Question about Samsung Computers & Internet
Completely re-boot a Samsung NP74OU3E Ultrabook
There is no CD drive, and the computer did not come with a USB re-boot flash drive..
    Top Expert:
  • Samsung Master
  • 23,678 Answers
If you mean to reload the software. Download an ISO of your system software, save it as a bootable USB and start the Samsung from the USB stick. When installed download all drivers from Samsung and you will have a fully functioning system again.
Posted on Dec 15, 2014
Need to put system recovery disc's 2 disc set on flash since dvd drive has quit on me.
http://www.computerhope.com/issues/ch001366.htm
How to create a bootable Windows USB drive. A common use of a bootable USB flash drive is to use it to boot into Windows. Booting from removable media such as a USB drive allows you to perform diagnostics on a computer that is having trouble booting from the hard drive. You can also use the flash drive to install Windows, instead of using the Windows installation CD.
This guide will outline making a bootable USB flash drive with Windows XP, Vista, or 7. Before we begin, it is important to note that the computer you want to use your bootable USB drive must be able to use a USB drive as a boot device. Most computers built since Windows Vista was released are capable of booting to a USB device. Prior to the Windows Vista time frame, it is hit or miss with motherboards.
To determine if a computer is capable of booting to a USB device, access the computer's BIOS and check the bootable device list. If a USB device is listed, set the USB drive to be the first boot device. If you do not see a USB device in the list of bootable devices, your BIOS is not capable of booting to a USB device.
Note: You may need to have your USB flash drive plugged in when you access the BIOS).
Windows Vista and Windows 7 users To make a bootable USB drive for Windows Vista or Windows 7, you need to have Windows Vista or 7 installed on your computer. It is recommended that you have a flash drive of at least 4 GB in size, to store all the necessary files.
Tip: Before you start, plug in the USB drive and backup any files you have stored on the USB drive. The drive will be formatted during this process and all files on it will be deleted.
Note: You need to have a Windows Vista or Windows 7 DVD for these instructions to be successful.
1. Open an elevated Windows command line window by clicking Start, typing in cmd in the search text field, then pressing CTRL + Shift + Enter on your keyboard (at the same time). You can also access this by navigating to Start, All Programs, Accessories, right-click with your mouse on the Command Prompt menu item and select Run as Administrator.
2. At the command prompt, type cd c:\windows\system32 to change the directory to the Windows system32 directory. Ensure your USB drive is plugged in, type DISKPART, then press Enter. Type LIST DISK and press Enter.
3. You will see a listing of the disk drives connected to your computer. Find the disk number of your USB drive and type SELECT DISK [USB disk #], where "[USB disk #]" is the disk # for your USB drive. It should now state that your USB drive is the selected disk. If you're not sure what disk is the USB disk, eject the USB drive, perform step number 2 again, connect the USB drive again, and compare the results. Usually the USB drive will be the last drive.
4. Type in the following commands, one by one, pressing Enter after each command.
CLEAN
CREATE PARTITION PRIMARY
SELECT PARTITION 1
ACTIVE
FORMAT FS=NTFS
(may take a couple minutes, depending on the USB drive size)
ASSIGN
EXIT
Keep the command prompt window open, but you can minimize it for a little bit.
5. You will now need your Windows Vista or 7 Installation DVD. Put the DVD in your computer's DVD drive. Open up My Computer and note which drive letter is assigned to your DVD Drive and your USB flash drive.
6. Go back to the command prompt window and type in D: CD BOOT (substitute your DVD drive letter for "D:", if necessary) and press Enter. Type CD BOOT again and press Enter. Lastly, type BOOTSECT.EXE /NT60 H: (substitute your USB flash drive letter for "H:", if necessary) and press Enter.
7. The last step is to copy the entire contents of the Windows DVD to your USB flash drive. To do this, in the My Computer window (opened in step 5 above), right-click on the DVD drive and select Open to view the contents of the DVD. Copy all the files and folders on the DVD to the USB flash drive.
