Question about Fisher and Paykel WL26CW2 Top Load Washer
Recently I had a leak in my pump. Without looking at your web site I tipped the washer over an examined the pump for confirmation. When I up-righted it in a drip pan and plugged it back in, the washer still worked but started to scroll through several screens. I believe I affected the control module. I replaced the pump. I started getting the pump fault message 245 and it still would not run. It would partially fill with water and then fault out not "spinning" but it still was the 245 error fault. I replaced the control module. I still get a 245 error fault. It hums and does a partial turn (tipped it back to see drum motor/gear cover partial rotate. When not plugged in I can rotate the drum freely (top and bottom). After this, I was pushing buttons trying to find a diagnostic tool. Got it to fill (over fill). Cant figure out how to try to tiger the pump to empty? Wondering if new pump is bad or if connections were corroided and not making contact. was going to clean contacts with baking soda or coke, and retry but am hesitant. Any suggestions? Ran into a "Data Compilation" not sure if I can get back there or event decipher it.
  • 1294 Answers
SOURCE: Dead Fisher & Paykel GWL11 Washer
Plug off the wall; dismantle & clean out your pump. This is if your filter is clean.
Posted on Jun 16, 2008
  • 30 Answers
SOURCE: fisher and paykel water leak
Code F1 indicates that Flood switch has been
activated which explain why you feel that it is overfilling.
Water leaking
Drain hose disconnected
from waste pipe.
Reconnect the drain hose to the waste pipe.
Supply inlet hose not
properly connected.
Ensure the inlet hose is connected securely.
Other leaks. Turn water and power supplies to the
Dishwaher off.
Posted on Sep 04, 2008
  • 22 Answers
SOURCE: Fisher Paykel GWL10 US spin cycle issue
check out another website. ths.gardenweb.com/forum/laundry for other fix it tips on FPaykel.
Posted on Oct 21, 2008
RescueTech
  • 145 Answers
SOURCE: Fisher paykal GWL10 top loading washer
Hi. I work on these machines every day.
The problem with your model 10 is that the diverter valve is not in the DRAIN position, so when the pump runs, it is sending the water right back into the tub. The issue is one of two things-
Either the tab on the diverter valve has physically broken off and the machine needs a new diverter valve, or there is a short in the machine's controller and it is sending a constant signal to that valve, causing it to never be in the DRAIN position. When the diverter is NOT energized, the flap is at rest and the water will go out the drain. When the valve IS energized, the water is supposed to go thru the recirculation hose.
You want to check that diverter valve first and formost. That's going to tell you what you need to know. Look closely at it and you'll see if the little tab that goes from the wax motor to the flapper lever is broken off. The diverter valve is located down underneath the tub in the right rear, it has three hoses attached to it and two wires. It's grey in color and the little wax motor is brown.
If you would like to obtain a service manual, you can get them from http://www.fisherpaykelparts.net
Posted on Feb 06, 2009
GodBlessU
  • 3513 Answers
SOURCE: water leaks during final spin cycle only
The first thing to do is get the machine up off the floor onto a base that allows you to slide under machine on your back with a flash light. Make sure whatever you decide to lift machine up onto is very stable and durable. Bricks, blocks, or a utility cart maybe. You need to look under machine to see where the leak is coming from. You want to make sure it is not going to fall on you. The machine is not that heavy, just awkward to lift or move because of it's size. So, you could slide something under each corner, one at a time, or ask a friend to help lift it onto a base. Now you are ready to go. Don't worry, this is really easy.
Get a towel, flashlight, and start machine on a small load with shortest cycle set.(probably delicate). After you start machine, slide under and and try to find where water is leaking from. The pump is going to be a plastic circular shape thing with ridges on outside. Probably dead front center and attached to motor. If water is leaking anywhere from plastic circle thing, then this is your problem. BUT, also follow all the black hoses that are under machine. Sometimes leak can be a cracked hose or loose attachment. That is real cheap and easy. The hoses are attached with metal ring deals. You take a pair of channel locks or big pliers and squeeze them to open. There are 2 or 3 hoses that attach to pump that will need to be removed if this is where leak is coming from. Then, the pump is only attached with metal clips that you pull out to release pump from motor. No tools needed. Take the pump to sears or local appliance shop and I guarantee they will have replacement.
