Question about Kyocera Office Equipment & Supplies
Ou je trouve le connecteur( red; green; white; black; black) en kyocera km 4050
Mix-it-up
  • 832 Answers
SOURCE: L'imprimante dit de consulter diagnostic/maintenance
quell primeur avez vous? brother imprimeur: cherchez cet forum pour error 50. c'est escrivez bien tout.
Posted on Apr 21, 2008
  • 32 Answers
SOURCE: demande d'aide
hi daliattie -
please try these links (HP support):
lost CD, need drivers: (select an operating system running on your computer)
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?lc=en&dlc=en&cc=us&lang=en&product=441125&
general information for your printer model:
http://h10025.www1.hp.com/ewfrf/wc/product?product=441125&lc=en&cc=us&dlc=en&lang=en&cc=us
- JW50
Posted on Nov 04, 2008
gremlin11
  • 78 Answers
SOURCE: epson acculaser c1100 service req E521
the developer home position sensor is not registering. it will need to be cleaned. This will involve the removal of the left side cover, the removal of the power supply pcb and the removal of the sensor which sits under the power supply. clean the sensor out with a dry pain brush and re install. be careful to turn the printer off and unplug it prior to removing any covers. the cover is easily removed, however, take your time and make sure you release all the clips on the inside of the cover. once the cover is off it is easy to get to the sensor. don't worry too much about all the connections to the power supply, they only fit in one plug and cannot be inter changed.
Remember to take your time in this operation. If you are at all uncomfortable with this, do yourself a favor and call a technician in to do it. He wii do it in about fifteen minutes.
Gremlin11
Posted on Dec 10, 2008
  • 525 Answers
SOURCE: Je possède un copieur Ricoh
SC 546: Unstable fusing temperature
Symptom: The fusing temperature does not rise
3 °C or more within 5 seconds after the
fusing lamp has been on over 8
seconds.
Possible Cause: • Thermistor defective
• Power supply unit defective
Posted on Feb 05, 2011
muntejaya
  • 10421 Answers
SOURCE: JE NE TROUVE PAS LE DRIVER POUR CANON LBP 1120
Hi, please get new driver here: www.driversdown.com/
www.nodevice.com/driver/company/Canon/Printer.html
www.usa.canon.com/cusa/office/products/.../hs_1200ts
Jay wxfbc
Posted on Feb 12, 2011
How to set system to print in color
KM-3050/4050/505 is a pure Black & White MFP
Oct 18, 2014 | Kyocera Tk-717Km-3050/4050/5050
Kyocera km 4050 showing error code cfb31 how to clear it
hello,
This error has to connect the connector (red, green, white, black, black) in the wrong place in panel. yc1 - yc9
Apr 22, 2013 | Office Equipment & Supplies
Bonjour au depart c'etait un probleme d'alimentation du papier et quand j'ai nettoye l'imprimante j'ai trouve un crayon de couleur a l'interieur maintenant je veux relancer l'imprimante mais j'ai le...
Bonjour ipty2004
Je suppose que vous avez vérifié si le capot ou tout autre couvercle sont bien verrouillés .
Je crois que si vous désinstallez le logiciel / pilote et le réinstallez ensuite après un redémarrage de votre ordinateur , le problème ne se posera plus .
Cordialement ,
fanaudi .
Mar 28, 2011 | Lexmark X5470 All-In-One InkJet Printer
Je trouve pas le pilote pour sharp 5320 pour windwos 7
consultez la page suivante (en anglais):
http://support.sharp.net.au/drivers/
Vous y trouverez le pilote de l'équipe que vous avez, il suffit de sélectionner votre système d'exploitation.
Mar 09, 2011 | Sharp AR-5320 Black and White Copier
Bonjour ou se trouve le reste sur ce modele?? j'ai DEG de programme dessus et je ne suis pas capable de l'enlever. merci
écoute, ne te fâche pas : je ne comprends pas le sens de ta question et je devrais m'abstenir de te venir en aide, craignant d'interpréter incorrectement ton problème (et ce n'est pas ma maîtrise de la langue de Molière qui est en faute!!) Mais je vais quand même essayer de t'aider.