Your USB flash drive is now set up to be a bootable USB drive for Windows Vista or 7.
How to or can boot from CD or DVD
Good luck.
Jan 12, 2016 | Compaq Presario CQ60-220US PC Laptop
Tip
Tiny Core Linux Guide for survival (Live Linux) CD USB flash
Tiny Core Linux is a live linux distribution,
less than 10 MB runs completely in memory
and can be booted from a CD-ROM or a USB flash drive.
(This minimal desktop can be extended
by installing additional applications from online repositories)
1) How to put Tiny Core Linux on the CD
1.a) Download Tiny Core Linux
http://distro.ibiblio.org/pub/linux/distributions/tinycorelinux/2.x/release/tinycore-current.iso
1.b) Tiny Core Linux is distributed as an ISO image.
It is necessary to burn it to CD
using the option of your program to burn CDs
Burn CD ISO image (Windows - Nero / Burn Image to Disc, for example)
1.c) Then you need to restart your computer.
1.d) Depending on the options your motherboard,
it is necessary when starting
your computer keyboard press:
F8 or F12 or Esc, etc..
Thus you will appear a menu where you choose your CD drive.
After
Tiny Core Linux menu comes before you.
2) How to put Tiny Core Linux on a USB flash drive
2.a) Download Tiny Core Linux
2.b) Format the USB flash drive in the FAT32 filesystem. (Windows)
(MyComputer, right click on your USB flash drive, Format, File System = FAT32, start)
2.c) Download and run UNetbootin for Windows
to create a bootable Tiny Core Linux USB Flash Drive
http://unetbootin.sourceforge.net/unetbootin-windows-latest.exe
2.d) Then you need to restart your computer
Depending on the options your motherboard, it is necessary when starting
your computer keyboard press: F8 or F12 or Esc, etc..
Thus you will appear a menu where you choose your USB flash drive.
After
Tiny Core menu comes before you.
3.) You can start using your Tiny Core Linux easily
on Jan 24, 2010 | Computers & Internet
Tip
XPUD Linux Guide for survival (Live Linux) CD USB flash
xPUD Linux is a live linux distribution,
less than 64MB runs completely in memory
1) How to put xPUD Linux on the CD
1.a) Download xPUD Linux
http://xpud.googlecode.com/files/xpud-0.9.2.iso
1.b) xPUD Linux is distributed as an ISO image.
After
xPUD Linux menu comes before you.
2) How to put xPUD Linux on a USB flash drive
2.a) Download xPUD Linux
2.c) Download and run LiveUSB creator for Windows
to create a bootable xPUD Linux USB Flash Drive
http://unetbootin.sourceforge.net/unetbootin-xpud-windows-latest.exe
After
SliTaz menu comes before you.
3.) You can start using your xPUD Linux easily
ThinkPad Helix 3701 not booting from USB
Did you configure the usb device as an ISO? Win8 won't like to downgrade, it will do its best to protect itself with the hidden partition.
Dec 19, 2013 | Lenovo 37012QU - ThinkPad Helix 3701 -...
Get this message upon boot up of samsung ultrabook: z:\WinClon\Manager1.exe The system cannot find the drive specified.
Sounds like u got a virus. My suggestion is don't open up any mail or any sites that your not sure of.
Oct 13, 2013 | Samsung 900x Ultraportable Laptop...
Tip
Damn Small Linux Guide for survival (Live Linux) CD USB flash
Damn Small Linux is a live linux distribution,
less than 50MB runs completely in memory
(Because all the applications are small and light
it makes a very good choice for older hardware.)
1) How to put Damn Small Linux on the CD
1.a) Download Damn Small Linux
ftp://ibiblio.org/pub/Linux/distributions/damnsmall/current/dsl-4.4.10.iso
1.b) Damn Small Linux is distributed as an ISO image.
After
Damn Small Linux menu comes before you.
