Ctv19402 circuit (kalinger portable tv circuit
    Top Expert:
  • Televison & ... Master
  • 74,198 Answers
What is the problem you faces with this Tamil Nadu Free TV? Provide more details; please.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Posted on Dec 15, 2014
How to determine if a plug on the back of a TV is good
Have you checked for a cracked circuit board. Very minor cracks in a circuit board may cause a break in the circuit when the boards are flexed slightly. Loose solder joints will also cause problems when boards are flexed or stressed when screwed tightly etc.
Oct 09, 2016 | Vizio E701I-A3 70-inch LED-backlit LCD TV...
I can't get a picture on my Roadstar LCD8082D TV
The TV has two main sections One is the Audio component. And 2 is Video section. Since they are Separate and not dependent on one another with the exception of synchronization; (matching Voice to the Video), one section may work just fine. The other non-working section in your case is the Video. Over time various internal parts age and wear out from use or hot/cold. In the Video section a series of Capacitors, resistors, diodes, and transistors on a circuit board make up the Video portion of the TV. One or more of these electronic parts are going bad or totally defective. The only solution is a replacement circuit board. Do not waste your money on repairing a circuit board. If you cannot obtain a replacement circuit board, then the Road-star is now a Road Accor.
Dec 22, 2013 | Roadstar LCD7310 7 in. Portable TV
I have a dvd player and it want come on anymore...its portable
It's virtually impossible to analyze a TV's circuits via internet. RCA's were famous for defective electrolytic capacitors, cold solder connections, tuner problems and power supply/deflection circuit problems. Any or all of these problems could be factors in your TV's demise. The only solution I see is in the hands of a experienced repairman or you could try locate the caps your self and buy the correct caps then soldered them on hope this helps.
Aug 27, 2011 | RCA DRC629N Portable DVD Player
Craig 7 inch lcd tv with dvd player is sold as DIGITAL meaning it will pick up digital tv signals with a tuner or antenna like my old tv at home with a converter; right?\r\nCan get no signal on tv...
The word "Digital" means, that device have digital processor circuit inside, which uses only for signal processing. Not mean that it will pickup digital signals. You did misunderstand that word. That's all.
http://electrotechnician.blogspot.com/
Jul 13, 2017 | Televison & Video
Ijust get a light screen!! no sound, no menu, no nothing
Internal capacitors have probably gone bad (bulged and leaked) and therefore there is nothing that can be done short of soldering new caps into place, and hoping the old one's didn't damage anything else on the circuit board. Recommendation: replace it.
Oct 13, 2010 | Haier LCD258 2.5 inch Portable Color TV...
TV Remote Stopped Working
remote senser on TV chassis needs to be replaced
they go bad alot.
Feb 15, 2010 | Philips PR0930X 9 in. Portable Television
TV DOESN'T GET SIGNAL
This may be a tuner failure, or a fault in the AGC or IF circuits. This may not be cheap to service unless it is a simple cold solder connection on one of the circuit boards in the mentioned areas.
Jerry G.
Apr 07, 2008 | Televison & Video
HYUNDAI COLOUR TV HCT3740 (37CM)
No vertical is always an affordable fix.
- failed (dried out) electrolytic caps in the vertical circuit
- failed vertical IC
- failed power to the vertical circuit.
Hope Ya Fix It
Feb 07, 2008 | Televison & Video
120VAC dead
There should be a small fuse on the circuit board inside the tv. Sometimes the fuse is soldered direct to the board and not in a holder. Hope this helps you,,, Mechanic
Jan 18, 2008 | Sony KV-9PT20 9 in. Television
Sound works, picture is very dark
You have to be specific when asking a question please. as you dont mention its a flodable LCD screen TV as I had to look it up. your problem is in the backlite circuit. if your a tech, you should have no problem finding this fault but could be a little trick if your not as your going to need to know how a back light circuit works, the parts in the circuit and know how to use a multimeter. Good Luck
Aug 25, 2006 | Polaroid FCM-0700A 7 in. Portable...
Televison & Video Logo
179 people viewed this question
Top Televison & Video Experts
Electro Med Services...