L'indicateur DEG que tu sembles vouloir éradiquer est parfaitement inoffensif. It est affiché sur l'écran pour te rappeler que l'unité d'angle est le degré. Cela signifie que tout argument que tu fournis à une fonction trigonométrique (sinus, cosinus, tangente, cotangente) est interprété comme une valeur en degrés. Donc si tu calcules sin(Pi) ne t'attends pas à obtenir 0 mais le sinus de 3,14.. degrés.
De même, toute valeur retournée par une fonction trigonométrique inverse ( arc sinus, arc cosinus, arc tangente, arc cotangente) sera en degrés.
Si tu changes l'unité d'angle de degré à radian, l'indicateur RAD sera affiché quelque part sur l'écran. Donc je te suggère de ne pas t'acharner à faire disparaître cet indicateur: Il ne fait que te monter quell unité d'angle tes calculs utilisent. C'est plutôt commode, ne trouves-tu pas?
Maintenant, si tu veux préciser ce qu'est ce reste que tu cherches, peut-être pourrais-je t'aider? Tu n'as qu'à faire un commentaire et je verrai ce que je peux faire.
Jan 17, 2010 | Casio FX-250HC Calculator
Pourquoi code erreur 52030
Bonjour,
Mon nom est Brandonmxb. Je veux essayer de vous aider du mieux que je peux. Je ne parle pas anglais, mais puisque vous parlez français, j'ai appris la belle langue, ou bien je viens d'utiliser Google Translate. Bref, voilà votre solution.
Certains utilisateurs ont un problème de reconnexion à la fonction WiiConnect après la mise à jour il ya des systèmes.
Si vous avez trouvé soit un 32002 ou une erreur 52030 essayez de changer votre canal sur le routeur à 11 ou 1. Si votre déjà sur l'une de ces chaînes aller de l'avant et mettez-le à tout le reste, laissez le cycle de routeur, au moyen (redémarrera après le changement), puis changez-le sur le canal 11 ou un. Aussi, si vous avez un téléphone sans fil aller de l'avant et de l'éteindre juste pour s'assurer qu'il n'y ait aucune interférence. Si rien de tout cela fonctionne aller de l'avant et appeler Nintendo sur l'organisation d'une unité de remplacement ou de dépannage mai ils vous fasse.
Pour les "routeurs Linksys WRT54G" Entrez l'adresse IP du routeur (par défaut est 192.168.1.1) le mot de passe et nom d'utilisateur (par défaut admin / admin) puis cliquez sur l'onglet sans fil, maintenant sélectionner un autre canal sans fil dans le menu déroulant. Ce correctif mai ne fonctionnera pas pour vous, mais il vaut la peine d'essayer, et à nouveau ce correctif n'est pas garanti de fonctionner pour toutes les consoles.
Si cela a permis, s'il vous plaît taux de moi.
Besoin d'aide?
Aller à: http://www.nintendo.com/consumer/
Appelez: 1-800-255-3700 *
Dec 12, 2009 | Nintendo Wii Console
Cable dv
bonjour j'ai le même problème que toi, peux tu me dire si tu as trouvé une solution merci laisse moi un message sur hondaciviclm@hotmail.fr merci et à bientôt
Aug 12, 2008 | Sharp Viewcam VL-Z1 Mini DV Digital...
Carte son
Bonjour,
Je ne parle pas tres bien francais alors je m'excuse pour les fautes grammaire. Quelles drivers vous avez besoin? Driver pour connection d'internet? Ou le drivers de music? Etc.
Apr 13, 2008 | Computers & Internet
26 people viewed this question
Top Kyocera Office Equipment & Supplies Experts
Kyocera HP Expert
Chris Schutte
Are you a Kyocera Office Equipment and Supply Expert? Answer questions, earn points and help others