2) How to put Damn Small Linux on a USB flash drive
2.a) Download Damn Small Linux
ftp://ibiblio.org/pub/Linux/distributions/damnsmall/current/dsl-4.4.10-embedded.zip
2.c)Download and run USB Installer for DSL
to create a bootable Damn Small Linux USB Flash Drive
http://www.pendrivelinux.com/downloads/DSL/USB-Installer-For-DSL-v0.2.exe
After
3.) You can start using your Damn Small Linux easily
on Jan 23, 2010 | Computers & Internet
Tip
SliTaz Guide for survival (Live Linux) CD USB flash
SliTaz Linux is a live linux distribution,
less than 32 MB runs completely in memory
1) How to put SliTaz on the CD
1.a) Download SliTaz
http://mirror.slitaz.org/iso/cooking/slitaz-cooking.iso
1.b) SliTaz is distributed as an ISO image.
After
2) How to put SliTaz on a USB flash drive
2.a) Download SliTaz
2.c)Download and run tazusb.exe
to create a bootable SliTaz USB Flash Drive
http://www.objectif-securite.ch/slitaz/tazusb.exe
After
3.) You can start using your SliTaz easily
(Password to log into a graphical environment:)
user: tux password: tux
user: root password: root
on Jan 14, 2010 | Computers & Internet
How to boot laptop from usb flash disk
When u just turn on your laptop go to bios settings.....in bios settings change the boot priority to USB flashdrive....save and restart before you restart connect your flash drive to ur laptop......it will ask boot from flash drive press any key....n contiune...hope this helps
Mar 11, 2010 | Computers & Internet
Tip
Puppy Guide for survival (Live Linux) CD USB flash
Puppy Linux is a live linux distribution,
less than 100 MB, which is the main purpose of the use of
CD, USB flash, MP3 Player, camera, etc..
Puppy comes with all codecs and is completely Multimedia ready.
Read and write in NTFS.
1) How to put Puppy on the CD.
1.a) Download Puppy
http://www.puppylinux.com/download/index.html
1.b) Puppy is distributed as an ISO image.
After Puppy menu comes before you.
2) How to put Puppy on a USB flash drive
2.a) Format the USB flash drive in the FAT32 filesystem. (Windows)
2.b) Boot Puppy from the CD
Then Menu / Setup / Puppy universal installer
Choose what you need.
Complete the installation process to end.
Restart your computer
2.c) The Puppy Live mode
see all your Windows and all. partitions and you can now manipulate them.
2.d) You can start using your Puppy easily.
on Jan 13, 2010 | Computers & Internet
Tip
Slax Guide for survival (Live Linux) USB flash-CD
Slax
(live linux) distribution proved to be an ultimate solution
for installation on a USB flash, CD,
MP3 Player, cameras and etc.
As all the above done in a few steps is the subject of this Guide.
1) How to put Slax on a USB flash drive.
1.a) Format the USB flash drive in the FAT32 filesystem. (Windows)
1.b) Download Slax for USB
http://www.slax.org/get_slax.php
1.c) Slax for USB is distributed as a TAR archive.
It is necessary to unpack it on your USB flash drives.
When you do this, you will see on your USB flash,
two new folders: boot and slax
Open the folder
boot
and run
bootinst.bat (if you're in Windows).
or
bootinst.sh (if you are in Linux).
Then it will become bootable, ie. able to raise from your USB flash drive.
1.d) Then you need to restart your computer.
After Slax menu comes before you.
(If in your BIOS is not set options for boot from USB flash drives, you can
do so when you start your computer press the keys: Delete, etc..
Thus will appear in the menu where you can set which devices can be boot-able)
2) How to put Slax on CD.
2.a) Download Slax for CD
2.b) Slax for CD is distributed as an ISO image.
2.c) Then you need to restart your computer.
2.d) Depending on the options your motherboard, it is necessary when starting your computer keyboard press: F8 or F12 or Esc, etc..
3) The Slax Live mode
3.a) Good collection of programs ie. modules:
http://www.slax.org/modules.php
3.b) You can start using your Slax easily.
Computers & Internet Logo
48 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
