Question about Fisher Refrigerators
Fit KIT COVER DOOR SHELF 635 - 315017 - Fisher & Paykel
Not sure how to fit clear plastic covers to fridge door - worried I'll break the new ones!
SOURCE: Error code F32 for fisher
Got the same error here, called Fisher Paykel and the said it's an error related to the water line. They recommended running 3 L of water and see if code disappeared. If not, call service, they gave me a local company. Error code has disappeared, for now.
Posted on Nov 09, 2008
SOURCE: Fisher & Paykel Fridge Freezer E402B beeping when door closed
see http://www.fixya.com/support/t675116-refrig_e402bre
Posted on Oct 06, 2009
  • 3 Answers
SOURCE: Fisher & Paykel active smart fridge keeps
press the select button ( the button that you choose the temperature on the fridge and freezer) and check that the fan on both fridge and freezer are working.
Posted on Nov 07, 2009
localwonder
  • 6784 Answers
SOURCE: Noisy, Chattering fan with fisher & paykel fridge.
HI. Just so you know, Hissing and popping is normal on frost free refrigerators, it is the defrost heater, in this case. I would check these following areas to address any other abnormal noises.
If the level of the unit is not adjusted to proper specs, this will create an unstable operating condition, causing many noises to emit from the units structure. inspect the unit for proper level. adjust if needed. Next will be the drain pan. Once removed for cleaning, the pan must be replaced in position correctly. If not, the pan will rattle against the compressor, causing a ping or rattle.Simply reposition the tray if this is the case. The third possible issue will be the condenser fan. The condenser fan is located behind the refrigerator. It may be necessary to remove an access panel to reach it. This fan has a shroud, and if the fan blade becomes warped, it will rub against the shroud, causing noise. This fan blade is whole,and it can be removed and replaced if this is the case. Ok, the fourth problem spot will be the evaporator fan.
The evaporator fan is located at the back of the freezer. It may be necessary to remove obstructions such as the contents of the freezer, freezer shelves, ice maker and the rear inside panel of the freezer. The rear panel may be held in place by retainer clips or screws. Remove the screws or depress the retainer clips with a small screwdriver. Check the fan for warped blades. if the blades are warped or mis-aligned, replace it. This fan also is protected by a shroud as well, and it will make noise if the fan blade is damaged.
Last, i would move on to the compressor mounts. This is the most common spot for noise overtime. The compressor sits on rubber mountings. Those rubber mountings are designed to absorb vibration from the compressor. As the mountings age, they can become hard or disintegrate. When this happens, the compressor vibration is transmitted to the refrigerator structure and it can cause noise.
The compressor is located in the rear. It may be necessary to remove an access panel to get to the compressor.
Locate the compressor and remove the screw or retaining clip of just one of the compressor mounts.Using a pry bar, lift up the compressor enough to slip out the rubber mount. Inspect the mount for deterioration. The rubber should be firm but not rigid. If the mount is crumbling or hard, it should be replaced.
This concludes the inspection procedure. Follow carefully, and replace any failed or damaged device.....
Posted on Dec 20, 2009
SOURCE: Leaking Fisher and Paykel Fridge
i have a fisher and paykel 450L fridge and its been pissing water out underneath the vege crisper since day one, i was told by f&p whilst it was under warranty that it was because of the humidity and constant opening and closing, i finely had enough of cleaning up fridge pee! you shouldnt have to do this for a 2 year old fridge, god sakes the 20 year old beer fridge doesnt leak. rang f&p and booked a service call $121 fast bucks, had to be available from 12miday untill 5pm bloke showed up at 4.45. inside the fridge he took the back panel off and then got out a part from his bag a long black thing with wires and attached it to the?whatever, but get this! it wasnt a replacement part, this fridge never had this part, so what? did they forget to put it in? and ive have to put up with fridge pee for 2 years?? and why do i have to pay the $121? he told me i wouldnt have to pay for the part? whippee? i already paid for it when i bought the "faulty" fridge. ill be getting to the bottom of this, does f&p know there is a fault? and they dont bother to fess up? lucky they dont make cars!!!! took about 10min and so far no more fridge pee!!
