Question about Acer AL2021M (Silver) 20" LCD Monitor
No display it is power is on - Acer AL2021M (Silver) 20" LCD Monitor
    Problem Solver:
  • 11 Answers
Hook up to external monitor .. Does the pre boot screen pop up (black and white writing at start ) ? If display runs on external monitor then your screen needs replacing usually or if you see a vague image on laptop screen then inverter or backlight is gone .. if no display on external and no pre boot screen probably the graphics chip on laptop has malfunctioned.
Posted on Dec 15, 2014
No display
If power problem then check you power connector. If power ok or display problem then you follow instruction:-
> Check CPU power, proper coming or not.
> HDD on or running ok conduction, if HDD not detect proper then not display.
> Check RAM slot or RAM ok conduction.
> Disconnect all power supply and some movement wait then reconnect all section and power on.
I hope display coming.
Thanks
Sep 09, 2013 | ViewSonic Computers & Internet
Proton pltv- 3250 32 "lcd tv a friend gave me
To turn on the TV:
Turning the Display On and Off
There is a power switch on the bottom of the display and a power button on top. The power switch is used to cut off power completely, whereas the power button turns the screen off but
allows the remote to continue working.
To turn the display on:
1. If the power light on the front of the display is off, turn on the power switch on the bottom of the display.
2. Press the POWER button.
To turn the display off:
1. Press the POWER button.
2. If the display will be unused for an extended period of time, turn off the power switch on the bottom of the display and disconnect the power.
Please make sure you rate my answer 4 thumbs up! Thanks so much for understanding, it would be a huge help to me. I would be forever grateful if you could do this for me. If you still have a question or concern about this problem please just respond / reply to my answer here before rating my answer.
Thanks
Tim
Oct 13, 2010 | Protron PLTV-32 Television
Intel desk top board no display
- remove all pci card
- check ram ( scrub with rubber eraser and broom ram slot with small brush, or your can troubleshut with new ram )
if still no display
- troubleshut with display card ( New display card )
if still no display
- troubleshut power supply with new power supply or any power supply is still good in condition( working power supply )
if display still not appear and your was do all tip above finally
you must troubleshut your motherboard with all your hardware. but your must use motherboard supported all your hardware.
Jun 10, 2010 | Intel D845GVSR Motherboard
No power to the display. Have changed fuse and
It is possible that the display is damaged, due to a steam leak in the machine, remove display and check for corrosion on board.
Mar 06, 2010 | Gaggia Titanium Espresso Machine
I can find nowhere on the tv that has an on off button, just got this tv
of the display.
Allso go here for full manual:
http://www.retrevo.com/search/v2/jsp/mytrevo/myTrevo.jsp?page=man
Oct 29, 2009 | Protron PLTV-32 Television
MY toshiba satellite 2430 CAN NOT POWER UP. BUT IT ALL THE LIGHT IS ON WHEN I SWITCH ON THE DC POWER SUPPLY SWITCH. WHAT IS THE PROBLEM? HELP.
remove the battery and remove the power adaptor ... press and hold the power button in the ON position and count to 20.
attach the AC adaptor only and press the power button ...this should fix the issue ... then re connect the battery.
if this does not work then add a external monitor .. if it lights up then hit the
Fn + F5 keys
Display modes
Fn + This hot key cycles through the power-on
display mode options.
The display mode options are:
Built-in display panel only, Built-in display panel and
external monitor simultaneously, External monitor only.
Fn + This hot key cycles through the power-on display options.
The display modes are:
❖ Built-in display panel only
❖ Built-in display panel and external
❖ External monitor only
video device simultaneously
❖ External video device only
Oct 07, 2009 | Toshiba Satellite 2430 Notebook
HCL LCD Monitor display problem
NO Bad Capacitors on the power board i have some problem in my HCL lcd monitor, my monitor display is on but at a time the display is gone. when i swicth off and on monitor power the monitor display is on ofter 2 sec the display is gone so that is the problem.
Jul 05, 2009 | ViewSonic VA702b 17" LCD Monitor
No power. led display very dim
dim display on an ag-1980 may be caused by bad display module or bad electrolytic capacitors in the display power supply. "no power" is probably a bad 12 volt regulator on the main board. the main power supply is working as evidenced by the display lighting up.
Jul 03, 2009 | Panasonic AG-1980 S-VHS VCR
Connecting Apple Studio Display 17 ( LCD ) to Apple G4 Cube
Check the connector coming from the monitor and see if any pins are crushed or touching. It may be shorting power going to it.
Mar 02, 2008 | Apple Studio Display 17" LCD Monitor
Sony demo
Had the same problem. The display of the home cinema system kept showing "sony demo". I went to the system menu and reset all settings to factory!
Nov 20, 2007 | Sony CMT-M100MD\W CD Shelf System
Acer AL2021M (Silver) 20" LCD Monitor Logo
Mohammed Ebrahim M
Mohammed Ebrahim M