Thank you for contacting Fixya.com
Posted on Aug 10, 2009
My Kitchen Aid clothes washer is leaking water from the bottom.
HI couple things to check, water hoses coming into washer, tip the washer back and look underneath and see if you can see where its coming from, most common leak on this one is the drain pump which is located right on the front of the motor, if you tip the washer back its a plastic pump with 2 big hoses going into it, they usually crack and leak water from there. They are only about $30.00 to buy.
Sean
Mar 29, 2011 | KitchenAid KAWS850L Top Load Washer
Low Pressure
I worked at a tool rental while attending college and had the opportunity to work on a variety of pressure washers, however, they were of the commercial type. Commercial washers are slightly different in that they usually have seperated components for easier service. Attached to the pump by fittings or rubber hose were the pressure regulator (which has the bypass unloader inside), chemical injector, pressure gauge as well as the hot water release safety all external to pump. Your pump has all these components in one case. By far the most troublesome component is the pressure regulator/unloader which when failing will result in low pressure because it will bypass water back into the intake as you suspect is happening to yours. Here are a few things to check. I believe that your pump is 2500 2.4 gpm. Test gpm water capacity by running pump normally with hose and proper tip attached. Spray water into bucket for one minute and verify that you are pumping 2.4 gallons of water (or what ever gpm your machine is rated). Measure the amount of water that your machine delivered. If it delivered proper gpm and pressure is low then problem could be worn or improper tip. The pressure is created at the tip and pressure will drop as the tip wears. As the unloader/bypass wears, water will bypass at a lower pressure. (Try lowering the pressure regulator all the way ) If water measures less than rated delivery than the machine is bypassing water due to worn regulator/bypass, checkvalves pitted, oring in front of checkvalve worn or cut or missing, or body of pump where checkvalve/oring seat is pitted allowing water to leak past valve. The cap that is removed to access checkvalve must presses against checkvalve with enough force to prevent water from leaking thru oring and body of pump. Examine checkvalves and orings with maginfy lens and look for pitting. Valves surface and orings must be very smooth and tight fitting to work properly. Body of pump where checkvalve oring snuggs against must be very smooth. Any surface where oring seats must be smooth. As water bypasses it cuts metal and orings just like a leaking faucet so look for cuts in metal and rubber. This info and my experience is better suited for larger pumps and higher pressure but maybe it will help. Good luck with your repair.
Jul 11, 2010 | Karcher 2500 PSI Pressure Washer
My washer is leaking from the underneath... I observed a cycle and noticed that the only time it does not leak is when it is draining. It has a slightly increased level of leak when it is filling but it...
The bit you're pointing to isn't meant to have any water in it (and to be honest, probably doesn't).
The leak is probably somewhere nearby, with the water then tracking round the outside of the pump before finally dripping off the lowest point.
There are two approaches to finding the leak.
1. Dry the whole pump assembly really thoroughly, then put some cold water into the machine and (with the power disconnected) carefully feel around the pump body to try to identify what bits get damp first.
2. Use the information that the leak subsides when the machine is draining to narrow your search to the pump suction. Have a careful look at the black bellows (at the right hand edge of your photo), examining all the corrugations for splits and tears. Then check the point where the bellows joins the pump body (the round, creamy coloured object with another hose coming out of it in between your arrowed box and the bellows). Use the dry/cold water/feel around trick to help with these examinations.
A.