Posted on Mar 18, 2010
How to I change handing of fisher & paykel 2 door fridge
Hello friend
Not your machine but this is how it is done for standard Fridges , They are all similar http://www.youtube.com/watch?v=VEcPVbOjdUE
Extract From the fisher & paykel website user guide ....it seems to be all about the handles.
http://www.fisherpaykel.com/vault/pdfs//pdf_usecares/5339_NZ_AU_ActiveSmart__HR.pdf
Door conversion
If you need to hinge your door on the opposite side we recommend that you call your local
Fisher & Paykel Authorised Repairer or Dealer to make this conversion.
ActiveSmart refrigerator models with silver handles need to be ordered at the point of purchase either with left or right opening doors and can not be interchanged.
All other models need to have an appropriate conversion kit for that model refrigerator.
The kit is available from your Fisher & Paykel Authorised Repairer or Dealer. Full instructions are
included in the conversion kit.
This does not apply to French door mode
Sep 11, 2014 | Fisher and Paykel Refrigerators
Hi,I bought a fisher and paykel refrigerator E450r model for over 2 yrs now. Once you open the door, you can hear a beep sound. You can also hear this sound while the door is open and even when the door is...
I unfortunately bought the F & P 450R upright fridge with the matching freezer, recommended to us by Winnings. Expensive and possibly the worst ever appliance purchase I have made. The door handle design is pathetic and once again today, has come apart. The fridge constantly freezes up which then affects the fan, which in turn stops the fridge getting cold. To date, we have had the F & P service out, he first said he needed to get it back to the factory and we'd be up for about $900. After we advised that wasn't happening, he replaced the control unit, which had didn't clear the problem (although still cost me $300). Having no confidence in F & P, we contacted a fridge mechanic with a good name. He closed his eyes when he saw the brand and mumbled, Kiwi's revenge. Long story short, over 3 visits he, adjusted the inadequate door sensor, refitted a temp sensor which had broken from its poorly designed plastic holder, replaced all the sensors and in the end said sorry, but you have bought a lemon. I now have a choice of buying a new fridge which wont match the freezer, buy a new fridge and freezer, even though the freezer is fine, or continue with what we do now, turn the fridge off every other day for 4 or 5 hours to defrost it. My solution, do not go near Fisher and Paykel, the service and machines are just not up to it.
May 31, 2011 | Fisher and Paykel Refrigerators
Fisher & Paykal Refrigerator. E 522 B Plastic piece in door hinge fell out . Door now travels around and has big dent in front panel. I need to replace outer stainless door panel and plastic piece in...
The plastic piece that is moulded to the inner door that holds up the shelf on a fisher & paykel fridge has cracked and no longer holds the shelf. Can I buy a new door liner or does the whole door need to be replaced?
Jan 29, 2011 | Fisher and Paykel E522BRXFD Stainless...
Fisher Paykel Fridge. Access to fridge fan.
My fridge is 11 years old and recently had the same problem; the freezer was cooling well, but the fridge compartment was not cooling enough. I searched the Web a read most answers. I thought the fan was faulty, but in fact it wasn't (the fridge has got 2 fans, one for each compartment, and they look very similar, the part number on mine was 883340). The whole problem was a build-up of ice in the condenser unit that is at the back of the freezer compartment. What happens is that the ice blocks the passage of air the fan for the fridge compartment. This of course stops the cool air circulating to the fridge compartment. I was able to repair the fridge an it is now working perfectly. This is what I did:
1) Removed everything from the fridge, food, shelves, the lot.
