I've lost my manual to my TDK Flip-down clock radio and I can't remember how to set a station to the station preset's. Can anyone help me?
How do I preset channels on the Nexxtech AM radio Model 1219833?
The most common way to set those buttons is to tune in a station and then press and hold the button down that you want to set it to. It will beep of flash to show you that it has preset.
Jun 18, 2014 | NexxTech Travel Alarm Clock (63-8042)
How do I set the time and alarm on the TDK TA4210BK, I've lost the manual and can't find anywhere to download it from.
Its actually really irritating. You have to turn off all the alarms i.e. so no little bell icons are showing in the display and also turn off the radio i.e it shows OFF. Then, and only then, if you hold down the SET button you will be taken to the time setting menu which starts with a blinking 12H sign. Once in this menu its like any clock radio - you push up or down on the right hand side to select higher or lower numbers and hit SET again to progress to the next feild. You must complete the entire setup menu i.e you must keep hitting SET until you are back at the main screen or it will just forget what you entered go back to whatever it was before you started. Very opaque if you dont have the manual, so I thought everyone else could get 45 minutes of their life back. BTW, the holding down SET with the iPOD in the dock doesnt work for me - its supposed to according to some entries on the web.
Mar 19, 2013 | Timex Nature Sounds LED Clock Radio
How do I set the clock & preset the stations. I bought the radio 5/4 /11 & there was no brochures or warrantee in box.
Setting the Clock 1. Press and hold the CLOCK button until the hour begins to flash 2. Use the left arrow and right arrow buttons to change the hour. 3. Press the CLOCK button again. Use the left arrow and right arrow buttons to change the minutes. 4. Press the CLOCK button again to save.
PRESET Stations the PRESET stations: 1. Tune to desired station. 2. Press and hold the PRESET button until the PRE-SET indicator on the display begins to flash 3. Use the left arrow and right arrow buttons to select the PRESET location for the station. Ten locations (0-9) are available. 4. Press the PRESET button to save the location. To tune a PRESET station: Press and release the PRESET button to step through the PRESET stations.
http://www.northerntool.com/downloads/manuals/142796.pdf
May 06, 2011 | Milwaukee Tool 49-24-0200 AM/FM Radio
Clock is in military time mode. How do I reset to regular? Also I want to preset radio stations and I've lost my manual.
Here is your manual in PDF format:
http://www.bose.co.uk/GB/en/images/Wave%20Radio%20CD_tcm6-4104.pdf
To set AM/PM (12 hour) or Military (24 hour) time - With the system off, hold down Alarm Setup and press On/Off to switch between AM/PM (12 hour) and Military (24 hour) time formats.
To preset up to 6 AM and 6 FM stations - Use the Track/Tune buttons to find the desired station. Then, on the control panel only, hold down any Preset button until the preset number lights. The station is now preset to that number.
Dec 05, 2009 | Bose Wave Radio
Station preset on AWR1-1W bose radio
I found out you tune the radio to the station you want to preset, and hold the preset button (1-6) that you want to assign it to until it beeps. And it's set.
Jan 08, 2009 | Bose Wave Radio
How to pre set satitions
Your Sony is equiped for 5 AM presets and 15 FM presets.
1. Power your unit "ON".
2. Set the desired band - AM or FM.
3. Hold the "Mode" button down no more than one second. The "preset" indication just be gone.
4. Manually tune in the desired station you want to preset.
5. Hold "Enter" until preset indication re-appears. The number of the preset should be blinking.
6. Using the tuning buttons, change the the number to your desired "preset" number.
7. Push the "Enter" button to set the preset.
Remember, you can't have more than 5 AM presets (a mistake I made).
Phil20124
Jul 16, 2008 | Sony Walkman SRF-HM33 AM/FM Radio
Need an owners manual
to set the 5 main presets:
with radio on, use the manual tuner to find station you want on a preset. push and release mem/clock adj button (mem will flash on display), push preset number and while holding it in push the mem/clock adj button again (mem on display will go away). station is now preset to that number.
to set the 5 additional presets:
with radio on, use the manual tuner to find station you want on a preset. push and release the +5 button (+5 will flash on display), push and release mem/clock adj button (mem will also flash on display), push preset number and while holding it in push the mem/clock adj button again (mem on display will go away). station is now preset to that +5 number.
to set the digital clock display:
with radio off, push and release the mem/clock adj button (clock display will now flash), use the tun up / hr part of manual tuning button to adjust hour and the tun dn / min part to adjust minutes.
Apr 05, 2008 | GPX HDT4004SP AM/FM Radio
Setting a Radio Station for Wake Up
You can download the manual from the link below: http://157.254.235.130/public/RP3721%20EN.pdf Please update the question & let us know if the information given was useful to you - Good Luck!
Aug 30, 2007 | RCA RP3721 Clock Radio
Timex T600
Can anyone tell me where to obtain a owner's manual? I bought this clock used.
Aug 07, 2007 | Timex T600 Clock Radio
 Grubhead
Grubhead
