Question about Lenovo ThinkPad Computers & Internet
How do I start the window when it appears the sentence to interrupt startup press the blue think vantage button
I pressed the power button and it appears the sentence above and the word fan error at the left cornor
    Problem Solver:
  • 3 Answers
Your computer might have overheated. I have a Lenovo Thinkpad too, and it does that from time to time. When you're using it, make sure you're using it on a flat, hard surface. This helps the fan circulate air easily and keep the hardware from getting too hot. If the problem still occurs, try to clean out the fan. There could be dust in it and that can prevent it from cooling off the hardware.
Posted on Dec 20, 2014
    Problem Solver:
  • 11 Answers
Can you explain a little clearer ..but sounds like fan issue ... Usually fan clogged with dust...remove back off pc and clean fan if that's the case ....
Posted on Dec 15, 2014
Rubec
  • 42 Answers
SOURCE: Bootup problem
Your CPU is overheating.
Try and get into the BIOS and increase the fan speed & any aother fan on the system. Don't increase the temperature range, as this will damage the system.
You won't be able to sort out the software problem until the system is running within the hardware limits.
You can also run a office fan to help get the system to cool while making the changes in the BIOS.
Posted on May 11, 2008
foxyreign
  • 52 Answers
SOURCE: dell inspiron 1525 notebook will not start windows
Usually this happens when the vista boot loader fails. During boot up, keep tapping F8 and then select Disable Automatic Restart... and get the stop error code which usually starts with 0x
Posted on Jun 10, 2009
Push28
  • 102 Answers
SOURCE: Gateway laptop vista unresponsive on startup
go to www.ubuntu.com download the cd image that is suitable for your laptop but USE THE VERSION 8 NOT 9 burn it star your computer with the cd inserted when ubuntu is loaded verify if you can browse your hdd if not your hdd is toasted if yoes you will need to use your recovery disk that came with your laptop but WARNING YOUR RECOVERY DISK IS DATA DESTRUCTIVE if you dont have your recovery disk use any windows install cd (xp , vista or se7en) go to http://www.gateway.com/worldwide/ to get your new driver of your hdd is toasted buy a new one and go to a pc shop to make it replaced
Posted on Jun 22, 2009
sijudoniston
  • 134 Answers
SOURCE: IBM ThinkPad R50 restore factory settings
You might have deleted the Hidden partition within the drive .So you will not get the restore factory setting option
Posted on Aug 27, 2009
richard191
  • 691 Answers
SOURCE: I have a compaq cn6220. when i press the start
mother board issue, has the unit had a knock
Seen this problem before
Posted on Nov 10, 2009
Testimonial: "Thanks Chief, but what do i do next. Replace the board or ?"
Studio 166. How do I cancel toner display?
To erase the Toner symbol:-
Step 1:- Switch off the machine.
Step 2:- Press 0 and 8 buttons and switch on the machine
Step 3:- AD will appear on the display
Step 4:- Press 695 and then start button
A value either 1 or 0 will display
If it is 0 make it 1 and press interrupt button
If it is 1 make it 0 and press interrupt button
Switch off and on to check.
To erase the spanner symbol:-
Step 2:- Press 0 and 8 buttons and sitch on the machine
Step 4:- Press 251 and then start button
A value will appear on display
Press 0 now and then interrupt
Now AD appears on the display.
Press 252 and repeat the step 4
Press 253 and repeat the step 5
Switch off and on to sheck
Jan 05, 2016 | Toshiba Office Equipment & Supplies
Advanced boot options
Lenovo Basic Input/Output System (BIOS) settings allow you to quickly customize interactions between your operating system and your hardware, especially your hard drive or drives, memory and power supply.
You must get into the Lenovo BIOS before your operating system loads.
Though most users don't typically see options for entering or using the BIOS, multiple changes can be made to customize and optimize your system, such as changing your boot device order and changing the display brightness to conserve power.
Turn off your Lenovo computer.
Press the power button to start your system.
For best results, wait 30 seconds to one minute before starting your system.
This gives you a longer window in which to enter the BIOS.
Press "F1" as soon as the Thinkpad logo appears.
