Question about Electronics - Others
How can I connect 1 inverter to two different energy meters
    New Friend:
  • 3 Answers
Tell me what you want to do and why you would want to to different meters
Posted on Jan 04, 2015
What is the difference between inverter AC?
The biggest difference between inverter and non-inverter AC is the fact that the motor of the inverter compressor has a variable speed. The speed of the non-invertor compressor is fixed. This means that it operates either at full or minimum speed. A censor in the invertor adjusts the power according to the temperature in the room, lowering the electrical consumption and saving energy.
Due to the sophisticated operational method of the invertor, its compressor does not work at its full capacity all the time. When the speed is lower, the needed energy is lower too and you pay less money for electricity.
As the compressor motor of the inverter air conditioner does not turn on and off all the time, but keeps working at low power, the operation is more quite.
The technology of the inverters not only makes cooling and heating more efficient, but it also makes the AC's life longer.
Last but not least, the inverter AC is able to cool or heat your room faster than the non-inverter. This is due to the fact that in the beginning of the process, the inverter uses more power than the non-inverter and diminish the power when it gets close to the desired temperature.
Source:
Service Repair Installation
May 17, 2018 | Inverter Heating & Cooling
Tip
What is the relation between an IMEON hybride inverter and Internet of Things
Enter the universe of connected devices and connected energy (IoT)
Your connected IMEON inverter is designed to keep up with technological advancements as well as to integrate itself into the Internet of Things (IoT).
For example, by downloading the "Philips Hue" application your connected IMEON inverter will communicate with the Philips Hue lamp to send the light signals according to the operating state of its solar system. With this application, you can set custom alerts in function of the state of charge of the battery, the presence of excess production, or you can choose to be notified about a transition to backup mode. For example, it is possible to switch the color of the lamp to red when the state of charge of your battery is low level or to switch the color of the lamp to green when the solar output is substantial.
Many applications like the one above are being developed to connect IMEON to new devices or "consumer loads" such as water heaters. In addition to that, Imeon Energy is already engaging with companies creating smart home equipment to accelerate the development of the new software.
With these new technologies, a whole new world of connected energy management is opening up and your IMEON hybrid inverter is ready for it.
The connected inverter and connected energy Imeon Energy
on Mar 12, 2018 | Inverter Electronics - Others
Tip
How imeon hybrid inverter is connected
The hybrid IMEON inverter has all the characteristics of a connected device, giving you the ability to monitor, in real time, the performance of your home installation, from your computer, tablet or smartphone. Thanks to an integrated a web server, IMEON hybrid inverter broadcasts its own Wi-Fi allowing you access to performance data without the need for internet connection.
The local monitoring interface displays detailed information on the produced solar electricity, the energy stored in or consumed from the batteries as well as the energy coming from and injected to the public electricity distribution network. Close supervision of your solar installation allows one to adapt the configuration of IMEON hybrid inverter in order to fine tune the overall performance of the entire photovoltaic system and achieve higher self-production rate.
There is also the possibility to access all these features remotely using a web-based monitoring interface which becomes available after connecting IMEON to the internet. Moreover, thanks to its connectivity, IMEON is able to send you e-mails concerning the system hazards related to your autonomous house, which makes it possible to take preventive steps.
You can supervise the hybrid inverter of your autonomous house from all over the world
imeon energy -solar hybrid inverter imeon3.6 angle view with cables-wigaoetmofgu4i3phjlbvsds-5-0_0.png
More connected Imeon Energy
Last January I switched my power supplier from Click Energy to Origin Energy. Origin Energy stated that they install the smart meter for free within 8 weeks. It is now 10 months, Ron Hartmann
ring and say that tomorrow is a good day for the installation of the free meter because the next day will be a different supplier if it is not done
10 months is far too long
Nov 07, 2017 | Power Computers & Internet
Main bearing cap bolt torque specs for a 1999 2.0 Ford engine
See #1; Main bearing diagram
See #2; NM conversion chart
  1. NOTE: The crankshaft must rotate freely; if necessary check and adjust the bearing clearances.Tighten the main bearings and connecting rod bearings.
    1. Tighten the main bearing bolts in two stages.
    • Stage 1: 25 Nm.
    • Stage 2: 60 degrees.
    1. Tighten the connecting rod bearing bolts in two stages.
    • Stage 1: 25 Nm.
    • Stage 2: 90 degrees.
# 2) Newton Meters conversion chart:
http://extraconversion.com/energy/newton-meters/newton-meters-to-foot-pounds.html
#1)
25730427-ddvrxh52bv4dwu240r4mw22m-2-0.gif saailer
I’m happy to help further over the phone at https://www.6ya.com/expert/david_6df67de3b14de867
Jun 05, 2015 | Ford Cars & Trucks
I mistakenly connected energy source at the AC inverter output .Inverter is 5KVA cyberpower inverter.After correcting the connection, It cannot switch from DC to AC( fault signal is displayed on its...
John,
It's shorted out, either replace the part or buy a new one.
If you need UPS, Surge, or Power Related help don't hesitate to contact me!
Daniel • daniel@psihq.com • Power & Systems Innovations • 800.260.2259 • www.psihq.com
Sep 24, 2013 | Cybernet Systems CyberPower DC to AC...
Energy conections
The speakers can be tested with a meter, but if the voltage is different from the USA you may have damaged them instantly if connected to wrong voltage, I presume if I understand correctly it is some kind of surround sound system, voltage in North America is 110=120 volts and 50=60 Hz.
Jul 19, 2013 | Bose 3 2 1 GSX System
Hi, i have a 5kw sunteams inverter that regularly comes up with "hi dc inject" with red led "fault" light and shuts down the output. This is the 3rd inverter i have had in 10 months...
hi, I also get one sunteams inverter, it works quite well. One month ago it had High DC problem and I contacted the manufacture and this problem was solved. you can contact them at service@kinglongpower.com
Jun 15, 2011 | Electronics - Others
GE HVM1750 DM microwave stopped heating.
Hello there:
Normally when a microwave stops heating but all else works there are only a couple of things that can be bad
First is the megatron This is the part that converts the elevtrical energy stored in the power inverter into thermal heat
and the second is the power inverter this is the part that coverts the down to a usable wattage of energy for the megarton I will post a picture of both below
The only way to test them is to use a ohm meter and unplug the part and use the meter to see if you are getting any type of reading any reading under 1100 would be a bad part ok look at part 73 and 75
Nov 28, 2010 | GE EVM1750 Microwave Oven
I need a diagram for a mitsubishi inverter s 500
Here ya go:
http://www.acpd.co.uk/sei/s/1488/f295.pdf
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
Jun 25, 2009 | Inverter Mitsubishi Fr-s520e-0.4k Freqrol...
Electronics - Others Logo
94 people viewed this question
Top Electronics - Others Experts
Are you an Electronics - Other Expert? Answer questions, earn points and help others
