Pansonic led tv flashing 7 times - Televison & Video
    Top Expert:
  • Televison & ... Master
  • 21,561 Answers
Repair kit is required as the SuS power supply has failed.
Posted on Dec 15, 2014
Testimonial: "whats this?"
TV switches off and red LED flashes 7 times
Your user manual should have a troubleshooting section which will tell you what the flashes mean. If you no longer have a manual, you can possibly go on line. Do a google search for your TV model number, manual... or go to manufacturers website. I hope this helps.
Mar 31, 2014 | Televison & Video
Sir I hava a plasma television Pansonic TH-42PV70M and the display cracked during transport. Any solution to repair. The pansonic agent in India,s Engineer comment is not possible to repair because 90%...
The tech from India is fairly correct. Newer TV's (LCD, LED, Plasma) have most of their cost in the screen. In fact most companies will straight up replace a broken panel TV rather than fix it because its more cost effective. I would advise you do the same and get a new TV. Sorry for the bad news!
Jul 19, 2011 | Televison & Video
My pansonic th-50phw3 turns on the LED indicator blinks several times then the tv shuts down
Count the number of blinks and let me know so I can help you. It should blink X number of times at about 1 second intervals, pause 3 seconds and repeat. Give me the number and I will see what I can do.
Thanks for using FixYa.
hardrocko
Apr 16, 2010 | Televison & Video
Philips 42PF7220A/37 42'' TV (LED flashes red 7 times)
Five buck solution; If you have any tek skills at all and are feeling adventurous; UNPLUG THE POWER, remove the back panel; You will be faced with the mainboard. In the lower right quadrant you will see two small capacitors, like tiny yellowish coke cans. If these are bulging, there lies your problem. These must be replaced. If you have no soldering skills, take only the mainboard to a fixit shop and have them solder in the two capacitors easily found on line. No guarantee's but worth a try
Dec 06, 2008 | Televison & Video
TV does not turn on/red led flashes 7 times in front
this is common issue with this model and through your troubleshooting is tied to y main board. blinking led on logic main in normal operation. when replacing y main always good idea to replace y upper and lowe buffer boards as they complete a circuit and sometimes replacing one without other could cause additional failure on remaining boards
Aug 10, 2008 | Philips 42PF7320 42 in. EDTV-Ready Plasma...
TRYING TO PROGRAM A RCA UNIVERSAL REMOTE TO WORK WITH A PANSONIC TV. THE RCA UNIVERSAL REMOTE MODEL# IS RCR4258 I NEED THE DIRECTIONS AND CODES TO WORK A TV ONLY
http://www.hifi-remote.com/ofa/codes-tv.shtml#tv
If none of the codes work then we have two other solutions:
1. Searching For Your Code
If you have tried all of the set-up codes for your brand of equipment ,or yourbrand is not listed, and you are still not able to get the unit to respond, trythe following procedure to search for your code.
If you don't find a code that works, the remote will flash four times when youreach the end of all the codes for this device type.
  1. PRESS the button for the device you want to program, (TV, VCR, CABLE, etc.), then RELEASE.
  2. PRESS and HOLD the SETUP button until the red LED flashes twice, then RELEASE.
  3. ENTER 9-9-1 (two blinks on the remote)
  4. ALTERNATE slowly between the POWER key and the DEVICE (TV, VCR, CABLE, etc.) button until your device turns off. (On VCR, LD, and CD players use PLAY instead of POWER)
    Make sure that the remote is pointed at your device during the search, You may have to press this sequences of buttons up to 100 times to search the entire library of codes.
  5. When your device turns OFF, PRESS the SETUP button and RELEASE it to lock in the code for your device.
2. Learn the buttons from the original
Line up your original remote and the head-to-head before completing thefollowing steps.
  1. PRESS and HOLD the SETUP button until the red LED flashes twice.
  2. PRESS 9 - 7 - 5, the red LED will flash twice.
  3. PRESS the DEVICE key where you wish to learn the function. The next 3 steps must be completed within 10 seconds.
  4. PRESS the button that will receive the learned function, the LED will flash rapidly.
  5. PRESS the button on the original remote to be learned.
Now you can repeat steps 3 through 5 to learn other functions onto other keysor press and hold SETUP until the Cinema's red light flashes twice to lock inyour new feature. (If the red light does not blink twice, stop and repeat stepsthrough 6).
To test the new feature, press and release the device key in which the newfeature was learned followed by the key on which the feature was learned
More help for programming your remote can be found here:
http://www.hifi-remote.com/manuals/ofa-l.shtml?URC-7800#device
Hope that helps! Should you have any further questions,please feel free to post them here.
Television Video - DVD Audio Satellite Set Top Box Video - VCR Brand: Model (optional): clip_image001.gifclip_image001.gifWe could not find an exact match, we think this code will work. 10054 clip_image001.gifclip_image001.gifSetup Instructions
· Set the "Mode Switch" to TV.
· Press and hold the "Mute" button and the "Select" button until the visible LED blinks twice.
· Enter the 5 digit Code above.
· Try your new code and tell us how it worked!
You'll have to settle for that, use the middle power key in the tv device to power on & off the tv.
hope this may help;
Regards,
VOTIT
DON'T FORGET TO RATE;
Jul 22, 2008 | RCA Universal Remote Control
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
