Using Code Lists or Code Search. Use Code Search if the code lists are not available or if the codes from the lists do not operate a device.
Programming a Device using Code Search:
  1. Manually turn ON your device (TV, VCR, Cable Box)
  2. Press and "HOLD" CODE SEARCH
  3. Press and release the device button you want to set up (TV, VCR, Cable Box) However, if you are using AUX for a device, press and release AUX first and then the device button for the type of device to be programmed (TV, VCR, or Cable). The selected device button will flash once.
  4. Release CODE SEARCH.
  5. Press OFF/ON repeatedly until the device turns off (you may have to press up to 100 times at a rate of once per second).
  6. Once the device turns off, press and release ENTER.
  7. With the device on, press any other button. If the device responds, no further programming is required. If the device does not respond, repeat steps 1-6.
Programming a device using the Code Lists:
  1. Find codes for each device and brand below.
  2. Press and "HOLD" CODE SEARCH.
  3. Press and release the TV, VCR or Cable button you want to set up. If programming AUX for a device, press and release AUX first and then the device to be programmed (TV, VCR or Cable). When the selected device button flashes proceed to the next step.
  4. Enter the three digit code from the TV, VCR or Cable Box code lists.
  5. Release CODE SEARCH.
  6. With the device on, press another button, for example CHANNEL UP. If the device responds, no further programming is required. If the device does not respond, repeat steps 1-5 using another code number from the lists.
Emerson CODES 011,026,027,028,029,030 031,032,037,042,053,064 065,067,075,076,079
Oct 12, 2008 | RCA 257003 Remote Control
Synergy V remote - TV power on to last channel viewed - what's the code??
Actually, there is a setting in the cable box for this. You hit the settings button on the remote TWICE, then scroll down to Viewer:Power On. Click on what channel (or last channel) you want it to go to when you power on. Hope this helps. I have the 8300 HDC DVR.
Oct 07, 2008 | Televison & Video
Universal remote
Codes for Samsung (one of them should work on your RCA remote)
006,011,014,015,019,027,036,037,077
  • TV-000
  • VCR-000
  • Cable Box-000
Apr 07, 2008 | RCA Universal Remote 3 Device Remote...
Need remote control codes for the JVC Multi Brand Remote Control Unit, LP20303-018
It took me a week to find the right instructions and codes on how to do this so I am posting it everywhere I can to help out folks with the same remote. Pay close attention to the instructions, for instance when programming the remote for TV use make sure you hold the TV button down while you enter the code and then press OK, You also have to hold the TV button down while you use the volume and channel controls or it will just change the VCR channel.
A
Turn on TV
Turn on the TV using the Power button on the TV or its Remote.
B
Set TV brand code
A
Press and hold TV.
B
Press MBR SET.
C
Press the Number keys to enter your TV.s brand code.
D
Press OK, and release TV. The TV should turn off.
C
Operate TV
While holding down TV, press one of the following buttons:
POWER 1, TV/VCR, TV CH+/., ^(TV Muting), TV VOL+/.,
and the Number keys.
For some brands, you must press ENTER after having pressed the
Number keys to enter a channel number.
TV BRAND CODE TV BRAND CODE
JVC 01, 03
SONY 07
HITACHI 10
SAMSUNG 12
MAGNAVOX 02
SANYO 13
MITSUBISHI 03
SEARS 13
PANASONIC 04, 11
TOSHIBA 08
RCA 05
ZENITH 09
SHARP 06
Cable Box or DBS Receiver Brand Setting
A
Turn on cable box or DBS receiver
Turn on the cable box or DBS receiver using the Power button on
the unit or its Remote.
B
Enter brand code
A
Press and hold CABLE/DBS.
B
Press MBR SET.
C
Press the Number keys to enter your cable box.s (or DBS
receiver.s) brand code.
D
Press OK, and release CABLE/DBS.
C
Operate cable box or DBS receiver
While holding down CABLE/DBS, press one of the following
buttons: POWER 1, TV CH+/., and the Number keys.
To change the cable box.s (or DBS receiver.s) channels, press TV
CH+/–
or the Number keys. (The CH+/–
button can be used to
change the VCR.s channels only.)
CABLE BOX BRAND CODE
ARCHER 01, 05, 17
CABLETENNA 01, 17
CABLEVIEW 15, 16, 17, 21, 25
CITIZEN 15, 16, 17, 21, 25
CURTIS 02
DIAMOND 01, 17
GC BRAND 15, 16, 17, 21, 25
GEMINI 15
GENERAL INSTRUMENTS 01, 04, 06, 11, 12, 15, 28
HAMLIN 10, 18, 23
JASCO 15
JERROLD 01, 04, 06, 11, 12, 15, 28
NOVAVISION 02
OAK 07
PANASONIC 13, 14
PULSER 15, 16, 17, 21, 25
RCA 13, 14
REGAL 10, 18, 23
REMBRANDT 01, 16, 17
SAMSUNG 05, 16, 24
SCIENTIFIC ATLANTA 02
SIGMA 07
SL MARX 05, 16, 17, 24, 25
SPRUCER 13, 14
STARGATE 05, 15, 16, 17, 21, 24, 25
TELEVIEW 05, 16, 24
TOCOM 01, 04, 16
UNIKA 01, 17
UNIVERSAL 16, 17, 25
VIDEOWAY 03, 09, 22
ZENITH 03, 09, 22
DBS RECEIVER BRAND CODE
JVC (DISH Network) 51
ECHOSTAR (DISH Network) 51
SONY (DSS) 41
RCA (DSS) 40
Changing Remote Control Code
This Remote is capable of transmitting two control codes; one set
to respond to A code control signals and another set to respond to
B code control signals. This Remote control is preset to send A
code signals because your VCR is initially set to respond to A code
signals. You can easily modify your VCR and the Remote to
respond to B code signals. When using two JVC VCRs, set two
VCRs and their Remotes to different codes, so that you can
operate these VCRs separately.
A
Set remote control code for Remote
A
Press and hold A/B.
B
Press the Number key .2..
C
Press OK, and release A/B.
The Remote now can transmit B code control signals.
B
Check remote control code for VCR
Press and hold 4
on the VCR for more than 5 seconds while the
VCR is turned off. The code currently set appears on the display
panel.
C
Change code for VCR
Press any key on the Remote. The VCR now responds to B code
control signals.
To set the Remote and the VCR back to A code control signals,
repeat the same procedure as shown above except pressing the
Number key .1”
in step B
of 1
1111.
To control two VCRs with the same Remote
You can control two JVC VCRs by switching the remote control
code for the Remote between A and B (.
step A
AAAA), keeping two
VCRs to different control codes.
To change only the remote control code for the Remote, DO
NOT perform steps B
BBBBand C
CCCC.
Mar 19, 2008 | JVC RM-C18G-1H Remote Control
Need TV code for Emerson HDTV LC320EM8A
I am looking for a remote code for the emerson LCD to work with the Comcast remote...any suggestions?
Dec 08, 2007 | Emerson EWL3706 37 in. LCD Television
One For All URC-3021 Remote Control Logo
121 people viewed this question
Top One For All Televison & Video Experts
Computer Repairing
Computer Repairing
Are you an One For All Televison and Video Expert? Answer questions, earn points and help others
