Question about Lowrance Elite 5 Color SonarGPS Combo
How do I erase trails
When fishing the same spots on different days the trails are covering way point icons adn therefore would like to start the day by erasing previous trails
    Scholar:
  • 97 Answers
Http://www.lowrance.com/Global/Lowrance-images/backgrounds/lowrance_hds_background.jpg
Here is a link to the lowrance website to the elite 5 page where you can download a pdf file of your owners manual.
Go to your gps screen on your unit and press "menu" twice. Under the Chart heading you will find "waypoints, routes and trails" select this option and when you open it you will find a tab for trails this is where you will locate the options to delete your trails so they wont clutter your screen.
Posted on Dec 25, 2014
Need to know if its normal for an Xtrail clutch to burn out at 69000 km. If not, why would Nissan not cover it under the manufacturers warranty?
A clutch, like a tire and brakes, is a wearable item and simply not covered under warranty. Some clutches last longer than others but that is because of the way it is used. A clutch that is "ridden" will wear out faster than one than is not. And when you replace the clutch, you will have the same wear pattern with the new one unless you change your riding/driving habits.
Aug 05, 2016 | 2005 Nissan X-Trail 2.0
Tip
Using a pH meter to care for your fish
pH values are the acidity of a body of water. Neutral water has a value of 7.0 meaning that it has equal amounts of hydrogen ions and hydroxide ions. When more hydrogen ions are added the water then the number goes down and the water becomes more acidic, or if the amount of hydroxide ions goes up then the water becomes more alkaline.
pH levels in your fish tank can prove to be fatal if they aren't monitored properly. While there is no secret formula for the perfect pH level for all fish it is best to keep all the fish from the same bodies of water together. Salt water fish shouldn't be put in a tank with freshwater fish because they need different pH levels.
Throughout the day the pH level of your fish tank will change although these slight changes shouldn't be too harmful on your fish sudden changes will prove to be fatal. When you are moving fish from one tank to another you want to make sure that the two waters have the same pH levels. When you want to buy a new fish check the pH level of your fish tank and then the pH level of the water at the pet shop to make sure that the levels are not too different.
You should be checking the pH levels of your fish tank at least once a month, but more often is always better. When you take the pH level you should write it down in a log book. You should try to take the pH level at the same time every time you take a reading because at different times of the day the levels would be different. Try to keep yourself from going crazy, if the pH level is a few decimals off of perfect your fish will be okay. If the level is fairly regular you shouldn't have to do anything unless your fish show signs of distress.
on Feb 02, 2014 | Measuring Tools & Sensors
When setting 12 for feeding twice a day at what point does the cycle start
The moment in time where you started the settings. If you programmed it at 8:45 in the morning, then it should start for the next cycle at 8:45 at night.
Jun 05, 2015 | TOP FIN Automatic Feeder
Which are the best places to do fishing?And which are best fishing rods we shuold have ?
Fish like edges or places where the bottof structure of the body of water you're fishing changes.
For instance a shallow flat with a deeper hole or ditch running through it. Or a drop off with a point that extends off of it.
if spots like the contain cover then they become even more attractive to fish. Cover is weeds, wood, rock or any other type of material that either naturally occurs of is artificially created. For instance a concrete break wall or a jetty that has bRosen rock along it makes great cover for fish. Fish also use edges, these can occur in a number of different ways. For instance where sandyou bottom turns to gravel or the edge of a weed line or where warme and cooler water meet etc. If you can locate an edge on a structural change and that edge meets cover or is the cover itself you've found potentially awesome fishing spot. The fish might not be there every day but they will use it at some point in time.
Hope this helps, good luck.
Nov 06, 2014 | Fishing
How can I make icon for repeated personal banking at Lloyds tsb on laptop?
Restore points on your unit should help. Go a few days or to your last restore point the machine. Its never easy, hope that helps.
Mar 16, 2014 | Computers & Internet
Any cheats for rapala tournament fishing
  • Bonus lures and videosAnswer all questions correctly under the "Quiz" section to unlock bonus lures and videos.
  • Quiz answersThe following is a list of all answers (in order) for the "Quiz" section:
      1. B2. C3. D4. D5. C6. B7. D8. D9. C10. B11. B12. A13. B14. D15. B16. D17. B18. D19. C20. B21. D22. A23. B24. B25. C26. B27. D28. A29. C30. C31. B32. C33. B34. C35. C36. B37. A38. D39. B40. C41. C42. A43. B44. B45. C
  • AchievementsAccomplish the indicated achievement to get the corresponding number of Gamerscore points:
      Tournament Completion (50 points): Finish the Tournament game mode.Tournament Master (40 points): Finish the Tournament game mode in first place (Gold Medal).Rapala Series (25 points): Finish the Rapala Series event.American Tour (25 points): Finish the American Tour event.Lund Series (25 points): Finish the Lund Series event.Elite Tour (25 points): Finish the Elite Tour event.Ranger Tour (25 points): Finish the Ranger Tour event.Legends Series (25 points): Finish the Legends Tour event.Rapala Pro Tournament (25 points): Finish the Rapala Pro Tournament event.Time Challenge Completion (50 points): Finish the Time Challenge game mode.Arcade Challenge Completion (50 points): Finish the Arcade Challenge game mode.Bass Champion (20 points): Catch 40 Bass.Perch Champion (20 points): Catch 40 Perch.Trout Champion (20 points): Catch 40 Trout.Catfish Champion (20 points): Catch 40 Catfish.Salmon King (20 points): Catch 20 King Salmon.Fish Master (25 points): Catch every fish in the game at least once.Fishing Boat Expert (20 points): Use all boats at least once in a tournament event.Shore Fishing Expert (20 points): Catch at least 15 different fish species casting only from the shores.Master of Deceivement (135 points): Finish the Tournament game mode with every character in the game at least once.Fishing Rod Expert (25 points): Catch at least 20 fish using every rod in the game.Fishing Reel Expert (25 points): Catch at least 20 fish using every reel in the game.Fishing Line Expert (25 points): Catch at least 20 fish using every fishing line in the game.Lure Master (75 points): Use each lure at least 10 times.Lure Apprentice (25 points): Catch at least 10 Lake Sturgeon using a single lure type.Lure Expert (25 points): Catch at least 30 Chain Pickerel using a single lure type.Lure Specialist (50 points): Catch at least 60 King Salmon using a single lure type.Always Ready (25 points): Catch your first fish within the first 2 minutes of entering a new tournament fishing day.Quick Fishing (40 points): Catch your first 3 fish in a new tournament fishing day in less then 6 minutes.Bad Weather (20 points): Catch at least 40 fish while in bad weather.
  • Sep 28, 2009 | Nintendo Wii Console
    Window vista office 2007 trail key
    The trial version of Microsoft office expires after 30 days. You must purchase Microsoft Office 2007 if you wish to keep using it.
    I suggest a free open source alternative - Open Office.
    Jul 12, 2009 | Acer Extensa 4620-6402 Notebook
    Fish don't move and guide book won't close
    The guidebook can be closed by clicking Alt F4. I can't get the fish to move though.
    May 29, 2009 | The Learning Company Oregon Trail 5th...
    Lowrance Elite 5 Color SonarGPS Combo Logo
    247 people viewed this question
    Top Lowrance Boating Experts
    Phil Walker
    Phil Walker
    Jerry Greenberg
    Jerry Greenberg
    Are you a Lowrance Boating Expert? Answer questions, earn points and help others