2) I made sure the fan for the fridge compartment was okay, by connecting it to a 9V battery; the fan was okay. (I did this because after reading the posts I was convinced the problem was a dead fan, but you can skip this step if you can hear the fan spinning and think it is okay). To check the fan, remove by pulling the toll plastic cover that fits below the smaller plastic cover with the temperature indicator. This cover is very flexible and flimsy, start pulling from near the bottom and continue along the right side, flexing it as you go along, until it comes free (there is an insulating plastic foam moulding underneath that comes with it). As soon as you remove this cover, you will see the small fan and the plugs. Unplug the fan's connector (it has a small lock you need to press) and wire it to a standard 9 volt battery. CAUTION: observe polarity! The battery positive terminal MUST be connected to the RED wire (or the fan burns!). If the fan is bad, you can remove it very easily by inserting 2 finger inside the white plastic holder, pushing the fan in (the fan is held with 3 very elastic thin silicon bands, that do not break) ,hooking the holder from the inside edge with your fingers and pulling. It will just come out through the slot. (I did this, but then had some problem in getting it back in place. I finally left it in a near flat position, but not quite as flat as it was. Nevertheless it works okay).
3) My fan was good (I wasted a lot of time doing this), so next I shifted my attention to the freezer compartment. I then noticed that the plastic cover at the bottom of the compartment was half dislodged from its proper location, all covered on ice. I removed the cover, breaking the ice that held it with care. This cover is difficult to remove, there is a lot of pushing and pulling, so be prepared and patient; do not break it (mine came out with a small locking leg broken, but it did go back in place without any problems). I then checked the second fan, that is on this cover; it was also okay.
4) As soon as I removed the cover I saw the problem...ice everywhere! I reached for the house hair drier and after about one hour it was all gone. Note that most of the problem ice is behind the condenser (small radiator looking aluminum frame, that should be left alone. Do not move, push or twist it).
5) once all the ice was removed, I the carefully pushed the radiator back in place at the bottom of the compartment (it just fits and had been displaced by the growth of ice), and replaced the plastic cover.
6) and voila! my fridge was again working perfectly. About 3 hours flat.
Jan 05, 2010 | Fisher and Paykel Active Smart E522B...
I have a fisher and paykel E522B refridgerator and the door handle is coming off. I need to know how the door handle is attached so I can retighten it
In most case the screws are hidden, some of the handles have a cover that slides up or down, and the others have a little hole cover that have to be popped out and then you can access the screw
Dec 13, 2009 | Fisher and Paykel E522B Stainless Steel...
The panel cover on my fisher & paykel nautilus is broken
Fisher and paykel is based out of australia. call the # in the manual to order part. they have a division in california. parts usually take me two to three weeks to recieve.
Jun 21, 2009 | Dishwashers
Door shelf support broken
Hi Shari. Yes. Go to any hardware store, or a home depot or lowes. Go to the adhesives isle. What you need is an epoxy adhesive that will work on plastic. There are different ones that will work so read info on the containers to find the appropriate one. One I use a lot with success is called JD WELD.
May 03, 2009 | Fisher and Paykel Active Smart E522B...
Fridge is warm, Freezer working ok
I had the same problem , you have to clean your freezer compartment out completely and take the covers off the inside back of the freezer being carefull not to break any wires, then defrost the cooling module by hand hot water towels messy job.
Make sure the cooling sensor is attached in the right spot and hasn't fallen down, it has a plastic holder it clicks into.
once clean and defrosted put back together and it will be fine...
Try not to put any frozen chip bags or peas etc right at the back of the freezer this causes the cooling system to freeze up.
How the system works it blows cold air from the freezer compartment down to the fridge to cool it and when the system freezes up no cold air to fridge ,hense the problem you are having...
If you are not confident in doing the job you can call a fisher and Paykel tech and they will charge you $150 to do the job.
Apr 01, 2008 | Fisher and Paykel Active SmartĀ® E522BR...
Refrigerators Logo
35 people viewed this question
Top Fisher Refrigerators Experts
Charles T Nevin
Charles T Nevin
Joseph Hoffmann
John Tripp
John Tripp
Are you a Fisher Refrigerator Expert? Answer questions, earn points and help others
