Remove error E00732-0001 - Office Equipment & Supplies
    Master:
  • 551 Answers
If its canon copier then you have difficulties on the FFC cable from Reader-con PCB to Main_con Pcb/reader relay pcb. Cross check.
Thanks.
Posted on Dec 25, 2014
Error code e1 showing at xerox pro 420? solution..
rror codes If the printer's front panel displays a message Error XX, find the error code in this table and follow the instructions for resolving the problem. If problems persist, check the Xerox web site www2.tek.com/TekSMART/ or contact service.
Error User Corrective Action Error 01
  • Remove and re-install the black Toner Cartridge, then turn the printer off and on.
  • Replace the black Toner Cartridge, then turn the printer off and on.
Error 02
  • Remove and re-install the cyan Toner Cartridge, then turn the printer off and on.
  • Replace the cyan Toner Cartridge, then turn the printer off and on.
Error 03
  • Remove and re-install the magenta Toner Cartridge, then turn the printer off and on.
  • Replace the magenta Toner Cartridge, then turn the printer off and on.
Error 04
  • Remove and re-install the yellow Toner Cartridge, then turn the printer off and on.
  • Replace the yellow Toner Cartridge, then turn the printer off and on.
Error 05, 10, 11,12, and 13
  • Turn the printer power off, then on.
Error 20
  • Remove and re-install the Imaging Unit (make sure that Imaging Unit is locked in place). Turn the printer off, then on.
  • Remove and re-install the Main Charge Grid. Turn the printer off, then on.
  • Remove and re-install the Transfer Kit. Turn the printer off, then on.
  • Remove and re-install each of the Toner Cartridges. Turn the printer off, then on.
  • Replace the Main Charge Grid. Turn the printer off, then on.
  • Replace the Imaging Unit (make sure that Imaging Unit is locked in place). Turn the printer off, then on.
  • Replace the Transfer Kit. Turn the printer off, then on.
  • Replace the Toner Cartridges. Turn the printer off, then on.
Error 21, 22, 30,and 32
  • If a problem persists for Error 30, clean the sensor. See Cleaning Phaser 750 Printers.
Error 33
  • Check for jammed paper throughout the paper path (especially in paper feeder).
  • Remove and re-install the paper feeder and Transfer Kit. Turn the printer off, then on.
Error 40, 41, 42,and 43
  • Check for jammed paper in the Fuser. Re-install the Fuser. Turn the printer off, then on.
  • Make sure that you have the correct Fuser for your local printer power supply:
    110-Volt Fuser Part Number 016-1839-00
    220-Volt Fuser Part Number 016-1840-00
  • Replace the Fuser. Turn the printer off, then on.
Error 50, 51
  • Turn the printer off, then on.
Error 52
  • Remove the Duplex Unit (if installed).
  • Check for paper under the Upper Tray.
  • Turn power off, then on.
Error 53
  • Open left door and remove any jammed media.
  • Tun the printer off, then on.
Error 60
  • Remove the media from the Multi-Purpose Tray. Turn the printer off, then on.
  • Reinstall the media. Make sure you do not overfill the tray.
Error 61
  • Remove and re-install each Toner Cartridge. Turn the printer off, then on.
  • Replace each Toner Cartridge. Turn the printer off, then on.
Error 62
  • Check for jammed paper throughout the paper path (especially in the paper feeder and Fuser).
  • Remove and re-install the Fuser. Turn the printer off, then on.
  • Slide out and re-insert the paper feeder. Turn the printer off, then on.
Error 63
  • Remove and re-install the Imaging Unit. Turn the printer off, then on.
  • Replace the Imaging Unit. Turn the printer off, then on.
Error 70, 71, and72
Error 73
Error 74
Error 80, 81, 82,83, and 84
  • Make sure that all four toner cartridges are installed in the printer.
Error 01p through
Error 47p
  • Make sure that installed memory DIMM(s) are compatible with printer's image processor board and that they are installed in the proper slot(s).
