Question about Pioneer Audio Players & Recorders
I have a Pioneer SX-229 Amplifier and recently it has developed intermittent crackling in the speakers. Fiddling with the speaker connector block at times makes the crackling go away only for it to return a short time later. The amp works fine in all other respects. Suggestions please.
  • RobZ
    RobZ Dec 17, 2014
    I think I cracked my problem yesterday. Further checks showed that the problem occurred on the A and B speaker outputs. So I either had a problem in the speaker selection switches or the Speaker Protection relay as it is common to both A and B outputs. (I did make an assumption that the driver stage is OK). So I went about changing the relay and played the unit for several hours with no issues. Checked the relay for resistance across the contacts with coil energized showed a resistance of several ohms and not stable. Also I might add that if anyone is not a tech then tread carefully as there are nasty voltages when the covers are removed.
techman
  • 3130 Answers
SOURCE: static and crackling sounds
Sorry to burst your bubble my freind but things do wear out as you had plenty of life out of this unit.. Your problem is a transistor or a driver IC is breaking down under a load and heat and will get worse to where you wont be able to use the unit.. It will probable cost you in a range of 200 bucks or .more!as there is no quick fix for a solid state unit that has no user serviceable parts inside. Its just not replacing the bad part , its the hooking up to the load resistors then seeing that several other parts are not up par and having to start rebuilding the amp statges of your reciver.. If its more then 8 years old Time to landfill it and get a new one .. Put it to rest. It dosent owe you anything as its been loyal to you all these years!! Good Luck
Posted on Jul 27, 2006
  • 518 Answers
SOURCE: Pioneer SX-750 Old School Need Help
It could be a dirty control or switch, working them back and forth could prove that. Other than that, It's likely bad outputs. A unit that old may have transistors for outputs but might be IC's. Transistors can be tested with an ohm meter to see if they're good or not. Also if it has transistor outputs, they may have a small value resistor on the Emitters, check those as well.
Hope that helps...
Geno
Posted on Mar 07, 2008
SOURCE: crackling sound through speakers while watching dvd movie
Yamaha Rx-V361 Firmware Upgrade, A/V-Receiver/-Verstärker - HIFI-FORUM
Posted on Jun 18, 2008
  • 3 Answers
SOURCE: pioneer sx 217 home theater system
you have to put the red and white cords into the tv section of the receiver and the yellow cord into the dvd console.
Posted on Jun 20, 2008
  • 4 Answers
SOURCE: Pioneer VSX-36TX popping and crackling during warm-up period
I have the exact same amplifier with what sounds like the exact same problem. I opened up the amplifier, and while it was powered on started tapping around until I heard the popping and crackling suddenly increase. I was using a piece of wood and the plastic part of a screw driver for this. The popping and crackling suddenly burst out onto all channels when I was tapping on the DSP board (encased in a metal enclosure to the very right of the amplifier).
I took off the metal enclosure (with the receiver turned off, of course :), and with the receiver on, and started tapping around the DSP board, and I found that the biggest crackling effect was achieved when I tapped on the Cirrus Logic CS493292-CL chip which does all the decoding and switching.
I detached and took out the DSP board and looked at it very carefully but of course couldn't find any bad connections. I tried resoldering all the feet of the Cirrus Logic chip and many many components all around to no avail.
Finally I tried applying pressure to the chip while the popping was going on, and it stopped. Further investigation revealed that bending the board around the chip produced the same effect.
For the life of me I couldn't figure out why bending the board eliminates the problem, but my solution was to put a piece of eraser wrapped in masking tape and taped to the Cirrus Logic chip, and two other pieces on the back of the board in such a way that when the metal enclosure was replaced onto the board, it put gentle but firm pressure onto the Cirrus Logic chip and at the same time bent the DSP board slightly.
It's been a few days without popping, clicking or static, but time will tell. Good luck!
Posted on Feb 05, 2009
Pioneer SX-315 Speaker Problem
The bump may have broken or disconnected speaker wires.
May 17, 2017 | Pioneer SX-315
I have a Pioneer SX-315. While inuse it shutdown. Now it won't turn on. What happened?