Depending on your Thinkpad model, you may be prompted to press either the blue "Access IBM" or the blue "ThinkAdvantage" button instead of "F1 or F2."
If this is the case, a message will appear stating "To interrupt normal startup, press (one of the listed buttons above)."
Select the "Start setup utility" to open the BIOS setup menu.
Follow the instructions provided in the BIOS setup menu to select BIOS menu sections, settings and to change options.
Next, navigate through the Bios setup pages using keybard arrow keys in order to find failsafe or optimized defaults press ENTER to select your option press F10 save to cmos and restart
http://www.michaelstevenstech.com/lenovoBIOS.html
Jul 07, 2013 | Lenovo IdeaCentre A600 (3011CKU) 21.5 in....
Would like to reset my ibm laptop it says my mircosoft online service is temporarily unavailable and my laptop is slower than ever
Hi and welcome to Fixya1
To reset the machine back to the factory settings, just follow these steps:
    • 1 Shutdown your machine and make sure that the charger is plugged in before doing the reset. Turn on the machine.
    • 2 Press the blue Access IBM button on your ThinkPad keyboard at the screen prompt. The screen prompt reads "To interrupt normal startup, press the blue Access IBM button." This interrupts the Windows reboot process.
    • 3 Double click "Recover to Factory Contents" at the Access IBM predesktop menu.
    • 4 Follow the recovery wizard prompts to initiate the factory restoration process. Your ThinkPad will automatically reboot upon completion.
Hope this helps!
Takasashi
Jul 19, 2011 | IBM ThinkPad R40 2722 Notebook
I want to repeat my question again as follow: I turned on my Lenovo T60 it can not log in to Window because it show the check date and time message after that it show the Key's picture then I restart...
according to the levono support page at this link: http://www-307.ibm.com/pc/support/site.wss/document.do?lndocid=YAST-3JWKJX
below is taken from the web site for a T60
Press the blue ThinkVantage button when the message "To interrupt normal startup, press the blue ThinkVantage button " is displayed to enter the ThinkVantage Productivity Center, then select Start setup utility to open the BIOS Setup Utility.
May 15, 2011 | IBM Computers & Internet
When i turn on my netbook it comes to a black screen that says: We apologize for the inconvenience, but windows did not start successfully. A recent hardware or software change might have caused this. If...
I think it would be more easier if you're going to reinstall the Operating System but the thing is you might loose all of the Data and Files you've saved on your machine, because trying different options to make the startup work will consume a lots of time. You can reinstall the Operating System by using the Windows CD that comes with the machine. If that's an OEM just access the partition for the Operatings System you'll just have to press certain button.
Apr 18, 2011 | Computers & Internet
When I boot up my t61 it starts to spin up then halts. The AC power and battery power indicators are green as is the power indicator. I thought it might be overheating so blew out the fan with...
Most likely the hard disk has just died - try to access the BIOS and see if it's still recognized. For that ress the blue ThinkVantage button when the message "To interrupt normal startup, press the blue ThinkVantage button " is displayed and then select Start setup utility .
If nothing appears on the screen then the defect is in the motherboard - you will need to take it to a service center to determine if the board must be replaced.
Apr 02, 2011 | Lenovo ThinkPad T61 Notebook
My laptop will not boot - Operating System Not Found, cannot enter BIOS system - nothing at all. When I try to access the BIOS, the key keeps beeping. It is a Type 2373. Thank You -- IMCND
How are you attempting to enter the setup (BIOS)? Here are the steps:
Press the blue Access IBM button when the message "To interrupt normal startup, press the blue Access IBM button" is displayed to enter the ThinkVantage Productivity Center, then select Start setup utility to open the BIOS Setup Utility.
Feb 18, 2010 | IBM ThinkPad T42 Notebook
Lenovo thinkpad R51e , when i power on the laptop it show error code 271
You need to set time and date in BIOS.
Aug 10, 2009 | Lenovo ThinkPad R51e Notebook
Computers & Internet Logo
42 people viewed this question
Top Lenovo Computers & Internet Experts
Michael Vincent Cruz
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
