Question about Canon Office Equipment & Supplies
How to configure canon 1133 image runner for wireless usage?
I want to configure the printer to be used wirelessly to print and scan
    Top Expert:
  • Canon Master
  • 44,381 Answers
First you need to setup a wireless network.
Posted on Jan 04, 2015
  • 67 Answers
SOURCE: Canon Image runner C 3200 printer gives error code E000677-0080
your quickbooks file is in the wrong format example tiff or pdf let your it know they can change it to the correct file format
Posted on Aug 19, 2008
  • 168 Answers
SOURCE: Can not scan documents using Canon Image Runner 2200
you need to down load the network scan gear tool www.imagerunner.com support downloads office /production then look for canon network utilities... down load scan gear tool [ not color}this file will have to be unzipped then run it... this will set a program in your program files open the one that says scan gear tool when opens either type in the device ip adress or you can select discover. once you do this you select it as the scanner in your scanning software Adobe Pro etc. you also must select scan on the copier then online before scan will happen
Posted on Dec 17, 2008
old marine
  • 1985 Answers
SOURCE: Using the Canon PIXMA MP240 printer wirelessly
In order to do this, the laptops have to be able to communicate with each other wirelessly. I.e., you have to have a wireless network set up. If you do, then you are "printer sharing", using one laptop as the 'printer server' (with the printer connected to it) and the other as the 'client'. Step by step instructions are available at this link. Type "printer sharing" in the search box in the center of the screen and click on the Search button. Select the option that matches your requirements.
Posted on Jan 12, 2009
  • 135 Answers
SOURCE: Canon IR3035 Print orientation
you set the setting the way you want them, the go to additional functions/common settings/store and that should help
Posted on Apr 19, 2009
  • 3 Answers
SOURCE: Wireless connection for the CANON ip4600
You in a way can but u need to buy a adapter that goes into your modem. apart from that it is possible to sign it into one computer and have it on "share" so that other computers on the same network can still print but for this you need to keep that computer it's connected to on for long periods of time or when you need to use the printer
Posted on Aug 10, 2009
Why does my canon PIXMA 452 say pc not connected when I hit the start scan button
Hi, several things i would be asking
Do you get an error code?
Is the error on the PC or Printer?
Can you print?
How is the Printer connected USB or Wireless
the first is the error code will determine where the fault lies.. if in the 5000 range.. its a hardware problem and would need to be repaired by a service center or repairer.
if you get the printer error.. check the cable or wireless connections
if the PC error it could relate to software you are using to scan too, even if you acquire the correct twain driver (select source).. some are not compatible.. try the scan function in your Canon Utilities IJ Scan Utility. Scan it there first and save it as a PDF or image file.
if you can print its not a connection problem if you cannot print try another USB/printer cable Or make sure your device is setup for wireless run the installation software again and complete the wireless procedures in setup. I hope this helps.. or post me the error code and i can give you a definite answer.. Cheers!
Jun 09, 2014 | Canon Pixma MX452
Can we use MF6550 for wireless network?
If you use a wireless USB print server like this . Keep in mind that you may not get all functions such as scanning to work but it will allow for printing for sure. If the scanning works consider it a bonus.
Jun 11, 2011 | Canon imageCLASS MF6550 All-In-One Laser...
Wondering what I need to print wirelessly from laptop with this printer
If you printer hasn't a built-in wireless connection and if you haven't a wireless router then -
You need a wireless router plus print server. Connect this print server to the wireless router with a LAN cable. Then the printer is then connected to the print server's printer port.
The laptop's wireless card is then configured with the router's wireless settings.
The laptop is then installed with the printer driver and the printer port needs to be changed/configured with the print server's IP address.
ALTERNATELY
If the printer is connected to a desktop computer on your home LAN and it is also connected to your wireless router. Then you can set this printer as A Shared Printer on your desktop computer, but this desktop computer and the printer has to be powered up for the laptop to print to the printer.