  • you can helpful
Oct 09, 2014 | Xerox Phaser Office Equipment & Supplies
How can i remove zynga poker error code RS1
how can i remove zynga poker error code RS1 zynga poker error code RS1 eror code rs1 i have the same problem,.
May 09, 2012 | Zynga Texas HoldEm Poker
How to remove error code (E000004-0010)from canon iR-6570 photocopier?
gmana ya cara benerin error e000004-0010 pada mesin canon ir6570
Jul 07, 2011 | Canon Office Equipment & Supplies
HP Color LaserJet 3800 dtn printer. Error message says 49.4C06 Service Error
49.XXXXX ERROR A critical firmware error has occurred.
If the message persists with different programs and print jobs, turn the printer off.
Remove all memory DIMMs or thirdparty DIMMs from the printer. (Do not remove the firmware DIMM in the lower slot J1).
Remove the printer EIO card.
Turn the printer on.
If the error does not persist, install each DIMM and EIO device one at a time.
Turn the printer off and then on again after installing each device.
Replace DIMMs and EIO devices as necessary.
If the error persists, replace the firmware DIMM.
If the error persists, replace the formatter and calibrate the printer.
Jun 16, 2011 | Office Equipment & Supplies
Hp color laserjet 3000dn getting 49.2 FC6 service error. not printing magenta. got new magenta toner - did not resolve. please advise
Any 49.xxxxx error is a critical firmware error
If power cycling the printer doesn't clear the error, try printing from a different program.
If it works, go back to the job that failed. Print. If the error comes back, that program is hosed.
If the error persists remove the network cable and any cable that goes to the computer.
Remove the JetDirect. Power on. If error is gone, power down and reinstall the JetDirect. Power up. If error is gone, chalk it up to reseating. If error comes back...replace the JetDirect.
If the error continues with the JetDirect removed, there could be a bad memory DIMM or formatter.
Good Luck
May 27, 2011 | Office Equipment & Supplies
Error e527 have manually removed all cartridges and replaced them and the PCU but the error code persists
Error E527: home position sensor error
Solution:
  1. open the left cover
  2. remove the home position sensor
  3. clean it ( remove the toner)
the home position sensor is shown at this picture: mabroukmedal_32.jpg
Dec 09, 2010 | Epson Aculaser C1100 Printer
Error 79.00FE
In order to fix the 79.00FE printer error, first you have to print a configuration page. Then remove the jet direct and power on while holding the go button down on the printer. After display reads offline, the reset process is complete. After the cold reset, remove the jet direct card and see if the 79.00FE error goes away. If the 79.00FE error appears before a job is sent then it may be the DIMMS, try removing them to see if the error persists.
Dec 08, 2010 | HP LaserJet 5100dtn Printer
It says a printer error has occured. If you turn off and start again nothing happens
• To resolve this issue remove the cartridges and then the printhead (To remove the printhead: Upon removing the cartridges push the small grey tab upwards.)
• Remove power
• Please now check for any objects or paper that might be obstructing the movement of the printer carriage - if any are found please remove them
• Wait 5-7 minutes
• Reinsert power
• Reinsert printhead (When inserting the Printhead please ensure that you hear it click into place)
• Then re-insert cartridges, black first then colour.Please also ensure that you hear them clip into place
• If the error persists, please advise us on where the error appears and what the exact wording of the error is along with any error lights.
May 15, 2010 | Office Equipment & Supplies
My printer has an error code: 49.3C1A Service Do you know what that means?
Hello my friend, try this.
Check the printer queue and delete the file(s) with the
error. Wait until it show that it was cleared. Turn off the printer and remove the network cable. Turn on the printer to see if the error is removed. If so, turn the printer off and reconnect the cable and turn back on. Reprint the file that had the error. If you get the error again, the file is corrupted or there is something about the file that the printer does not understand.
If the error is not removed after the above procedure, there could be a hardware issue. Remove the JD card and any hard disk and power back on to see if you still get the error. If so, and with both the JD and HD removed, do a cold reset.
Feb 12, 2010 | HP LaserJet 2420 Printer
k24674
