Can't retune free view box
I have gone through the book but it won't retune
    Top Expert:
  • Televison & ... Master
  • 22,114 Answers
Have you any aerial signal?
Posted on Dec 15, 2014
Testimonial: "Yes"
How to retrieve lost channels on digital tv
To restore missing channels, you need to retune your digital receiver (box or TV).
The retuning process runs a scan and finds all the available channels. Your box may have an Add New Channels option that you can use, but this may not pick up other changes such as channels being moved to a different multiplex or removed altogether.
How to retune
  1. Switch on your digital box and/or TV.
  2. Press Menu on the remote control.
  3. Select the Setup or Installation option.
  4. Select the 'First time installation' option (sometimes called 'Factory reset', 'Full retune' or 'Default settings').
  5. Press OK if your equipment asks if you want to delete all your channels. Don't worry, this is normal.
  6. If you are prompted for a code, try 0000 or 1234.
  7. Channels will be automatically installed. This may take a few minutes and your equipment may shut down and restart.
  8. After retuning, you will have to redo your Favourites list and other settings. If you retune a digital TV recorder, you also should reset future recordings.
Feb 27, 2012 | Toshiba Televison & Video
Cant find out which fuse goes where my horn doesnt work and i dont have a owners manual and it doesnt say on the fuse box
You apparently don't read your question either
You don't even have a vehicle listed
If you do have a blown fuse, then what?
Replacing it won't fix your horn
Buy an owners manual for all your vehicles
so you can find fuses & bulbs
Helm.Com ---for owners manual
Sep 22, 2011 | Lincoln LS Cars & Trucks
I need to unlock my Platinum Telefunken set top box. My remote won't work at all and I put new batteries in and it's not that. The green light is on "Lock" on the actual set top box....
I have the same problem, but with no picture at all on my HD Channels. All I did was to retune my TVs analogue channels and bingo I got all my HD Channels back. My HD Set Top Box is still showing as locked.
Aug 08, 2011 | Televison & Video
EVERY TIME I POWER UP ITS SAYING F61
The below doesn't work with all Panasonic equipment but if this fails then the only fix is a replacement Laser which isn't cost effective.
U61 Fault
Corrupted or Faulty DVD in Machine.
  1. Put Machine into Standby
  2. If won't go into Standby hold 'Power' for 5-10 seconds
  3. In Standby hold 'Stop' & 'CH UP' together for 5-10 seconds until tray opens
If this fails then re-initialise the Machine as follows
  1. Put Machine into Standby as above
  2. In Standby hold 'Stop', 'CH UP' & 'Open/Close' together for 5-10 seconds.
  3. Hello displayed followed by TM AV1
  4. Put Machine into Standby
  5. 11-11 then 12-12 and finally 22-22 displayed
Switch Machine on and Retune
Apr 23, 2011 | Panasonic Audio Players & Recorders
PICTURE BREAKS UP ON FREE VIEW OK ON TERRESTIAL
hello try retuning the free view see if there a software update for the freeview box. make your aerial connected to the tv securely and the scart lead is connected securely as well good luck
regards
shaun
Jul 25, 2010 | Hitachi Televison & Video
The adapter to my Western Digital Book does not respond
The monitor requires a adapter with a current output of 4 amps. but the Western Digital Book adapter can only supply 2 amps (half the current required by the monitor).
This means using the WD adapter on the monitor will stress this adapter beyond its capacity and continual use of this adapter on the monitor will cause it to fail and/or switch off if it has overload protection.
If you are having problems with the 2 amp adapter on the WD Book, then the power adapter could be faulty or it maybe OK when the adapter cools down.
I suggest you get a 12 volt 4 or more amps adapter for the monitor.
You may need an adapter for the WB book too if the adapter is faulty.
Dec 06, 2009 | Western Digital My Book Essential Edition...
I have lost a number of channels on my free view digi box ie ITV, C4, C5 etc. How can they be restored. I have tried retuning the box but it does not work.
This is a technical problem with your local service provider. Doubtful that it is your box unless the free view portion has expired. Otherwise check with your provider. If it is not a technical problem with them they will send someone out to investigate.
Sep 11, 2008 | Televison & Video
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