For instruction on setting up a shares network printer, please click on this link and follow my instructions :-
http://www.fixya.com/support/r3668797-setting_up_shared_network_printer
Nov 16, 2010 | Canon PIXMA MP510 All-In-One InkJet...
I have canon image runner 3035. I want to know to know how to scan
you can find manuals here:
http://www.usa.canon.com/cusa/support/office/b_w_imagerunner_copiers/imagerunner_2230_2230g_2270_2830_2870_3530_3025_3030_3035_3045_3530g_3570_4570/imagerunner_3035#BrochuresAndManuals
Jul 25, 2010 | Office Equipment & Supplies
How do i set up my wireless canon printer to my laptop? I keep getting messages saying can't find the printer.
Difficulty: Moderately Easy
Instructions
Things You'll Need: · Wireless print server
· USB printer
· Ethernet cable
· Computer
1. Step 1
Obtain a wireless print server that is compatible with both your wireless network and your printer. While the printer’s documentation may not explicitly say that it is compatible with a print sever, many are compatible, and this can be verified by checking the website of the print server’s manufacturer. If you have a multifunction printer, only the print function will work with most wireless print servers, though a few have recently added support for scanning and the printer’s other functions.
Step 2 Read all of the documentation that came with the wireless print server. The manual will detail the specifics of the installation routine.
Step 3 Connect the printer to the wireless print server via the USB cable. Connect the print server’s Ac adapter and turn the unit on.
Step 4 Connect an Ethernet cable between the wireless print server and your computer. This will be used for the initial setup only.
Step 5 Insert the CD supplied with the print server into your CD-Rom drive. Start the software if it does not start automatically. The application will walk you through the installation process, which includes setting the unit’s IP address, setting an access password, configuring it to connect to the wireless network, installing the drivers that allow the print server to use the printer and installing the print drivers on your computers.
Step 6 Choose how your print server will be addressed. Most units are set up to use dynamic addressing by default, which means that your wireless router will assign an IP address to it. This allows the server to be easily installed on the network, but it also means that the IP address of the printer may change over time. The other option is to assign a static IP address to your print server. This option is more reliable, because the print server will always use the same IP address, making it easier for the computers to find the printer and easier to access the print server’s online configuration application. If your router has the IP address of 192.168.0.1, for instance, set the print server to something like 192.168.0.2 or 192.168.0.3, as long as another device does not use that address.
Step 7
Set a password to be used to access the unit’s online configuration application.
Step 8 Configure the print server to access your wireless network. Give it the same SSID network name as your router and set it to use the same wireless channel. If encryption is used on the router, enable encryption on the print server, and enter the encryption key or password.
Step 9 Follow the instructions given by the print server’s software for installing printer drivers on the unit.
Step 10
Disconnect the Ethernet cable and allow the unit to connect via the wireless network.
Step 11 Install the printing drivers on each computer that will use the printer.
Step 12 Access the print server’s online configuration application to verify all settings by entering the IP address of the unit into a web browser, using the “http://192.168.0.2” format. Enter the administrator name and password.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Mar 21, 2010 | Canon PIXMA MP600 all-In-One InkJet...
Is a canon Pixma MP160 a wireless printer? I would like to make my printer which I now use a usb cord and make the printer a wireless connection instead, and I cannot find in the manual if it is wireless...
Per the information found here, it is not a wireless printer.
If you purchase a wireless print server (similar to a wireless router), you can connect just about any USB printer to it (which would be practically the same as having a wireless printer).
Some wireless print servers that support USB have a maximum of 2 USB ports and 4 or 5 network ports.
The only problem is the additional effort it takes to configure everything to work properly.
Good Luck!
Jan 25, 2010 | Canon PIXMA MP160 All-In-One InkJet...
What are my options to configure Canon i850 for wireless printing
Hi
I looked at the specs of you printer and it does not support ethernet/ wireless connectivity your best bet would be to connect your printer to your router with usb cable that's if your router supports it else you can buy what they call a wireless print server and connect wirelesly to your router or pc
Nov 17, 2009 | Canon i850 InkJet Photo Printer
94 people viewed this question
old marine
old marine
