Question about Kenwood KR-X1000
How to connect spekers
No sound
    Novelist:
  • 176 Answers
If it's your first time in this project, connecting speakers are not simple but you can learn fast. First of all, I don't know the type of speakers you have. Not all speakers are the same, even in sound they're not the same. Some sound superb, others sound just right and many sound like tin cans. Because you have a Kenwood KR-X1000, it looks like you have large speakers. To connect these large speaker you need high quality speaker cables, not cheaper low amp types. Cables for speakers are usually marked with a continuous colored line along one side the cable. This line is an orange color is the cable is 100% copper and is a clear plastic cable (you can see the braided or twisted wire inside), or it could be black plastic with a white or grey colored band on one side of the cable. The colored bands means it's positive side (+). Split the cable ends then splice about half inch and twist the exposed wire. If you have a soldering iron, solder the exposed twisted braids to make it into a single solid wire for easy insertion into the speakers.
Now, I don't know what speakers you have but it doesn't matter, as long as you are aware that there are three types of connections used to connect the wires to the speakers. One type is a snap-on, another type is a squeeze, insert the wire in and let go. This is like a clamp. Another type is the a bolt type with a hole in the shaft of the bolt. The head is usually a plastic but to hold the wire and it is the strongest. Let's say you have the bolt type used by many professional speaker makers and users. You simply unscrew the plastic nut until the hole is open, then insert the wire in the hole then screw the plastic nut back tight. do a light pull test to see if the wire might slip out. Remember that these speaker connectors are colored red and black and the wire with the colored line on sheath is positive, that is it goes into the red connector. Then on the other end of the cable bet some tape or a tie to say this is the left speaker and this is the right speaker, this is the rear speaker and this is the right speaker, so that when you connect them to the Kenwood, you will not have to check which cable goes where.
The same thing goes with the Kenwood wire connection. I am a Pioneer man, I know them well. But I just happen to know that Kenwood and many others are very similar in wire connections because I am close to a store that has these, so, it's easy for me to go there and learn the tricks of trade. However, when I was writing this, it was too late to go down and have a look and the Kenwood X1000. So, I can only say that if you looked behind the machine, you'll find it all easily set and you can't go wrong. The red is positive (+) and black is negative (-). If you have been able to wire the speakers as instructed above, then you are also able to wire the Kenwood amplifier. Split the cables and strip or splice a half inch to expose the stranded wires the twist them and solder to form a solid wire for easy insertion and to stop the little copper wires in the braid from separating themselves from the twisted group. Then insert the colored line of the cable into the positive (red) clamp, clip-on, or screw type connector, whichever your amplifier has. Insert the negative soldered wire into the black clamp, clip-on or screw type connector. Do the same with the others speakers wires, recheck the connections, paying attention to polarities and test. It should work without problems. Cheers.
Posted on Feb 03, 2015
Audio on aux device
Connect a 3.5 mm (1/8 in) cable
from the auxiliary device to the
auxiliary input jack. When a
device is connected, the system
automatically begins playing audio
from the device over the vehicle spekers.
Mar 11, 2016 | 2012 Buick LaCrosse
I can not turn the tv spekers
suspect a issue with the socket where the headphones connect to the set---when inserted it should cut speaker sound off---often a loose connection.
Jul 17, 2012 | Mitsubishi Televison & Video
How to hook the 3490 to get 4 ohms
Hello
The output impedence of the amp is 8 Ohms. It can also be connected to a 4 Ohms speaker, but the reted output will be higher than specifed, and the sound quality will be reduced. You cant get an putput impedece to this amp by no means, as its' output is desigend to match 8 Ohms/channel. If you have only spekers with 4ohms impedence, connect two of the in serieal connection, so that, they together will reach a resultant impedence of 4Ohms. Similarly connect an other two spekers in series to the other channel too. OK.
Dec 24, 2011 | Harman Kardon Audio Players & Recorders
When conect speaker, the original tv speaker sound are off
Hello
You are connecting external speaker from your TVs headphone socket I thinks. It is quite normal that the internal speker will cut off when external a headphone is connected to the headphone socket. OK.
Jan 28, 2011 | Televison & Video
Lux Audio 5.1 home theater speaker & Yamaha HTR 5540 AMP
configure ur PC (both OS audio and third party sound driver) for surround sounds. control panel- sounds and audio devices - speaker settings - advanced - speker settings. so this done. make sure u select the 6 input channel - the button is on the right edge near the volume knob. near the vol button there are two buttons for selecting input type with up down arrow. from that u can select the input type this will be indicated on the top front indicator. but with the 6 input channel selected all selections are preceeded. if u select stereo mode u will have left/ right audio only.
make sure u connect the input right. connect from computer to 6 channel input. main, surround, center and sub-woofer.  connect the spekers to main (L/R), rear(surround) (L/R), center and sub woofer to terminal marked sub woofer ouput. this done select like i said before the 6 channel button. that should do it.
Mar 13, 2010 | Yamaha HTR-5540 Receiver
No sonud of the speker
have you properly installed d driver?if not try to reinstall the driver.. if it is installed then you can see a speaker emblem on the right bottom of the screen.
May 17, 2009 | Computers & Internet
Creative spekers
SoundCard SoundBlaster Audiby Model SB 0570
Creative CA0106-WATLF
Creative Tech '02 A120070620
Apr 12, 2009 | Creative Labs Sound Blaster Live! 5.1...
Problem about sound
i am using same configuration with 5.1 creative speaker with good sound. in 5.1 sound system there are 2 seperate jack for left and right speaker. you attach one adopter having 2 in and 1 out point.The jack is 'Y' shaped. that will solve ur problem.
Nov 25, 2007 | Intel D915GAV Motherboard
Onkyo Amp
Set your input to the amp at mono.Then check levels again.If it is still low you have a prob w/amp circuitry
Oct 16, 2007 | Onkyo TX-SR604 Receiver
Kenwood KR-X1000 Logo
73 people viewed this question
Top Kenwood Audio Players & Recorders Experts
 Grubhead
Grubhead
da surgen
Are you a Kenwood Audio Player and Recorder Expert? Answer questions, earn points and help others
