Samsung 29 cu. ft. French Door with Cool Select Pantry 1/2 Refrigerator Black Logo
S
SONIA VAN HOUTEN Posted on Dec 15, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
HOW DO I SET THE TEMPERATURE ON A SAMSUNG MODEL SRS615DP REFRIGERATOR
Happy Valley Air Care LLC
Level 2:
Novelist:
  • Expert 199 Answers
  • Posted on Dec 15, 2014
Expert
Level 2:
Novelist:
Answers
199
Questions
0
Helped
61946
Points
316
5 for both freezer and fresh food side. This corresponds to about 37 degrees in fresh food side and 0 - 5 degrees in freezer. Check for blocked vents from and to the fresh food side and return to freezer. Most problems occur because these vents are blocked and/or overstuffing of freezer and fresh food side. The air has to have room to circulate. Another thing to check is if the condensing coils are dirty. Normal access to the condensing coils if yours has one is inside the cardboard cover on the lower back side of the your refrigerator.
Hope this helps
I have a very small dribble of water leaking from the bottom of the control panel on the freezer door. Is there a simple fix or do I need a technician? Unit is a SRS615DP.
Maybe and maybe not.
Page 9 of the user manual mentions a anti sweat heater that you can turn on or off.
Samsung SRS579NP User Manual Ice cold Water Dispenser
It maybe that the water line to the water dispenser is leaking
I am including a link to youtube videos about refrigerator water leaks but there is little about Samsung. Hopefully turning on the heater will solve your problem. At least one of the videos shows how to replace the tubing in a different brand of refrigerator.
samsung side by side water leak from freezer door YouTube
1helpful
My SAMSUNG SIDE BY SIDE fridge model number SRS615DP keeps shorting out my circuit breaker after a few munutes...why?
There is a ground fault in it, meaning that there is leakage of electric current from the hot wire to ground. It may be due to moisture in the wiring. Take care because the metal frame may be live, and call a service tech.
3helpful
2answers
My Samsung Refrigerator can not keep the set temperature.
Normally your fridge is set +2 degrees C. with a differential of 3 so when it reaches +5 it should switch back on. if this is not doing this then a new thermostat may be in order.
1helpful
Ice maker seized after dumping ice, will not return to fill position
OK, Now I see that model number is only for the UK. I did find a supply and hopeful supply warehouse Ckick Here=> Big Warehouse the location is Australia. They have parts manuals with your model numbers. Like this PDF of your model Here=> SRS615DP I would like to say I know your machine but all model numbers change in the USA I am trying to help and if you are from another county I will also give that a try, Tell me this OK or not, I would like to know because I get many questions from Australia, Thanks, Sea Breeze
SAMSUNG SRS615DP IS TRIPPING MAIN FUSE WHY
I would start by getting behind it and removing any cardboard or dividers. With it unplugged from the wall check for any loose wires or breaks in the wiring, some small animal may have chewed a wire into. Next look closely at the compressor most have a way to unplug the compressor - unplug it, set the wires so they do not touch any metal or you. and plug it up into the wall if the lights come on and fans start running you have a bad compressor. Sorry.
2helpful
Freezer, Ice Maker and Water dispenser not working
it has to get down to the proper temperature after the reset the set point is -4 for the freezer and 38 for the refrigerator. the numbers shown o\n the digital display panel stands for the actual temperatures. When the compartmnet tempertures go down, so do the numbers on thge display panel, and finally they reach the set temperatures. Once the system is stabilized , the display tempoeratures are the set temperature.
2answers
Refridgerator constantly beeping. I have a Samsung SRS615DP about 3yrs . Constantly beeping on fridge side. Seals look very clean with no dirt etc. Looked at Samsung site but no help. I live in Mandurah...
Look to the freezer side for the possible problem. If the freezer evaporator coil is freeing up due to a defect in the defrost system the refrigerator temperature will be the first place it will show. Look for frost build-up on the freezer back wall.
Fridge is in lock mode
Please press the white wine key and interior lamp button together for 3 seconds.
Top Samsung Refrigerators Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