Generally speaking, an amp attempts to protect itself from heat, shorts, overloads and operator exuberance by refusing to turn on or stay on.
Overloads can be from excessive periods of high output or marginally low impedance loading by the speakers; and shorts would be wiring issues or a speaker blowing up.
You should be able to feel if it's hot. WHY is it overheating? Make sure it has sufficient ventilation on all sides and that vent holes are not blocked by dust balls. Ensure the fan (if equipped) is running as designed (some only operate on demand). Clean dust and debris from it.
If the amp comes back on after cooling, you're lucky. They only have so many self-protection cycles in their lives so continuously resetting or cycling their power without addressing the cause can do more harm than good.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'nekkid'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced and competent hands-on tech.
Check for loose speaker connections at the speaker as another possible root cause for intermittent shutdown.
Sep 01, 2011 | Pioneer SX-315
My PIONEER STEREO RECIVER MODEL SX-650 has very recently started making this weird crackling noise and ive tryed it on all kinds of differnt speakers so there not blown. Then i took it apart and cleaned it...
if the unit is under warranty just bring it back to the store or in the authorized service center. because there is no serviceable parts inside the unit esp on that kind of problem... ty
Jun 23, 2011 | Audio Players & Recorders
Crackling noise in the rear right speakers often...
Try connecting another speaker that is known to work to the Rear right connector, and if the crackling noise still appears, it is a problem with your wiring, receiver speaker terminal, receiver internal board, or the device connecting to the amplifier or the wiring from that device to the amp. Usually this is a wiring problem, or faulty crossover.
I’m happy to help further over the phone at https://www.6ya.com/expert/jeremy_69f3cc28d95bf514
Mar 09, 2011 | Denon Audio Players & Recorders
Pioneer sx-255r can i connect 6 - 8 ohms
Yes, you can use them but be careful. These are not necessarily robust speakers. If they sound strained, back off.
Mar 07, 2011 | Pioneer SX-255R Receiver
Crackling sound on my amplifier
If you have good clean, loud sound with your LP player and not with your PC, your PC is causing the noise. Most PC sound cards are not very HiFi in their sound and it is quite evident when listening to a PC via a HIFI sound. Now, you can not use the headphone outputs to your Pioneer, you must use the LINE OUT jack, set as line out in your computer. There is a signal level mismatch if you use your headphone outs, distorting your Pioneer. Try LINE OUTs or buy a HiFi rated sound card.
Feb 23, 2010 | Audio Players & Recorders
Crackling sound from right speaker only
I'm not familiar with that model but I am familiar with the problem. If your unit has a volume knob or a balance control which is a potentiometer you need to clean them. Go to www.mcmelectronics.com where you can find spray cleaner. I like to use blue shower as it works well and will not hurt any components. When you get the cleaner unplug your unit and locate the volume control and any others which have a rotating knob. Usually near the top is a small hole which you can spray the cleaner in. Rotate the control and follow through several times. Try the unit and it should be ok. If it isn't you will have to replace the controls as the resistance material has worn off and they cannot be repaired. Let me know how you make out or if you need anymore help.
hardrocko
Thanks for using FixYa
Feb 18, 2010 | Pioneer Audio Players & Recorders
No surround sound like the movies
HOOK IT UP FROM A DVD PLAYER OR BLU RAY,,, WITH EITHER COMPONENT OR A OPTICAL CABLE ,,MAKE SURE YOU HAVE ALL OF IT TURNED ON ON THE RECIER SETUP
May 14, 2009 | Pioneer SX-315
Soundsticks have developed a loud intermittent annoying crackle
YOUR ONLY OPTION IS TO TAKE IT APART AND CHECK SPEAKER MEMBRANE I SUSPECT THIS HAS PARTIALY BECOME UNATACHED FROM THE SPEAKER IF THAT IS THE CASE IT WILL NEED TO BE REPLACED
Dec 28, 2008 | Harman Kardon SoundSticks Computer...
61 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
Ian Summerfield
Ian Summerfield
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
