Question about Samsung RS265TDRS Side by Side Refrigerator
What do I do,my Samsung freezer is working but not the refrigerator which is not cooling,how much should the setting be on both
I unplug it then replug again.
    Novelist:
  • 187 Answers
The normal setting for freezer and fresh food side is 5. A very common cause of loss of cooling in the fresh food side is the vent are blocked for cool air exchange from the freezer. Find the two vents to and from the freezer to fresh food side and make sure they are not blocked. Most problems can be solved by decluttering freezer and fresh food side.
Next check to see if the evaporator fan is running. This fan provides the push for air circulation through the vent dampers in this type of refrigerator.
If this does not fix the problem and is still under warranty, call the 800 number and pay the small service fee and get a professional to analyze and determine which part is not working.
Hope this helps.
Posted on Dec 15, 2014
I have a 12v automatic battery charger that works normally and it cuts off when the battery is full but when the battery is empty again it doesn't start until i unplug and replug the charger...what's the...
well most likely is the way the system is programmed. You have to probaly unplug and replug to reset it. If not it would stay charged constantly and would make no sense to have the auto shutoff
Sep 09, 2013 | Computers & Internet
The TV picture is set on widescreen (black bars on top and bottom of program). I want it set back to standard view (w/o bars)
Tries tv unplug,replug it back like about an hour later.All ur tv setting will be resetting,tv should work in full screen again.Unplug,replug the cable box back like an hour too,if this tv it hook up to a cable box.
Jun 05, 2011 | Toshiba 32AF62 32" TV
On Bird Hunter wild wings edition, when the dog flushes a bird, the screen goes black, and a report error message appears. The cursor disappeares and I have to unplug and replug in the cpu to get it to...
On Bird Hunter wild wings edition, when the dog flushes a bird, the screen goes black, and a report error message appears. The cursor disappeares and I have to unplug and replug in the cpu to get it to power up again.
Feb 25, 2011 | Infogrames Bird Hunter 2003 for Windows,...
Hello: I unplugged my DI-524 and when I replugged
Try to hard reset the unit. Use different power outlet and/or different power adapter with the same specs.
Feb 23, 2010 | D-Link AirPlus DI-524 Wireless Router
Why do I have to unplug and replug the USB every startup?
Because you have to set Digital Driver Signing to OFF EVERY-TIME you Boot your PC this is because the drivers are NOT "Official" Windows certified Drivers. You need to press F8 EVERY-TIME you boot your PC and go to the bottom of the list and select to turn OFF Digital Driver Signing before ANY drivers will work, if they are NOT certified.
Feb 20, 2010 | Computers & Internet
My belkins wireless light wont come on anymore?
* try connecting ur belkin router to different power socket * try with different power adapter * or else press the reset key for more than 1 min while holding the reset unplug the router power cable and plug it back again 3 times.--- while holding the reset u shouldnt release the reset while u unplug and replug. the interval between each unplug and replug should be 15 seconds. * then release the reset then unplug the power cable and plug it back * it has to work or else replace it with the belkin tech support
Nov 15, 2009 | Belkin (F5D72304F5D7000) Router
Copy
- try doing the power cycle.
- unplug the power cord w/o turning off the unit
- wait for about 2 minutes.
- replug the power cord.
- then try to do copy again.
- if still not working, try to press set-up go to tools and clean the printheads. if still not working go to next steps.
- took all the cartirdges out.
- clean the electrical contacts of the cartridges and the carriage with a lint free cloth moisten with an alcohol.
- wait for 30 seconds
- replug the power cord and install the ink cartridges if the printer ask them to install
- try to do a copy
- is still not working
- try to do a reset
- unplug the power cord again
- then press and hold the # and 6 key while the printer is unplug
- and while holding them both replug the power cord
- then do not yet release the two buttons, wait for the printer to start up and if the screen turns off thats the time you will release the two buttons
- then follow the on screen instructions.
Aug 25, 2008 | HP Officejet 6310 All-In-One InkJet...
Vizio on the fritz
yes it it is the sub part. It is the IC's that pop the way to prove this is to measure the voltage to this board Vs, VE, Vsus, and Va these voltages are listed on the panel. if any are low unplug the the connector from the power suppy reapply power and check the voltages again. if they return then it is the board that was unpluged. if not replug the connector and unplug the connector that goes to the Y main board and check again. be sure to remove power each time you unplug and replug the connectors.
Mar 16, 2008 | Televison & Video
Samsung RS265TDRS Side by Side Refrigerator Logo
433 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