May 20, 2010 | Frigidaire Washing Machines
It is leaking water from the bottom as it washes
Plug off the mains. Open up the washer top & behind. There should be a loose or torn rubber pipe. Examine all hoses (pipes), including door seal. Three pipes go from the inlet to soap holder, below the drum you will find a big hose to the filter and pump. If you cannot find anything turn the machine on (keep kids away, locked out). Run the machine without clothes or soap to observe where the leak comes from. You can either tighten the hose, with mains off or replace the hoses. Try sites below for spares with make & model number, depends where u are.
marcone.com
RepairClinic.com
espares.co.uk
AppliancePartsPros.com
mcminone.com
Feb 12, 2010 | Zanussi FJS1225W Front Load Washer
Water leaks from washer after rinse or draining
Hello, the most likely cause is the pump. Whirlpool's and Kenmore's are direct drive machines which means they do not have a belt. The pump is hooked up directly to the motor. To confirm this is the pump tip the machine back so that you can access it underneath. Make sure you wedge something underneath so it does not fall on you. Next take a look where the pump joins onto the motor shaft, this is where you will find the leak. This pump is a sealed unit so you will have to replace the whole pump. You can do this by removing the inlet and outlet pipes. Next with a screwdriver release the 2 clips holding the pump and remove the pump.....reassemble with new pump in reverse order. Good Luck!! If you have any further question's please feel free to comment. Mike
Oct 10, 2009 | Kenmore Washing Machines
Washer is leaking, but I dont know why
Hello, the most likely cause is the pump. Whirlpools are direct drive machines which means they do not have a belt2.gif. The pump is hooked up directly to the motor. To confirm this is the pump tip the machine back so that you can access it underneath. Make sure you wedge something underneath so it does not fall on you. Next take a look where the pump joins onto the motor shaft, this is where you will find the leak. This pump is a sealed unit so you will have to replace the whole pump. You can do this by removing the inlet and outlet pipes. Next with a screwdriver release the 2 clips holding the pump and remove the pump.....reassemble with new pump in reverse order. Good Luck!! If you have any further question's please feel free to comment. Mike
Oct 01, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Leaking from a washer/dryer in condo
Just turn off the water, remove the hoses and unplug it, then bring it out away from the wall. You should be able to tilt the machine and see it from underneath to detect the source of the leak. Also, find how to remove the front of the washer without dimantling the machine and run it without the front panel on there. That is the best way to track down your leak. It could be a seal under the tub, a hose coming from the tub to the pressure valve, a hose from the water pump or the pump itself. The pump is at the bottom, so it will get wet regardless of where it is leaking from. Make sure you dry out everything before you start to look for the leak.
Sep 04, 2009 | Whirlpool Washing Machines
Kenmore 70 Series leaking water from bottom
I used to work for Sears as a home repair technician and washers and dryers were my specialty. Most likely the problem is with your water pump. I ran across this issue many times and what happens is people leave things in their pockets and it destroys the pump. A hair pin or coins, I have even seen socks and under ware get stuck in them causing leaks. What you want to do is tip the machine back and look at the pump. It is located right at the front of the washer with two hoses connected to it. You will want a pair of hose clamps though if you don't want water all over your floor. Disconnect the pump and look inside it for anything causing the motor inside to not work, this will cause slow draining and even leaking. If it looks clear then look for any cracks in the pump. If there is a crack then it needs to be replaced. Just call your local appliance repair place and tell them what you need. Pumps run around 30 bucks or less on average for Kenmore's. If everything looks good on the pump check the hoses that run from the pump and make sure there are no cracks or holes in the hoses. If they look good then the only thing left is the tub and the overflow tube. Chances are though that your pump is what the problem is and it is an easy fix. Good luck.
Jan 20, 2009 | Kenmore 22422 Top Load Washer
Leaking out the bottom of the washer
thanks for the question Tip the washer back to the wall now you can see underneath the pump is right there at the front if you see the pump leaking replace the pump thanks for the question The appliance doc
Aug 03, 2008 | KitchenAid KAWS850L Top Load Washer
Washer leaking some after everything is done washing? why ?
The most common source of leaks from the bottom on a regular basis is a bad pump. Add a little water into the unit. Pull it forward and tilt it back about 45 degrees resting the top against the wall. On the botom center towards the front, you should see a white plastic looking thing. This is the pump and usually where the water leaks from. You can get a replacement on from the manufactures web site or from local appliance parts stores.
May 31, 2008 | Whirlpool GSC9455 Top Load Washer
Fisher and Paykel WL26CW2 Top Load Washer Logo
Top Fisher and Paykel Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
