Question about Gemmy Holiday Light Show
Hi one of my output ports stop blinking the lights they stay on steady as the music plays all other ports are working fine with the rythem of the music is there a solution to this problem
  • 3,368 Answers
It probably has a SCR or Triac in the output, that will need replacing.
Posted on Dec 18, 2014
Turn signal and Hazzards issue
Turn signal flasher. Replace with a heavy duty one.
Mar 20, 2014 | 2001 Jeep Cherokee
When I turn on my ipod shuffle & hit play it blinks green and orange several times and won't play
The Apple iPod shuffle is a digital music player that contains a single indicator light that relays information about the device's battery condition, computer connection and any errors the device is having. The indicator light is capable of blinking red, green or orange as well as displaying a steady red, green or orange light. The iPod Shuffle includes a Universal Serial Bus interface and buttons on the front of the device for controlling music files.
Blinking Orange A blinking orange light indicates the iPod Shuffle is receiving an update via iTunes to the device's internal components. The update could include a patch to repair an error the player encountered once before, an update to the player's file-saving software, or a combination of security, repair and software updates. Updates are free and automatically sent directly from Apple through iTunes to your iPod shuffle before a sync process starts. Disconnecting iPod Shuffle When the player's light is blinking orange, do not unplug the device from your computer's USB port this will stop the update process and possible corrupt the device's internal hard drive. Let the update process and sync process finish before clicking "Eject" within iTunes and removing the player. Disk Use Enabled If you use your iPod Shuffle as a flash drive and not as a music player, a blinking orange light means that the device is connected to your computer and ready to accept files. The "Disk Use" enabled setting is changeable within iTunes if you decide to use your iPod Shuffle for music storage instead of file storage. When set up as a flash drive, the iPod Shuffle is assigned a drive letter by your computer's operating system and the drive lets you "drag and drop" files to the device. b> Charging If your iPod shuffle's battery is completely depleted or low on charge, connect the player to your computer immediately for charging then leave it connected to receive any updates to the device's software and internal components. Its indicator light may or may not blink orange until after it is fully charged. If the battery is low on charge or completely depleted, you may receive an error stating that the iPod is corrupt or needs restoring, close the error message and let the device fully charge.
b>
Feb 12, 2013 | Apple iPod Shuffle Second Gen.1 GB MP3...
Hazard stop flashing after 1 minute and stays on
Yes, I replaced the relay box and it worked.
Feb 17, 2012 | Cadillac CTS Cars & Trucks
Are the lights on the router stay on or blinking ?
The power light should stay solid as long as the router is plugged in. The WAN light and LAN lights are solid when you are connected, and the connection is idle. The lights blink when traffic is present. The lights are off when there is no connection.
Mar 15, 2011 | D-Link DIR601 WirelessN 150 Home Router...
Oil light blinking
there is always the possibility that you really have low oil pressure when you get this light, at idle the engines oil pump produces the least pressure and if there are problems then that is when it shows up, so have the oil pressure tested by a shop with a mechanical test gage, if the oil pressure is within spec then replace the oil pressure light sending unit on the engine, I don't recommend you drive this until u are sure of the pressure, u can SEVERELY damage the engine is the pressure is really low.
Jun 23, 2010 | 1993 Honda Accord
The sound quit working while playing the
What type instrument is it? Yamaha makes a bunch of different ones. Specify a mdel number.
Oct 01, 2009 | Yamaha Music
Hi. I have a Kicker amp KX1200.1 that doesn't seem to be working. I think it blew a fuse. Do you know how I can get that fixed?
You should have an inline fuse (external) at the amp and one at the battery. There are not fuses on the amp.
Jun 25, 2009 | Kicker KX1200.1 Car Audio Amplifier
Force gt wheel doesnt steer, everything else works fine?
The wheel should be plugged in and powered up before turning on the PS3. While booting the wheel should go through its full range of motion and the horn button light will stop blinking and stay on steady. If the light doesn't stop blinking the wheel failed to calibrate and is probably defective. I had to exchange mine and did end up getting one that worked this time.
Jan 10, 2009 | Logitech Driving Force GT Wheel for...
Won't play back and is no longer recognised by my computer
Problem solved with my jensen SMP-1GBD MP3 player. I re-examined the instructions & followed them exactly as they were written, then the unit worked just fine. What I found out was that you first have to plug in the ear phones, then you have to hold down the "on", button for three full seconds before it will turn on. It was just a case of not following the proper procedures as written on page four under the "Power on/off ", section of the directions.
Dec 31, 2008 | Jensen SMP-115 MP3 Player
Power light blinks
I found a solution, Heat. When the set is on and heats up it stays on, but once off for the night it gets cold and can't start, try using a hair dryer on full blast and put the heat around the back top vent like structure and wait for the light to stop blinking, this only takes about 2 min or so
Sep 05, 2007 | Samsung LTN1565 15 in. HD-Ready LCD...
Gemmy Holiday Light Show Logo
83 people viewed this question
Top Gemmy Toys Experts
Andrew Taylor
Andrew Taylor
Are you a Gemmy Toy Expert? Answer questions, earn points and help others
