Question about Garden
Gas line diagram for xl chainsaw homelite - Garden
  • Eugene Rounds Dec 15, 2014
    Hi Steve l Chrisman, I want to help you with your question, but I need more information from you. Can you please add details in the comment box? Need the UT- number to look-up the IPL.
  • 7 Answers
Find the UT # and go to partstree web page.
Posted on Jan 04, 2015
  • 42 Answers
SOURCE: On a homelite chainsaw model d3300 i have all fuel
The line that hooks up at the front of the carb (#17 in picture) goes to the fuel tank. the line that hooks up at the rear of the carb (#18 in picture) goes to the primer bulb. Hope this all helps. Let me know. thanks.
convert?ilfn=d%3a%5cempartweb_52%5ccatalog%20data%5cemp_img%5chcp%5cimages%5c06%5c01%5c13%5c0007.tif&ilsc=12&iliv=0&ilbr=0&ilif=p&ilre=8
Posted on Mar 15, 2009
slohry
  • 87 Answers
SOURCE: homelite cs3314 chainsaw
Here is a link to get you your parts list. Make sure you have your UT#
http://odref.com/homelite/chainsaw/index.html
Posted on Apr 09, 2009
SOURCE: Need diagram for fuel lines on craftsman chainsaw
There is two sizes of line. I see the large one goes to the large port on the primer button and then to the fuel tank. The small one goes from the primer button to the carb. The problem is there are two hose connections on the carb. I believe one is a vent, but I am not sure what one it is. I have a 36cc 2-cycle model 358.352161
Posted on Jun 22, 2009
dontbother10
  • 2220 Answers
SOURCE: my homelite chainsaw model# ut10520 has aoil leak
I input your model number and found 3 possible matches, "42cc/46cc Chain Saw UT-10520; SUPER 2 Chain Saw UT-10520 or SUPER 2 Chain Saw UT-10520-A".
I opened the first "Ref # 3" on "Figure A" I suspect is what you say is leaking. It is very inexpensive and available. I would order one and inspect it once recieved to determine an installation method. It does not appear overly difficult without the part in hand. Good Luck.
Homelite/Ryobi.com (authorized parts supplier)
https://www.gardnerinc.com/recons/disclaimer-lg.php - Agree; Choose “Product Line”; “Select OEM” & “Select Catalog” both to “Homelite Consumer Products”. A drop down list appears; self explanatory from here.
The numbers Homelite & Ryobi use do not match the numbers everyone posts. A careful inspection of your saw should find something that matches.
If you have more questions or need additional help please reply below and I will get back to you. HTH & Good Luck.
Lou
Thank You for using FixYa.
Posted on May 07, 2010
SOURCE: Primer bulb is part of the fuel cap.
I have a Homelite Super 2 chainsaw that has a hole in the primer bulb on the fuel cap...will not prime. Where can
I find a replacement primer bulb fuel cap?
Posted on Jul 02, 2011
I need to remove the automatic oiler in my homelight chainsaw z3850b
Chainsaw Oil Pump Replacement - Homelite ... - YouTube
? 5:57
https://www.youtube.com/watch?v=8dj0Voh3TTM
Jan 21, 2014 - Uploaded by RepairClinic.com
The most common reason for replacing the oil pump is ... ...Chainsaw Oil Pump Replacement - Homelite Chainsaw Repair (part #309514001) ... spark plug wrench, cord, clutch removaltool, adjustable wrench, needle-nose pliers ... The chainsaw guy shop talk Repair Homelite 150 chainsaw Auto Oiler ...
How to Repair a Homelite XL Chainsaw Oiler - Home Guides
homeguides.sfgate.com > Real Estate Advice > Basic Real Estate Advice
The Homelite XL chain saw is designed to use one tank of oil per each tank of fuel. Fill the oil ... Push the guide bar toward the saw, and remove it and the chain. Clean the ... Automatic Oiler and Oil Line Replacement ..... My Ridevisit'Cars-My
Dec 21, 2015 | Garden
Homelite chainsaw fuel line diagram
need a fuel line diagram for a homelite 330 chain saw
Oct 05, 2013 | Homelite Garden
Exploded diagram homelite 104522 chainsaw
This would be something Homelite might be able to provide
Mar 17, 2013 | Homelite Garden
Homelite xl chainsaw won't start. I took out spark plug, put in some fuel and if fired right up. But won't run.
You need to clean out the carb. possibly replace the Needle Valve and check the Diaphram for stiffness. Also check the fuel line for cracks and rott.
Feb 10, 2013 | Homelite Garden
I need a parts diagram of the homelite xl 12 with a ut number of 104564 serial number 790291696.
There seems to be 1 to many numbers in the model # UT104654 is it possible that it reads UT10465A.
If so here is a link to the parts diagram for a Homelite XL12 UT10465A ,
http://www.jackssmallengines.com/help.cfm#/Homelite/XL12_Chain_Saw_UT-10456-A/Engine_Internals/1010129/0609011010046
Aug 06, 2011 | Homelite Garden
Homelite chainsaw gas line diagram witch one goes where have the primer bulb
Take the primer bulb off.Look on the back side of it.Most will say tank and carb.If not try putting them on if the bulb doesen't get gas in it.Change them around.
Feb 27, 2011 | Homelite ZR10926 16" Chain Saw
I have a Homelite XL Chainsaw, What is the recommended gas/oil mix, please? Clive
I have an older homelite that uses a 40 to 1 mix. It is about twenty years old but I think that is what homelite still uses.I hope this helps you. Thanks
Dec 27, 2010 | Garden
What fuel mix does a homelite xl-130 chainsaw require?
the homelite xl-130 gas/oil ratio is 32:1 meaning one quart of gas and one oz of 2 cycle engine oil or one gallon of gas and and one 4oz bottle of 2 cycle engine oil.
Best,Regards
obliqueridge
Nov 10, 2010 | Homelite Garden
Garden Logo
55 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
