Question about Breezaire Refrigerators
I have a Breezair Harmony 2 air cooler that seems to be stuck on the lowest speed, even though the display says it is on the highest speed?
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 86 Answers
Faulty controller.
Posted on Jan 17, 2016
My breezair evaporative cooling can not cool.
Maybe you're expecting too much. Evaporative cooling doesn't work really well. It's function depends on evaporating a lot of water into the air. If the air in your room doesn't have a really low humidity (really dry air), then evaporation can slow way down or even stop regardless of how fast the fan is blowing.
Jan 02, 2015 | Heating & Cooling
My breezair evaporative cooling system can not cool.the air flow is very worm,anyone can tell me this problem?
what is the weather like is it humid ?
Humid weather will render any evaporative cooler ineffective !
Have you got the windows and doors open to the building ?
Evaporative cooling relies on putting water in the air and pumping the air out of the building. If it is humid the air already contains water and no extra water is added to the air and no cooling occurs.
Idle up down
hunting or surging ilde. name the 2 RPMS, low and high , is it hot or cold engine this issue.? 400rpm or 1000 or 2000 all are diff.causes.
no year, stated. so cant help.
but ill answer in the generic,
1: the ECU (got a carb,? )
the ecu controls idle speed at all times.
if not , there is a problem (you)
A: air leaks in the induction will make motor race at some point the ECU/ISC loses control. and hunts. trying hard to correct it.
b: egr stuck open idle too low, iSC cant correct it,, bad EGR.
c: engine EFI running way too leak starving for fuel so it hunts for 2 reasons < ISC hunting, and lean does that.
lean is gross power loss and opening throttle bogs the engine.
so is double bad. ISC makes it worse,
all this breaks down to 2 reasons.
1: ISC bad. in some way (gummed up. or restricted inside)
2: bad fueling or air leaks. vacuum leaks.
try answers , the hot cold question and the 2 speeds, of the hunt.
lowest rpm and highest of the hunted range of RPM.
Nov 23, 2013 | Honda Civic Cars & Trucks
HELP! MY TREADMILL WILL AUTOMATICALLY CHANGE SPEEDS TO THE HIGHEST SPEED EVER. ITS INCREDIBLY TERRIFYING!
please RUN the software calibration inmediately, for easy diagnose and fix it. However adjust the speed sensor, clean it, test for open or fraulty, tight the connector very well.
Jun 06, 2013 | Epic Exercise & Fitness
I have a breezair evaporative aircondioner. Ive turned the cooler off however the water has been leaking continually for several hours , even though ive switched the mains off . Sometimes ive often...
There is a water shut off valve connected to a float. The float may have a hole in it or the valve itself won't shut the water supply off before it overflows.
May 04, 2017 | Heating & Cooling
How to set humidistat for different seasons.
Vick, depending on the season and the humidity level in your home, is what determines the setting. For example, in the winter you want to maintain at least a 40% humidity level in your home. It will feel more comfortable, the heat will feel warmer and it will help keep static electricity at bay. In the Summer, you'll want to remove as much humidity as possible, as this will make the air feel cooler. If you have ceiling fans in you home, run them Clockwise at the highest speed you can tolerate. The more wind chill you generate, the cooler the air will feel and you won't have to set your AC at a lower temperature. Thereby, saving money. In the winter, run the ceiling fans Counterclockwise on the lowest speed. This will take the heat off the ceiling, wash the walls and bring it back down.
Clockwise and Counterclockwise are determined by looking up at the fan blades. Also, reversible ceiling fans have a switch on the side (where the pull chain is located). Generally, switch-up is Counterclockwise and switch down is Clockwise.
Hope this helps you to keep your home comfortable year round.
Apr 05, 2011 | Honeywell Heating & Cooling
It starts running and after about 15 seconds it shuts down with a message of service then what i see as an alarm 7 and shuts down
If it is a evaporative cooler that is breezair, coolair or braemar it will be because it has to low or too high a voltage supply. another problem could be the capacitor is the wrong size
Feb 09, 2011 | Mastercool 67680 Evaporative Cooler Air...
Breezair swamp cooler parts
Contact Convair cooler corporation.
Phone # 1- (602) 353-8066
Will send your parts out the same day.
Jun 28, 2009 | Heating & Cooling
AIR CONDITION
replace switch, works 9 times out of 9.
Nov 08, 2008 | 1998 Nissan Frontier
Refrigerators Logo
490 people viewed this question
Top Breezaire Refrigerators Experts
mike cooper
maniman
Are you a Breezaire Refrigerator Expert? Answer questions, earn points and help others
